[postgis-tickets] [PostGIS] #5049: Regression on buffer tests on berrie64
PostGIS trac at osgeo.org
Tue Jan 11 11:34:21 PST 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.2.1
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
 Berrie64 has been failing for a while.  I suspect because of the new
 buffer logic in GEOS.
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/3070/consoleFull
 11:15:39  ./regress/core/regress_buffer_params .. failed (diff expected
 obtained: /tmp/pgis_reg/test_46_diff)
 11:15:39
 11:15:39 --- ./regress/core/regress_buffer_params_expected      2022-01-11
 08:04:48.687916768 -0800
 11:15:39 +++ /tmp/pgis_reg/test_46_out  2022-01-11 08:15:39.769355510
 -0800
 11:15:39 @@ -3,13 +3,13 @@
 11:15:39  line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
 11:15:39  line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
 11:15:39  line quadsegs=2 endcap=square|POLYGON((10 2,12 2,12 -2,0 -2,-2
 -2,-2 2,10 2))
 11:15:39 -line join=mitre mitre_limit=1.0 side=both|POLYGON((148.12357
 161.60116,159.5301 156.87643,160 50,159.80785 48.0491,159.2388
 46.17317,158.3147 44.4443,157.07107 42.92893,155.5557 41.6853,153.82683
 40.7612,151.9509 40.19215,150 40,148.0491 40.19215,146.17317
 40.7612,144.4443 41.6853,142.92893 42.92893,141.6853 44.4443,140.7612
 46.17317,140.19215 48.0491,140 50,140 125.85786,57.07107 42.92893,55.5557
 41.6853,53.82683 40.7612,51.9509 40.19215,50 40,48.0491 40.19215,46.17317
 40.7612,44.4443 41.6853,42.92893 42.92893,41.6853 44.4443,40.7612
 46.17317,40.19215 48.0491,40 50,40.19215 51.9509,40.7612 53.82683,41.6853
 55.5557,42.92893 57.07107,148.12357 161.60116))
 11:15:39 +line join=mitre mitre_limit=1.0 side=both|POLYGON((147.65367
 161.7958,160 156.68179,160 50,159.80785 48.0491,159.2388 46.17317,158.3147
 44.4443,157.07107 42.92893,155.5557 41.6853,153.82683 40.7612,151.9509
 40.19215,150 40,148.0491 40.19215,146.17317 40.7612,144.4443
 41.6853,142.92893 42.92893,141.6853 44.4443,140.7612 46.17317,140.19215
 48.0491,140 50,140 125.85786,57.07107 42.92893,55.5557 41.6853,53.82683
 40.7612,51.9509 40.19215,50 40,48.0491 40.19215,46.17317 40.7612,44.4443
 41.6853,42.92893 42.92893,41.6853 44.4443,40.7612 46.17317,40.19215
 48.0491,40 50,40.19215 51.9509,40.7612 53.82683,41.6853 55.5557,42.92893
 57.07107,147.65367 161.7958))
 11:15:39  line side=left|POLYGON((150 50,150 150,50 50,42.92893
 57.07107,142.92893 157.07107,144.4443 158.3147,146.17317 159.2388,148.0491
 159.80785,150 160,151.9509 159.80785,153.82683 159.2388,155.5557
 158.3147,157.07107 157.07107,158.3147 155.5557,159.2388
 153.82683,159.80785 151.9509,160 150,160 50,150 50))
 11:15:39  line side=right|POLYGON((50 50,150 150,150 50,140 50,140
 125.85786,57.07107 42.92893,50 50))
 11:15:39  line side=left join=mitre|POLYGON((150 50,150 150,50 50,42.92893
 57.07107,160 174.14214,160 50,150 50))
 11:15:39  poly quadsegs=2 join=round|POLYGON((-2 0,-2 10,-1.41421
 11.41421,0 12,10 12,11.41421 11.41421,12 10,12 0,11.41421 -1.41421,10 -2,0
 -2,-1.41421 -1.41421,-2 0))
 11:15:39  poly quadsegs=2 join=bevel|POLYGON((-2 0,-2 10,0 12,10 12,12
 10,12 0,10 -2,0 -2,-2 0))
 11:15:39  poly quadsegs=2 join=mitre|POLYGON((-2 -2,-2 12,12 12,12 -2,-2
 -2))
 11:15:39 -poly quadsegs=2 join=mitre mitre_limit=1|POLYGON((-1.82843
 -1,-1.82843 11,-1 11.82843,11 11.82843,11.82843 11,11.82843 -1,11
 -1.82843,-1 -1.82843,-1.82843 -1))
 11:15:39 -poly quadsegs=2 join=miter miter_limit=1|POLYGON((-1.82843
 11:15:39 +poly quadsegs=2 join=mitre mitre_limit=1|POLYGON((-2 -0.82843,-2
 10.82843,-0.82843 12,10.82843 12,12 10.82843,12 -0.82843,10.82843
 -2,-0.82843 -2,-2 -0.82843))
 11:15:39 +poly quadsegs=2 join=miter miter_limit=1|POLYGON((-2 -0.82843,-2
 11:15:39  poly boundary rhr side=left|POLYGON((20 20,10 20,10 50,50 50,50
 10,20 10,20 20),(20 20,40 20,40 40,20 40,20 20))
 11:15:39
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5049>
