[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-163-g58292267f
Wed Jan 12 14:41:35 PST 2022
the project "PostGIS".
       via  58292267f3ae4486202af7030215983c92d921c7 (commit)
       via  738c9488deebcfeeff3a9e92b1e79781252c0a69 (commit)
       via  138207b846b607201c7b65e85a3918d098a299cd (commit)
       via  7697f5996f0d7056a8838098e2f61ab9d0dcecc5 (commit)
       via  e2002f8ce5318214e6db33f0144f56ded4a1ba7d (commit)
      from  f6abd980d7bcc4d6d7934a68dbd9d2acc5acf4f9 (commit)
revisions in full, below.
commit 58292267f3ae4486202af7030215983c92d921c7
Author: robe <regina at arrival3d.com>
Date:   Wed Jan 12 22:26:34 2022 +0000
    Translated using Weblate (Russian)
    Currently translated at 21.8% (19 of 87 strings)
    Translation: postgis/administration.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ru/
diff --git a/doc/po/ru/administration.xml.po b/doc/po/ru/administration.xml.po
index 1ea9319e6..0344edca9 100644
--- a/doc/po/ru/administration.xml.po
+++ b/doc/po/ru/administration.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2022-01-11 22:18+0000\n"
+"PO-Revision-Date: 2022-01-12 22:41+0000\n"
 "Last-Translator: robe <regina at arrival3d.com>\n"
 "Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/"
 "administrationxml/ru/>\n"
@@ -68,19 +68,21 @@ msgstr ""
 #: administration.xml:19
 #, no-c-format
 msgid "If you want to enable offline raster:"
-msgstr ""
+msgstr "Если вы хотите включить автономный растр:"
 #. Tag: programlisting
 #: administration.xml:20
 #, no-c-format
 msgid "POSTGIS_ENABLE_OUTDB_RASTERS=1"
-msgstr ""
+msgstr "POSTGIS_ENABLE_OUTDB_RASTERS=1"
 #. Tag: para
 #: administration.xml:21
 #, no-c-format
 msgid "Any other setting or no setting at all will disable out of db rasters."
 msgstr ""
+"Любая другая настройка или отсутствие настройки вообще отключит растры вне "
+"БД."
 #. Tag: para
 #: administration.xml:22
@@ -89,12 +91,14 @@ msgid ""
 "In order to enable all GDAL drivers available in your GDAL install, set this "
 "environment variable as follows"
 msgstr ""
+"Чтобы включить все драйверы GDAL, доступные в вашей установке GDAL, "
+"установите эту переменную среды следующим образом"
 #: administration.xml:23
 #, no-c-format
 msgid "POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL"
-msgstr ""
+msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL"
 #. Tag: para
 #: administration.xml:24
@@ -103,18 +107,20 @@ msgid ""
 "If you want to only enable specific drivers, set your environment variable "
 "as follows:"
 msgstr ""
+"Если вы хотите включить только определенные драйверы, установите переменную "
+"среды следующим образом:"
 #: administration.xml:25
 #, no-c-format
 msgid "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
-msgstr ""
+msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
 #. Tag: para
 #: administration.xml:27
 #, no-c-format
 msgid "If you are on windows, do not quote the driver list"
-msgstr ""
+msgstr "Если вы на Windows, не цитируйте список драйверов"
 #. Tag: para
 #: administration.xml:29
@@ -126,10 +132,15 @@ msgid ""
 "<replaceable>main</replaceable>/environment</filename> where 10 refers to "
 "version of PostgreSQL and main refers to the cluster."
 msgstr ""
+"Установка переменных среды зависит от ОС. Для PostgreSQL, установленного в "
+"Ubuntu или Debian через apt-postgresql, предпочтительным способом является "
+"редактирование <filename>/etc/postgresql/"
+"<replaceable>10</replaceable>/<replaceable>main</replaceable>/environment</"
+"filename>, где 10 относится к версии PostgreSQL, а main относится к кластеру."
 #. Tag: para
 #: administration.xml:32
-#, no-c-format
+#, fuzzy, no-c-format
 msgid ""
 "On windows, if you are running as a service, you can set via System "
 "variables which for Windows 7 you can get to by right-clicking on Computer-"
@@ -138,6 +149,13 @@ msgid ""
 "clicking <emphasis>Advanced System Settings ->Advanced->Environment "
 "Variables</emphasis> and adding new system variables."
 msgstr ""
+"В Windows, если вы работаете как служба, вы можете установить с помощью "
+"системных переменных, которые для Windows 7 вы можете получить, щелкнув "
+"правой кнопкой мыши «Компьютер-> Свойства» «Дополнительные параметры системы»"
+" или в проводнике, перейдя к <имя_переменной> Панель управления\\Все "
+"Элементы панели управления\\Система</varname>. Затем нажмите "
+"<emphasis>Дополнительные параметры системы ->Дополнительно->Переменные "
+"среды</emphasis> и добавьте новые системные переменные."
 #. Tag: para
 #: administration.xml:34
@@ -146,18 +164,20 @@ msgid ""
 "After you set the environment variables, you'll need to restart your "
 "PostgreSQL service for the changes to take effect."
 msgstr ""
+"После установки переменных среды вам потребуется перезапустить службу "
+"PostgreSQL, чтобы изменения вступили в силу."
 #. Tag: title
 #: administration.xml:39
 #, no-c-format
 msgid "Creating spatial databases"
-msgstr ""
+msgstr "Создание пространственных баз данных"
 #. Tag: title
 #: administration.xml:42
 #, no-c-format
 msgid "Spatially enable database using EXTENSION"
-msgstr ""
+msgstr "Пространственно включить базу данных с помощью EXTENSION"
 #. Tag: para
 #: administration.xml:44
@@ -167,6 +187,9 @@ msgid ""
 "extensions/postgis modules, you can turn a database into a spatial one using "
 "the EXTENSION mechanism."
 msgstr ""
+"Если вы используете PostgreSQL 9.1+ и скомпилировали и установили модули "
+"extensions/postgis, вы можете превратить базу данных в пространственную, "
+"используя механизм EXTENSION."
 #. Tag: para
 #: administration.xml:49
@@ -176,6 +199,9 @@ msgid ""
 "the functions and comments. Raster and topology are packaged as a separate "
 "extension."
 msgstr ""
+"Расширение ядра postgis включает в себя геометрию, географию, "
+"пространственную_справку_sys и все функции и комментарии. Растр и топология "
+"упакованы как отдельные расширения."
 #. Tag: para
 #: administration.xml:55
commit 738c9488deebcfeeff3a9e92b1e79781252c0a69
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jan 12 22:30:18 2022 +0000
    Translated using Weblate (Italian)
    Currently translated at 20.0% (39 of 195 strings)
    Translation: postgis/introduction.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/it/
diff --git a/doc/po/it_IT/introduction.xml.po b/doc/po/it_IT/introduction.xml.po
index 516be625e..67925dd0c 100644
--- a/doc/po/it_IT/introduction.xml.po
+++ b/doc/po/it_IT/introduction.xml.po
@@ -12,15 +12,16 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2022-01-10 13:02+0000\n"
-"PO-Revision-Date: 2018-07-22 02:48+0000\n"
-"Last-Translator: georgersilva <georger.silva at gmail.com>\n"
-"Language-Team: Italian (Italy) (http://www.transifex.com/postgis/postgis/"
-"language/it_IT/)\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"introductionxml/it/>\n"
 "Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 4.10.1\n"
 #. Tag: title
 #: introduction.xml:3
@@ -40,7 +41,7 @@ msgid ""
 msgstr ""
 "PostGIS è un'estensione spaziale per il database relazionale PostgreSQL "
 "creata da Refractions Research Inc. come progetto di ricerca tecnologica sui "
-"database spaziali. Refractions è una societa' di consulenza su GIS e basi di "
+"database spaziali. Refractions è una società di consulenza su GIS e basi di "
 "dati con base a Victoria, in British Columbia, Canada, specializzata "
 "nell'integrazione dei dati e nello sviluppo di software."
@@ -54,7 +55,7 @@ msgid ""
 msgstr ""
 "PostGIS ora è un progetto della OSGeo Foundation ed è sviluppato e "
 "finanziato da molti sviluppatori ed organizzazioni FOSS4G da tutto il mondo "
-"che beneficiano in modo significativo dalla sua funzionalita'."
+"che beneficiano in modo significativo dalla sua funzionalità."
 #. Tag: para
 #: introduction.xml:13
@@ -94,9 +95,9 @@ msgstr ""
 #. Tag: term
 #: introduction.xml:31
-#, no-c-format
 msgid "Raúl Marín Rodríguez"
-msgstr ""
+msgstr "Raúl Marín Rodríguez"
 #. Tag: para
 #: introduction.xml:33
@@ -105,6 +106,9 @@ msgid ""
 "MVT support, Bug fixing, Performance and stability improvements, GitHub "
 "curation, alignment of PostGIS with PostgreSQL releases"
 msgstr ""
+"Supporto di MVT, risoluzione bachi, migliorie nelle performance e nella "
+"stabilità, cura di GitHub, allineamento di PostGIS con i rilasci di "
+"PostgreSQL"
 #. Tag: term
 #: introduction.xml:39
@@ -1266,8 +1270,8 @@ msgid ""
 "successful campaigns out of it."
 msgstr ""
 "PostGIS 2.0.0 è stata la prima release con cui abbiamo tentato questa "
-"strategia. Abbiamo utilizzato <ulink url=\"http://www.pledgebank.com"
-"\">PledgeBank</ulink>, realizzando due campagne di successo."
+"strategia. Abbiamo utilizzato <ulink url=\"http://www.pledgebank.com\""
+">PledgeBank</ulink>, realizzando due campagne di successo."
 #. Tag: para
 #: introduction.xml:364
commit 138207b846b607201c7b65e85a3918d098a299cd
Date:   Wed Jan 12 22:36:06 2022 +0000
    Translated using Weblate (French)
    Currently translated at 15.3% (30 of 195 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/fr/
diff --git a/doc/po/fr/introduction.xml.po b/doc/po/fr/introduction.xml.po
index 959a3c7cb..9412362d3 100644
--- a/doc/po/fr/introduction.xml.po
+++ b/doc/po/fr/introduction.xml.po
@@ -11,15 +11,16 @@ msgstr ""
 "POT-Creation-Date: 2022-01-10 06:28+0000\n"
-"Language-Team: French (http://www.transifex.com/postgis/postgis/language/"
-"fr/)\n"
+"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
+"introductionxml/fr/>\n"
 "Language: fr\n"
-"Plural-Forms: nplurals=2; plural=(n > 1);\n"
+"Plural-Forms: nplurals=2; plural=n > 1;\n"
 #. Tag: title
@@ -86,7 +87,7 @@ msgstr ""
 #, no-c-format
-msgstr ""
 #. Tag: para
commit 7697f5996f0d7056a8838098e2f61ab9d0dcecc5
Date:   Wed Jan 12 22:36:58 2022 +0000
    Currently translated at 72.0% (178 of 247 strings)
    Translation: postgis/installation.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/installationxml/fr/
diff --git a/doc/po/fr/installation.xml.po b/doc/po/fr/installation.xml.po
index 4e571c336..53177ba3e 100644
--- a/doc/po/fr/installation.xml.po
+++ b/doc/po/fr/installation.xml.po
@@ -16,15 +16,16 @@ msgstr ""
-"PO-Revision-Date: 2018-07-22 02:56+0000\n"
-"fr/)\n"
+"installationxml/fr/>\n"
 "Language: fr\n"
 #. Tag: title
 #: installation.xml:3
@@ -272,7 +273,7 @@ msgstr ""
 #: installation.xml:108
 #, no-c-format
 msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis"
-msgstr ""
+msgstr "git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis"
 #. Tag: para
 #: installation.xml:110
commit e2002f8ce5318214e6db33f0144f56ded4a1ba7d
Date:   Wed Jan 12 22:27:00 2022 +0000
    Currently translated at 12.6% (11 of 87 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/it/
diff --git a/doc/po/it_IT/administration.xml.po b/doc/po/it_IT/administration.xml.po
index 5960fb5f1..4a26ee21d 100644
--- a/doc/po/it_IT/administration.xml.po
+++ b/doc/po/it_IT/administration.xml.po
@@ -1,19 +1,21 @@
 # SOME DESCRIPTIVE TITLE.
 # FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
-#, fuzzy
 msgid ""
 msgstr ""
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
-"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
-"Language: \n"
+"administrationxml/it/>\n"
+"Language: it_IT\n"
 #. Tag: title
@@ -40,8 +42,8 @@ msgid ""
 "If you enabled raster support you may want to read below how to properly "
 "configure it."
 msgstr ""
-"Se hai abilitato il supporto per i raster vorrai leggere la prossima "
-"sezione per configurarlo correttamente."
+"Se hai abilitato il supporto per i raster vorrai leggere la prossima sezione "
+"per configurarlo correttamente."
 #. Tag: para
 #: administration.xml:16
@@ -54,15 +56,13 @@ msgid ""
 "For PostGIS 2.2, you can use the more cross-platform approach of setting the "
 "corresponding <xref linkend=\"PostGIS_GUC\"/>."
 msgstr ""
-"A partire da PostGIS 2.1.3, per default sono disabilitati tutti i "
-"raster driver ed il supporto per i raster offline. "
-"Per ri-abilitarli, puoi dare un valore alle seguenti variabili "
-"ambientali (nell'ambiente del server): "
+"A partire da PostGIS 2.1.3, per default sono disabilitati tutti i raster "
+"driver ed il supporto per i raster offline. Per ri-abilitarli, puoi dare un "
+"valore alle seguenti variabili ambientali (nell'ambiente del server): "
 "<varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> e "
-"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname>."
-"A partire da PostGIS 2.2, puoi usare l'approccio più combatibile "
-"tra varie piattaforme usando le <xref linkend=\"PostGIS_GUC\"/> "
-"corrispondenti."
+"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname>.A partire da PostGIS 2.2, "
+"puoi usare l'approccio più combatibile tra varie piattaforme usando le <xref "
+"linkend=\"PostGIS_GUC\"/> corrispondenti."
 #. Tag: para
@@ -81,8 +81,8 @@ msgstr ""
 #, no-c-format
 msgstr ""
-"Qualunque altro valore, o l'assenza di valore, disabilita il "
-"supporto per i raster offline (out-of-db)."
+"Qualunque altro valore, o l'assenza di valore, disabilita il supporto per i "
+"raster offline (out-of-db)."
 #. Tag: para
@@ -131,6 +131,12 @@ msgid ""
 msgstr ""
+"Come settare variabili ambientali dipende dal sistema operativo. Se "
+"postgreSQL è stato installato su Ubuntu o Debian via apt-postgresql, il "
+"metodo preferito è modificare <filename>/etc/postgresql/"
+"filename> dove 10 si riferisce alla versione di PostgreSQL e main si "
+"riferisce al nome del cluster."
 #. Tag: para
@@ -151,6 +157,8 @@ msgid ""
 msgstr ""
+"Dopo aver settato le variabili ambientali, affinché le modifiche abbiano "
+"effetto dovrai far ripartire il servizio PostgreSQL."
 #. Tag: title
Summary of changes:
 doc/po/fr/installation.xml.po      | 13 +++++------
 doc/po/fr/introduction.xml.po      | 13 +++++------
 doc/po/it_IT/administration.xml.po | 42 +++++++++++++++++++++---------------
 doc/po/it_IT/introduction.xml.po   | 26 ++++++++++++----------
 doc/po/ru/administration.xml.po    | 44 ++++++++++++++++++++++++++++++--------
 5 files changed, 89 insertions(+), 49 deletions(-)
hooks/post-receive
