[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-588-g356a0ae05
git at osgeo.org
git at osgeo.org
Tue Feb 22 23:52:33 PST 2022
the project "PostGIS".
via 356a0ae05519717ac1f7e6a4bee123df0aced7c1 (commit)
from dfb2ca5cc2dd62f1a1fa6ada487d5bf9d170e8d2 (commit)
revisions in full, below.
commit 356a0ae05519717ac1f7e6a4bee123df0aced7c1
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Tue Feb 22 07:34:08 2022 +0000
Translated using Weblate (Japanese)
Currently translated at 93.1% (218 of 234 strings)
Translation: postgis/extras_tigergeocoder.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_tigergeocoderxml/ja/
diff --git a/doc/po/ja/extras_tigergeocoder.xml.po b/doc/po/ja/extras_tigergeocoder.xml.po
index 392d89bae..d3522752a 100644
--- a/doc/po/ja/extras_tigergeocoder.xml.po
+++ b/doc/po/ja/extras_tigergeocoder.xml.po
@@ -9,7 +9,7 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2022-02-18 09:52+0000\n"
+"PO-Revision-Date: 2022-02-23 07:52+0000\n"
"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"extras_tigergeocoderxml/ja/>\n"
@@ -1373,7 +1373,7 @@ msgstr ""
msgid ""
"If you have not loaded your state data yet and want these additional tables "
"loaded, do the following"
-msgstr ""
+msgstr "州データをロードしていなくて、これらの追加テーブルをロードしたい場合には、次のようにします。"
#. Tag: programlisting
#: extras_tigergeocoder.xml:367
@@ -1382,6 +1382,8 @@ msgid ""
"UPDATE tiger.loader_lookuptables SET load = true WHERE load = false AND "
"lookup_name IN('tract', 'bg', 'tabblock');"
msgstr ""
+"UPDATE tiger.loader_lookuptables SET load = true WHERE load = false AND "
+"lookup_name IN('tract', 'bg', 'tabblock');"
#. Tag: para
#: extras_tigergeocoder.xml:368
@@ -1880,7 +1882,7 @@ msgstr ""
#: extras_tigergeocoder.xml:540
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"SELECT loader_generate_script(ARRAY['MA','RI'], 'windows') AS result;\n"
"-- result --\n"
@@ -1906,12 +1908,10 @@ msgid ""
msgstr ""
"-- 結果 --\n"
-"set STATEDIR=\"\\gisdata\\www2.census.gov\\geo\\pvs\\tiger2010st"
-"\\44_Rhode_Island\"\n"
"set TMPDIR=\\gisdata\\temp\\\n"
"set UNZIPTOOL=\"C:\\Program Files\\7-Zip\\7z.exe\"\n"
"set WGETTOOL=\"C:\\wget\\wget.exe\"\n"
-"set PGBIN=C:\\Program Files\\PostgreSQL\\8.4\\bin\\\n"
+"set PGBIN=C:\\Program Files\\PostgreSQL\\9.4\\bin\\\n"
"set PGPORT=5432\n"
"set PGHOST=localhost\n"
"set PGUSER=postgres\n"
@@ -1919,16 +1919,18 @@ msgstr ""
"set PGDATABASE=geocoder\n"
"set PSQL=\"%PGBIN%psql\"\n"
"set SHP2PGSQL=\"%PGBIN%shp2pgsql\"\n"
+"cd \\gisdata\n"
"\n"
-"%WGETTOOL% http://www2.census.gov/geo/pvs/tiger2010st/44_Rhode_Island/ --no-"
-"parent --relative --recursive --level=2 --accept=zip,txt --mirror --"
-"reject=html\n"
+"cd \\gisdata\n"
+"%WGETTOOL% ftp://ftp2.census.gov/geo/tiger/TIGER2015/PLACE/tl_*_25_* --no-"
+"parent --relative --recursive --level=2 --accept=zip --mirror --reject=html\n"
+"cd \\gisdata/ftp2.census.gov/geo/tiger/TIGER2015/PLACE\n"
":\n"
#: extras_tigergeocoder.xml:542
+#, no-c-format
msgid ""
"SELECT loader_generate_script(ARRAY['MA','RI'], 'sh') AS result;\n"
"-- result --\n"
@@ -1956,30 +1958,39 @@ msgid ""
msgstr ""
-"-- result --\n"
-"STATEDIR=\"/gisdata/www2.census.gov/geo/pvs/tiger2010st/44_Rhode_Island\"\n"
+"-- 結果 --\n"
"TMPDIR=\"/gisdata/temp/\"\n"
"UNZIPTOOL=unzip\n"
-"PGPORT=5432\n"
-"PGHOST=localhost\n"
-"PGUSER=postgres\n"
-"PGPASSWORD=yourpasswordhere\n"
-"PGDATABASE=geocoder\n"
-"PSQL=psql\n"
-"SHP2PGSQ=shp2pgsql\n"
+"WGETTOOL=\"/usr/bin/wget\"\n"
+"export PGBIN=/usr/lib/postgresql/9.4/bin\n"
+"-- PostgreSQLで使う変数: https://www.postgresql.org/docs/current/static/libpq-"
+"envars.html\n"
+"export PGPORT=5432\n"
+"export PGHOST=localhost\n"
+"export PGUSER=postgres\n"
+"export PGPASSWORD=yourpasswordhere\n"
+"export PGDATABASE=geocoder\n"
+"PSQL=${PGBIN}/psql\n"
+"SHP2PGSQL=${PGBIN}/shp2pgsql\n"
+"cd /gisdata\n"
"\n"
-"wget http://www2.census.gov/geo/pvs/tiger2010st/44_Rhode_Island/ --no-parent "
-"--relative --recursive --level=2 --accept=zip,txt --mirror --reject=html\n"
+"cd /gisdata\n"
+"wget ftp://ftp2.census.gov/geo/tiger/TIGER2015/PLACE/tl_*_25_* --no-parent --"
+"relative --recursive --level=2 --accept=zip --mirror --reject=html\n"
+"cd /gisdata/ftp2.census.gov/geo/tiger/TIGER2015/PLACE\n"
+"rm -f ${TMPDIR}/*.*\n"
":\n"
#. Tag: para
#: extras_tigergeocoder.xml:549
+#, no-c-format
msgid ""
", <xref linkend=\"Loader_Generate_Nation_Script\"/>, <xref linkend="
"\"Drop_State_Tables_Generate_Script\"/>"
-msgstr ", <xref linkend=\"Missing_Indexes_Generate_Script\"/>"
+msgstr ""
+", <xref linkend=\"Loader_Generate_Nation_Script\"/>, <xref linkend="
+"\"Drop_State_Tables_Generate_Script\"/>"
#. Tag: refname
#: extras_tigergeocoder.xml:555
Summary of changes:
doc/po/ja/extras_tigergeocoder.xml.po | 57 +++++++++++++++++++++--------------
1 file changed, 34 insertions(+), 23 deletions(-)
hooks/post-receive
