[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-133-g2d5247b0c
git at osgeo.org
git at osgeo.org
Sun Jan 9 21:08:14 PST 2022
the project "PostGIS".
via 2d5247b0c167c86060cf8d714043867511082392 (commit)
via 84146b6383b07f9f560948993ebdd6f4e2b58aa8 (commit)
via 0ef9e94ca32f2b4c1a03e5c824742bac47650821 (commit)
from 7ed2c1a17ebba9826e01542205dd744141deb17b (commit)
revisions in full, below.
commit 2d5247b0c167c86060cf8d714043867511082392
Author: jsanz <jsanz at osgeo.org>
Date: Sun Jan 9 08:19:15 2022 +0000
Translated using Weblate (Spanish)
Currently translated at 89.3% (497 of 556 strings)
Translation: postgis/extras_topology.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_topologyxml/es/
diff --git a/doc/po/es/extras_topology.xml.po b/doc/po/es/extras_topology.xml.po
index ced358c45..18b06e89b 100644
--- a/doc/po/es/extras_topology.xml.po
+++ b/doc/po/es/extras_topology.xml.po
@@ -10,14 +10,16 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2021-11-08 06:12+0000\n"
-"PO-Revision-Date: 2021-11-28 21:13+0000\n"
-"Last-Translator: Regina Obe\n"
-"Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/es/)\n"
+"PO-Revision-Date: 2022-01-10 05:06+0000\n"
+"Last-Translator: jsanz <jsanz at osgeo.org>\n"
+"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
+"extras_topologyxml/es/>\n"
+"Language: es\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"Language: es\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 4.10.1\n"
#. Tag: title
#: extras_topology.xml:3
@@ -136,6 +138,7 @@ msgstr "getfaceedges_returntype"
msgid ""
"A composite type that consists of a sequence number and an edge number."
msgstr ""
+"Un tipo compuesto que necesita un número de secuencia y un número de eje."
#. Tag: title
#: extras_topology.xml:34 extras_topology.xml:58 extras_topology.xml:107
@@ -172,6 +175,9 @@ msgid ""
" is the return type for <varname>ST_GetFaceEdges</varname> and "
"<varname>GetNodeEdges</varname> functions."
msgstr ""
+"Un tipo compuesto que consiste de un número de secuencia y de un número de "
+"eje. Es el tipo devuelto por las funciones <varname>ST_GetFaceEdges</"
+"varname> y <varname>GetNodeEdges</varname> ."
#. Tag: para
#: extras_topology.xml:43
@@ -320,7 +326,10 @@ msgid ""
"A composite type that consists of an error message and id1 and id2 to denote"
" location of error. This is the return type for "
"<varname>ValidateTopology</varname>."
-msgstr " Un tipo compuesto que consta de un mensaje de error e id1 e id2 para denotar la ubicación del error. Este es el tipo de valor devuelto para<varname>ValidateTopology</varname>."
+msgstr ""
+"Un tipo compuesto que consta de un mensaje de error e id1 e id2 para denotar "
+"la ubicación del error. Este es el tipo de valor devuelto por "
+"<varname>ValidateTopology</varname>."
#. Tag: para
#: extras_topology.xml:108
commit 84146b6383b07f9f560948993ebdd6f4e2b58aa8
Date: Sun Jan 9 08:10:47 2022 +0000
Currently translated at 53.4% (132 of 247 strings)
Translation: postgis/installation.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/installationxml/es/
diff --git a/doc/po/es/installation.xml.po b/doc/po/es/installation.xml.po
index f554dc6c6..d96c2f089 100644
--- a/doc/po/es/installation.xml.po
+++ b/doc/po/es/installation.xml.po
@@ -12,8 +12,8 @@ msgstr ""
"POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2022-01-08 03:27+0000\n"
-"Last-Translator: robe <regina at arrival3d.com>\n"
"installationxml/es/>\n"
"Language: es\n"
@@ -21,7 +21,7 @@ msgstr ""
-"X-Generator: Weblate 4.9.1\n"
#. Tag: title
#: installation.xml:3
@@ -68,20 +68,20 @@ msgstr ""
#. Tag: para
#: installation.xml:13
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"Once PostGIS is installed, it needs to be enabled (<xref linkend="
"\"create_spatial_db\"/>) or upgraded (<xref linkend=\"upgrading\"/>) in each "
"individual database you want to use it in."
msgstr ""
-"Una vez que se instala postgis, es necesario habilitarlo en cada base de "
+"Una vez que se instala PostGIS, es necesario habilitarlo en cada base de "
"datos en la que desee utilizarlo."
#. Tag: title
#: installation.xml:23
#, no-c-format
msgid "Compiling and Install from Source"
-msgstr ""
+msgstr "Compilación e instalación desde el código fuente"
#. Tag: para
#: installation.xml:26
@@ -93,7 +93,7 @@ msgid ""
msgstr ""
"Muchos Sistemas Operativos incluyen ya paquetes precompilados PostgreSQL/"
"PostGIS. En la mayoría de casos no es necesario compilar salvo si quieres "
-"las ultimas versiones o eres alguien que hace mantenimiento de paquetes."
+"las ultimas versiones o haces mantenimiento de paquetes."
#. Tag: para
#: installation.xml:31
@@ -105,12 +105,12 @@ msgid ""
"User contributed compile guides</ulink> and <ulink url=\"http://trac.osgeo."
"org/postgis/wiki/DevWikiMain\">PostGIS Dev Wiki</ulink>."
msgstr ""
-"Esta sección incluye las instrucciones generales de compilado, si estas "
-"compilando en Windows o otro Sistema Operativo, puedes encontrar información "
+"Esta sección incluye las instrucciones generales de compilado.Si estas "
+"compilando en Windows u otro Sistema Operativo, puedes encontrar información "
"adicional detallada en <ulink url=\"http://trac.osgeo.org/postgis/wiki/"
"UsersWikiInstall\">PostGIS User contributed compile guides</ulink> y <ulink "
-"url=\"http://trac.osgeo.org/postgis/wiki/DevWikiMain\">PostGIS Dev Wiki</"
-"ulink>."
+"url=\"http://trac.osgeo.org/postgis/wiki/DevWikiMain\">PostGIS Dev "
+"Wiki</ulink>."
#. Tag: para
#: installation.xml:33
@@ -125,7 +125,7 @@ msgstr ""
#. Tag: para
#: installation.xml:34
+#, no-c-format
msgid ""
"If you are a windows user, you can get stable builds via Stackbuilder or "
"<ulink url=\"https://postgis.net/windows_downloads\">PostGIS Windows "
@@ -136,11 +136,11 @@ msgid ""
"PostGIS"
msgstr ""
"Si eres usuario de Windows, puedes obtener versiones estables compiladas via "
-"Stackbuilder o <ulink url=\"http://www.postgis.org/download/windows/\"> "
-"sitio de descragas de PostGIS para Windows</ulink> También tenemos <ulink "
+"Stackbuilder o el <ulink url=\"http://www.postgis.org/download/windows/\"> "
+"sitio de descargas de PostGIS para Windows</ulink> También tenemos <ulink "
"url=\"http://www.postgis.org/download/windows/experimental.php\">versiones "
"experimentales para Windows </ulink> que son publicadas normalmente una o "
-"dos veces por semana o cuando algo interesante ocurre. Puedes utilizar estas "
+"dos veces por semana o cuando ocurre algo interesante. Puedes utilizar éstas "
"para experimentar con las versiones de desarrollo de PostGIS"
#. Tag: para
@@ -153,11 +153,11 @@ msgid ""
"against PostgreSQL versions &min_postgres_version; or higher. Earlier "
"versions of PostgreSQL are <emphasis>not</emphasis> supported."
msgstr ""
-"El modulo PostGIS es una extensión del servidor PostgreSQL. Como tal, "
-"PostGIS &last_release_version; <emphasis>requiere</emphasis> PostgreSQL con "
-"acceso completo cabeceras del servidor con el fin de compilar. Puede ser "
-"compilado en PostgreSQL versiones &min_postgres_version;, o superior. Las "
-"versiones anteriores de PostgreSQL <emphasis>no</emphasis> son compatibles."
+"El modulo PostGIS es una extensión del servidor PostgreSQL. Como tal, para "
+"poder compilar PostGIS &last_release_version; <emphasis>requiere</emphasis> "
+"acceso completo a las cabeceras del servidor PostgreSQL. Puede ser compilado "
+"en versiones &min_postgres_version;, o superior de PostgreSQL. Las versiones "
+"anteriores de PostgreSQL <emphasis>no</emphasis> son compatibles."
#. Tag: para
#: installation.xml:47
@@ -168,8 +168,8 @@ msgid ""
"org </ulink> ."
msgstr ""
"Si todavía no tienes instalado PostgreSQL puedes ir a la guía de instalación "
-"de PostgreSQL en <ulink url=\"http://www.postgresql.org\"> http://www."
-"postgresql.org </ulink> ."
+"en <ulink url=\"http://www.postgresql.org\"> http://www.postgresql.org </"
+"ulink> ."
#. Tag: para
#: installation.xml:57
@@ -179,14 +179,13 @@ msgid ""
"explicitly link PostgreSQL against the standard C++ library:"
msgstr ""
"Para tener compatibilidad con las funcionalidades GEOS, cuando instales "
-"PostgreSQL necesitar hacer un enlace explícito de PostgreSQL con la librería "
-"estándar C++:"
+"PostgreSQL necesitar hacer un enlace explícito con la librería estándar C++:"
#. Tag: programlisting
#: installation.xml:62
#, no-c-format
msgid "LDFLAGS=-lstdc++ ./configure [YOUR OPTIONS HERE]"
-msgstr "LDFLAGS=-lstdc++ ./configure [PON TUS OPCIONES AQUI]"
+msgstr "LDFLAGS=-lstdc++ ./configure [PON TUS OPCIONES AQUÍ]"
#. Tag: para
#: installation.xml:64
@@ -197,10 +196,10 @@ msgid ""
"closed or similar things) try this trick. This will require recompiling your "
"PostgreSQL from scratch, of course."
msgstr ""
-"Esta es una falsa solución para excepciones de interacción de C++ con "
-"herramientas de desarrollo antiguas. Si experimentas problemas extraños "
-"(backend cerrado inesperadamente o cosas similares) prueba este truco. Para "
-"ello será necesario volver a compilar PostgreSQL desde cero, por supuesto."
+"Esta es una solución para falsas excepciones C++ con herramientas de "
+"desarrollo antiguas. Prueba este truco si experimentas problemas extraños ("
+"backend cerrado inesperadamente o cosas similares). Porc supuesto, será "
+"necesario volver a compilar PostgreSQL desde cero."
#. Tag: para
#: installation.xml:72
@@ -210,8 +209,8 @@ msgid ""
"source. They are written for Linux users and will not work on Windows or Mac."
msgstr ""
"Los siguientes pasos describen la configuración y compilación del código "
-"fuente de PostGIS. Están escritas para usuarios Linux y no funcionaran con "
-"Windows o Mac."
+"fuente de PostGIS. Están escritas para usuarios Linux y no funcionarán con "
+"Windows o Mac."
#. Tag: title
#: installation.xml:79
commit 0ef9e94ca32f2b4c1a03e5c824742bac47650821
Author: robe <regina at arrival3d.com>
Date: Fri Jan 7 03:20:08 2022 +0000
Currently translated at 52.2% (129 of 247 strings)
index 649fcab41..f554dc6c6 100644
@@ -12,15 +12,16 @@ msgstr ""
-"PO-Revision-Date: 2018-10-18 13:20+0000\n"
-"Last-Translator: Manuel Retamozo <manuel at retamozo.com.ar>\n"
-"Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/"
-"es/)\n"
+"PO-Revision-Date: 2022-01-08 03:27+0000\n"
+"Last-Translator: robe <regina at arrival3d.com>\n"
+"installationxml/es/>\n"
"Language: es\n"
+"X-Generator: Weblate 4.9.1\n"
#. Tag: title
@@ -246,22 +247,22 @@ msgstr ""
#. Tag: para
#: installation.xml:96
+#, no-c-format
msgid ""
"Alternatively, checkout the source from the <ulink url=\"https://git-scm.com/"
"\"> git </ulink> repository <ulink url=\"https://git.osgeo.org/gitea/postgis/"
"postgis/\"> https://git.osgeo.org/gitea/postgis/postgis/ </ulink> ."
msgstr ""
-"De forma alternativa se puede obtener el código fuente del repositorio "
-"<ulink url=\"http://subversion.apache.org/\"> svn </ulink> <ulink url="
-"\"http://svn.osgeo.org/postgis/trunk/\"> http://svn.osgeo.org/postgis/trunk/ "
-"</ulink> ."
+"De forma alternativa se puede obtener el código fuente del <ulink url="
+"\"https://git-scm.com/\"> git </ulink> repositorio <ulink url=\"https://git."
+"osgeo.org/gitea/postgis/postgis/\"> https://git.osgeo.org/gitea/postgis/"
+"postgis/ </ulink> ."
#: installation.xml:108
#, no-c-format
msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis"
-msgstr ""
+msgstr "git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis"
#. Tag: para
#: installation.xml:110
Summary of changes:
doc/po/es/extras_topology.xml.po | 21 +++++++----
doc/po/es/installation.xml.po | 78 ++++++++++++++++++++--------------------
2 files changed, 54 insertions(+), 45 deletions(-)
hooks/post-receive
