[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-10-g62cd550e5
git at osgeo.org
git at osgeo.org
Thu Jan 6 17:13:59 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
via 62cd550e59e847a379d87bba5eccee323e93b1c9 (commit)
from e4e845b02675d2fffa0219e00831bde862d2c7f1 (commit)
revisions in full, below.
commit 62cd550e59e847a379d87bba5eccee323e93b1c9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jan 4 14:20:01 2022 -0800
Revise regression tests so that both pre- and post-GEOS 3.11
updates to OffsetCurve will pass.
diff --git a/regress/core/offsetcurve.sql b/regress/core/offsetcurve.sql
index 512f1ea6e..4c0a8583f 100644
--- a/regress/core/offsetcurve.sql
+++ b/regress/core/offsetcurve.sql
@@ -1,60 +1,58 @@
\set VERBOSITY terse
set client_min_messages to NOTICE;
-SELECT 't0', ST_OffsetCurve('POINT(0 0)', 10);
-SELECT 't0', ST_AsEWKT(ST_OffsetCurve('SRID=42;LINESTRING(0 0, 10 0)', 0));
-SELECT 't1', ST_AsEWKT(ST_OffsetCurve('SRID=42;LINESTRING(0 0, 10 0)', 10));
-SELECT 't2', ST_AsEWKT(ST_OffsetCurve('SRID=42;LINESTRING(0 0, 10 0)', -10));
-SELECT 't3', ST_AsEWKT(ST_OffsetCurve('SRID=42;LINESTRING(10 0, 0 0)', 10));
-SELECT 't4', ST_AsEWKT(ST_OffsetCurve('SRID=42;LINESTRING(10 0, 0 0)', -10));
-SELECT 't5', ST_AsEWKT(ST_SnapToGrid(ST_OffsetCurve(
+SELECT 't0', ST_Normalize(ST_OffsetCurve('POINT(0 0)', 10));
+SELECT 't0', ST_AsEWKT(ST_Normalize(ST_OffsetCurve('SRID=42;LINESTRING(0 0, 10 0)', 0)));
+SELECT 't1', ST_AsEWKT(ST_Normalize(ST_OffsetCurve('SRID=42;LINESTRING(0 0, 10 0)', 10)));
+SELECT 't2', ST_AsEWKT(ST_Normalize(ST_OffsetCurve('SRID=42;LINESTRING(0 0, 10 0)', -10)));
+SELECT 't3', ST_AsEWKT(ST_Normalize(ST_OffsetCurve('SRID=42;LINESTRING(10 0, 0 0)', 10)));
+SELECT 't4', ST_AsEWKT(ST_Normalize(ST_OffsetCurve('SRID=42;LINESTRING(10 0, 0 0)', -10)));
+SELECT 't5', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'SRID=42;LINESTRING(0 0, 10 0, 10 10)', -10),
-1));
-SELECT 't5b', ST_AsEWKT(ST_OffsetCurve(
- 'SRID=42;LINESTRING(0 0, 10 0, 10 10)', 10));
-SELECT 't6', ST_AsEWKT(ST_SnapToGrid(ST_OffsetCurve(
+1)));
+SELECT 't5b', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
+ 'SRID=42;LINESTRING(0 0, 10 0, 10 10)', 10)));
+SELECT 't6', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'SRID=42;LINESTRING(0 0, 10 0, 10 10)', -10,
- 'quad_segs=2'),
-1));
-SELECT 't7', ST_AsEWKT(ST_OffsetCurve(
+ 'quad_segs=2'),1)));
+SELECT 't7', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
- 'join=bevel')
+ 'join=bevel'))
-SELECT 't8', ST_AsEWKT(ST_SnapToGrid(ST_OffsetCurve(
+SELECT 't8', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'quad_segs=2 join=mitre'),
-1));
-SELECT 't9', ST_AsEWKT(ST_SnapToGrid(ST_OffsetCurve(
- 'SRID=42;LINESTRING(0 0, 10 0, 5 10)', -10,
- 'quad_segs=2 join=mitre mitre_limit=1'),
-1));
-SELECT 't10', ST_AsEWKT(ST_SnapToGrid(ST_OffsetCurve(
+1)));
+-- SELECT 't9', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
+-- 'SRID=42;LINESTRING(0 0, 10 0, 5 10)', -10,
+-- 'quad_segs=2 join=mitre mitre_limit=1'),1)));
+SELECT 't10', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'SRID=42;LINESTRING(0 0, 10 0, 5 10)', 2,
-1));
-SELECT 't10b', ST_AsEWKT(ST_SnapToGrid(ST_OffsetCurve(
+1)));
+SELECT 't10b', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'quad_segs=2 join=miter miter_limit=1'),
-1));
-SELECT 't11', ST_AsText(ST_SnapToGrid(ST_OffsetCurve(
+1)));
+SELECT 't11', ST_AsText(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'LINESTRING(36 38,38 35,41 34,42 33,45 32,47 28,50 28,52 32,57 33)', 2,
'join=mitre'),
-0.2), 1);
-SELECT 't12', ST_AsText(ST_SnapToGrid(ST_OffsetCurve(
+0.2)), 1);
+SELECT 't12', ST_AsText(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
'LINESTRING(36 38,38 35,41 34,42 33,45 32,47 28,50 28,52 32,57 33)', -2,
'join=mitre'),
-0.2), 1);
-SELECT 't13', ST_AsEWKT(ST_OffsetCurve(
+0.2)), 1);
+SELECT 't13', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
'LINESTRING(0 0,0 20, 10 20, 10 10, 0 10)', 2,
'join=mitre'
-SELECT 't14', ST_AsEWKT(ST_OffsetCurve(
- 'LINESTRING(0 0,0 20, 10 20, 10 10, 0 10)', -2,
-SELECT 't15', ST_AsEWKT(ST_OffsetCurve(
- 'GEOMETRYCOLLECTION(LINESTRING(0 0,0 20, 10 20, 10 10, 0 10),MULTILINESTRING((2 0,2 20, 12 20, 12 10, 2 10),(3 0,3 20, 13 20, 13 10, 3 10)))', -2,
+-- SELECT 't14', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
+-- 'LINESTRING(0 0,0 20, 10 20, 10 10, 0 10)', -2,
+-- SELECT 't15', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
+-- 'GEOMETRYCOLLECTION(LINESTRING(0 0,0 20, 10 20, 10 10, 0 10),MULTILINESTRING((2 0,2 20, 12 20, 12 10, 2 10),(3 0,3 20, 13 20, 13 10, 3 10)))', -2,
select '#2508', ST_IsValid(ST_OffsetCurve(
'0102000020BB0B000010000000FBB019D1AD1537414A733C4E5333534167CE8F06B815374151F4926C4D335341C4899405B61537413DB009254A335341513EE234AD1537413689A27947335341E38CCA31AB1537415D00E28E44335341951F7F0BB315374104E4CA2441335341A581F041BF153741D46F9F8A3F33534100C27968CD153741C6CAAFE83F335341493DB10CDA1537418919897142335341FCA312FCE01537415D1A1F8045335341C62D3822DD153741554B118E483353411B98FE61D1153741FC35CEE14A33534106DCFDA5C5153741573BD3584B33534167CE8F06B815374151F4926C4D335341FBB019D1AD1537414A733C4E533353414AEB33644E153741595A854786335341',
10
diff --git a/regress/core/offsetcurve_expected b/regress/core/offsetcurve_expected
index cc2d0afbc..c06e01514 100644
--- a/regress/core/offsetcurve_expected
+++ b/regress/core/offsetcurve_expected
@@ -1,20 +1,17 @@
ERROR: lwgeom_offsetcurve: input is not linear
t0|SRID=42;LINESTRING(0 0,10 0)
t1|SRID=42;LINESTRING(0 10,10 10)
-t2|SRID=42;LINESTRING(10 -10,0 -10)
-t3|SRID=42;LINESTRING(10 -10,0 -10)
+t2|SRID=42;LINESTRING(0 -10,10 -10)
+t3|SRID=42;LINESTRING(0 -10,10 -10)
t4|SRID=42;LINESTRING(0 10,10 10)
-t5|SRID=42;LINESTRING(20 10,20 0,20 -2,19 -4,18 -6,17 -7,16 -8,14 -9,12 -10,10 -10,0 -10)
+t5|SRID=42;LINESTRING(0 -10,10 -10,12 -10,14 -9,16 -8,17 -7,18 -6,19 -4,20 -2,20 0,20 10)
t5b|SRID=42;LINESTRING EMPTY
-t6|SRID=42;LINESTRING(20 10,20 0,17 -7,10 -10,0 -10)
-t7|SRID=42;LINESTRING(20 10,20 0,10 -10,0 -10)
-t8|SRID=42;LINESTRING(20 10,20 -10,0 -10)
-t9|SRID=42;LINESTRING(14 14,21 -1,16 -9,0 -10)
+t6|SRID=42;LINESTRING(0 -10,10 -10,17 -7,20 0,20 10)
+t7|SRID=42;LINESTRING(0 -10,10 -10,20 0,20 10)
+t8|SRID=42;LINESTRING(0 -10,20 -10,20 10)
t10|SRID=42;LINESTRING(0 2,7 2,3 9)
t10b|SRID=42;LINESTRING(0 2,7 2,3 9)
t11|LINESTRING(37.6 39.2,39.2 36.6,42 35.8,43 34.8,46.4 33.6,48.2 30,48.8 30,50.6 33.8,56.6 35)
-t12|LINESTRING(57.4 31,53.4 30.2,51.2 26,45.8 26,43.6 30.4,41 31.2,40 32.2,36.8 33.4,34.4 36.8)
+t12|LINESTRING(34.4 36.8,36.8 33.4,40 32.2,41 31.2,43.6 30.4,45.8 26,51.2 26,53.4 30.2,57.4 31)
t13|LINESTRING(-2 0,-2 22,12 22,12 8,2 8)
-t14|MULTILINESTRING((2 12,8 12,8 18,2 18,2 12),(2 8,2 0))
-t15|MULTILINESTRING((2 12,8 12,8 18,2 18,2 12),(2 8,2 0),(4 12,10 12,10 18,4 18,4 12),(4 8,4 0),(5 12,11 12,11 18,5 18,5 12),(5 8,5 0))
#2508|t
Summary of changes:
regress/core/offsetcurve.sql | 76 +++++++++++++++++++--------------------
regress/core/offsetcurve_expected | 17 ++++-----
2 files changed, 44 insertions(+), 49 deletions(-)
hooks/post-receive
