[postgis-tickets] [PostGIS] #5041: loader_generate_script generates script with invalid syntax
trac at osgeo.org
Fri Jan 7 12:14:27 PST 2022
Reporter: naoko | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: tiger geocoder | Version: 2.5.x
Keywords: |
loader_generate_script generated the following 2 lines which is invalid
syntax
ALTER TABLE tiger_staging.UT_tract RENAME geoid IF EXISTS TO tract_id;
ALTER TABLE tiger_staging.UT_tract RENAME geoid10 IF EXISTS TO tract_id;
also
gisdb=# select table_name, lookup_name, process_order, lookup_name,
level_state, load from tiger.loader_lookuptables where table_name LIKE
'tabblock%';
table_name | lookup_name | process_order | lookup_name | level_state |
load
tabblock10 | tabblock | 11 | tabblock | t | f
tabblock20 | tabblock20 | 11 | tabblock20 | t | t
(2 rows)
cause the link to be created like this
wget
https://www2.census.gov/geo/tiger/TIGER2018/TABBLOCK20/tl_2018_49_tabblock20.zip
--mirror --reject=html
but tabblock20 do not exists but tabblock10 do.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5041>
