[postgis-tickets] [PostGIS] #5102: CopyTopology: ERROR: column "geom" is of type geometry but expression is of type integer
PostGIS trac at osgeo.org
Wed Feb 23 00:08:01 PST 2022
of type integer
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  blocker   |  Milestone:  PostGIS 3.3.0
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"f5b476bf5d7a6c4c8e1fe0866eaad5549b1bb96c/git"
 f5b476bf/git]:
 #!CommitTicketReference repository="git"
 revision="f5b476bf5d7a6c4c8e1fe0866eaad5549b1bb96c"
 Restore backward compatible order of fields in topology node table
 Closes #5102
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5102#comment:2>
