[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0-146-gcbcea8fe1
Mon Jan 10 16:56:00 PST 2022
the project "PostGIS".
The branch, main has been updated
       via  cbcea8fe1429633f672c30b63ae31bdeda99ee21 (commit)
      from  301f8df9b2687d4fd719ee7da3ae5f415599939d (commit)
revisions in full, below.
commit cbcea8fe1429633f672c30b63ae31bdeda99ee21
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jan 11 01:54:19 2022 +0100
    Add weblate commandline configuration and early instructions
diff --git a/doc/.weblate b/doc/.weblate
new file mode 100644
index 000000000..3b8892be2
--- /dev/null
+++ b/doc/.weblate
@@ -0,0 +1,2 @@
+[weblate]
+  url = https://weblate.osgeo.org/api/
diff --git a/doc/po/README b/doc/po/README
index e0c4950cf..6584bb8c9 100644
--- a/doc/po/README
+++ b/doc/po/README
@@ -31,9 +31,34 @@ NOTE: the recommended workflow is:
  make pull-tx
  do:
   make html-localized || edit
- until success
+ until success
  if edits:
   make push-tx
   make pull-tx
   commit changes to repo
  fi
+Using weblate [EXPERIMENTAL]
+Weblate web-ui to translation was setup here:
+https://weblate.osgeo.org/projects/postgis
+Translations made via Weblate will automatically be pushed
+to the a configured repository (currently robe's fork) with
+'weblate' as a committer, see commit 2d5247b0c as an example.
+Changes to the templates should be automatically fetched by Weblate
+via webhook, see https://git.osgeo.org/gitea/postgis/postgis/settings/hooks
+(currently broken because the configured repository does not match the
+URL of the official repository)
+Local changes to the translation files can be uploaded manually
+to weblate with a command like the following:
+  wlc upload \
+    postgis/introductionxml/it \
+    --input po/it_IT/introduction.xml.po
+NOTE: wlc 1.2 is known to be not functional, while wlc 1.12
+      (current latest when installed via pip) seems fine
Summary of changes:
 doc/.weblate  |  2 ++
 doc/po/README | 27 ++++++++++++++++++++++++++-
 2 files changed, 28 insertions(+), 1 deletion(-)
 create mode 100644 doc/.weblate
hooks/post-receive
