[postgis-tickets] [PostGIS] #5043: Duplicated msgid in using_postgis_dataman.xml
PostGIS trac at osgeo.org
Mon Jan 10 06:28:50 PST 2022
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.3.0
 Component:  documentation  |    Version:  3.2.x
Resolution:                 |   Keywords:
Comment (by strk):
 Regina I see that we have a similar problem with spatial_relationship.xml
 whereas the SAME text is used for both <refpurpose> and <para> in the
 description, resulting in the same msgid. In git history I see you changed
 some po files to include the tag in the msgid, see commit
 [e357e0a7381a8c2f36c62375380acbf800da697d/git] -- did you find that
 approach to actually work ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5043#comment:2>
