[postgis-tickets] [PostGIS] #5043: Duplicated msgid in using_postgis_dataman.xml
PostGIS trac at osgeo.org
Mon Jan 10 06:07:12 PST 2022
 Reporter:  strk           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  medium         |  Milestone:  PostGIS 3.3.0
Component:  documentation  |    Version:  3.2.x
 Keywords:                 |
 Our {{{ using_postgis_dataman.xml }}} contains two different tags
 containing the same content: {{{ TRIANGLE ((0 0, 0 9, 9 0, 0 0)) }}} --
 one is  a <programlisting> tag on line 190 and another is a <para> tag on
 line 553. This results in xml2pot creating 2 msgid strings being the same,
 and msgmerge fail when trying to update the corresponding .po files.
 To reproduce: {{{make -C doc/ update-po}}}
 Note that the failure in {{{ make update-po }}} results in Transifex not
 receiving a translation file on {{{ make push-tx }}}.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5043>
