[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0-18-g9647b4667
git at osgeo.org
git at osgeo.org
Wed Jan 5 15:43:16 PST 2022
the project "PostGIS".
The branch, main has been updated
via 9647b4667cdc49e0c4ea5e18c0dbe61589f2ed56 (commit)
from 7ece57ac6e9f0de3bc919405378ad873d76f2f03 (commit)
revisions in full, below.
commit 9647b4667cdc49e0c4ea5e18c0dbe61589f2ed56
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 6 00:36:16 2022 +0100
Look for xml2pot and msgmerge at ./configure time
Avoids `make update-po` and `make update-pot` possibly creating
empty template files.
diff --git a/configure.ac b/configure.ac
index f41bbfb2a..c85bdd73d 100644
--- a/configure.ac
+++ b/configure.ac
@@ -187,6 +187,16 @@ if test "x$XSLTPROC" = "x"; then
CAN_BUILD_COMMENTS=no
fi
+AC_PATH_PROG([XML2POT], [xml2pot], [])
+if test "x$XML2POT" = "x"; then
+ AC_MSG_WARN([xml2pot is not installed so translations cannot be updated])
+fi
+AC_PATH_PROG([MSGMERGE], [msgmerge], [])
+if test "x$MSGMERGE" = "x"; then
+ AC_MSG_WARN([msgmerge is not installed so translations cannot be updated])
+fi
CAN_BUILD_PDF=${CAN_BUILD_COMMENTS}
AC_PATH_PROG([IMAGEMAGICK], [convert], [])
diff --git a/doc/Makefile.in b/doc/Makefile.in
index dc396dffc..fbb93c118 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -38,6 +38,7 @@ INSTALL_DATA=@INSTALL_DATA@
XSLTPROC=@XSLTPROC@
XSLBASE=@XSLBASE@
+CAN_UPDATE_TRANSLATIONS=@CAN_UPDATE_TRANSLATIONS@
XMLLINT=@XMLLINT@
CAN_BUILD_COMMENTS=@CAN_BUILD_COMMENTS@
PERL=@PERL@
@@ -82,10 +83,10 @@ DBLATEX=@DBLATEX@
IMAGEMAGICK=@IMAGEMAGICK@
# Gettext for translated documentation
-MSGMERGE=msgmerge
+MSGMERGE=@MSGMERGE@
# XML gettext tools
-XML2POT=xml2pot
+XML2POT=@XML2POT@
# DOCBOOK to EPUB
DBTOEPUB=dbtoepub
@@ -166,6 +167,9 @@ XML_INPUTS = $(XML_SOURCES) $(XML_GENERATED_SOURCES)
XML_INPUTS_POT = $(XML_SOURCES:%.xml=po/templates/%.xml.pot)
.PHONY: $(XML_INPUTS_POT)
+ifeq ($(XML2POT),)
+$(XML_INPUTS_POT): requirements_not_met_xml2pot
+else
$(XML_INPUTS_POT): po/templates/%.xml.pot: %.xml
@if test -f $@; then \
$(XML2POT) $< > $@.tmp; \
@@ -180,11 +184,15 @@ $(XML_INPUTS_POT): po/templates/%.xml.pot: %.xml
else \
$(XML2POT) $< > $@; \
fi;
+endif
# Update translation templates
update-pot: $(XML_INPUTS_POT)
# Creates or updates translation files
+ifeq ($(MSGMERGE),)
+update-po: requirements_not_met_msgmerge
+else
update-po: $(XML_INPUTS_POT)
@for lang in $(translations); do \
echo "Creating po files for language $$lang..." ; \
@@ -198,6 +206,7 @@ update-po: $(XML_INPUTS_POT)
fi; \
done; \
done
+endif
pull-tx:
tx pull --all
@@ -481,3 +490,15 @@ requirements_not_met_imagemagick:
@echo
@echo " http://postgis.net/documentation"
@echo
+requirements_not_met_gettext:
+ @echo
+ @echo "configure was unable to find both gettext's 'msgmerge' utility program."
+ @echo "To update the translation templates, install gettext and then re-run configure."
+ @echo
+requirements_not_met_xml2pot:
+ @echo
+ @echo "configure was unable to find the 'xml2pot' utility program."
+ @echo "To update the translation templates, install poxml and then re-run configure."
+ @echo
Summary of changes:
configure.ac | 10 ++++++++++
doc/Makefile.in | 25 +++++++++++++++++++++++--
2 files changed, 33 insertions(+), 2 deletions(-)
hooks/post-receive
