[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-12-gc585d7c0e
git at osgeo.org
git at osgeo.org
Wed Jan 12 21:56:33 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
via c585d7c0ef9c767ae8546285c10cea6e61bb62ee (commit)
from f7c953cd65dc08b55ce37d35ea6cab43419e78c8 (commit)
revisions in full, below.
commit c585d7c0ef9c767ae8546285c10cea6e61bb62ee
Author: Regina Obe <lr at pcorp.us>
Date: Thu Jan 13 00:13:04 2022 -0500
Take out buffer mitre tests
that yield different results between GEOS 3.11 and GEOS < 3.11
Closes #5049 for PostGIS 3.2.1
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index 63a546c51..ba9958611 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -10,14 +10,14 @@ SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_
SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
SELECT 'line quadsegs=2 endcap=square', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=square'), 5);
-SELECT 'line join=mitre mitre_limit=1.0 side=both', ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'join=mitre mitre_limit=1.0 side=both'), 5);
+--SELECT 'line join=mitre mitre_limit=1.0 side=both', ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'join=mitre mitre_limit=1.0 side=both'), 5);
SELECT 'line side=left',ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=left'), 5);
SELECT 'line side=right',ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=right'),5);
SELECT 'line side=left join=mitre',ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=left join=mitre'),5);
SELECT 'poly quadsegs=2 join=round', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=round'), 5);
SELECT 'poly quadsegs=2 join=bevel', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=bevel'), 5);
-SELECT 'poly quadsegs=2 join=mitre', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=mitre'), 5);
-SELECT 'poly quadsegs=2 join=mitre mitre_limit=1', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=mitre mitre_limit=1'), 5);
-SELECT 'poly quadsegs=2 join=miter miter_limit=1', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=miter miter_limit=1'), 5);
+--SELECT 'poly quadsegs=2 join=mitre', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=mitre'), 5);
+--SELECT 'poly quadsegs=2 join=mitre mitre_limit=1', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=mitre mitre_limit=1'), 5);
+--SELECT 'poly quadsegs=2 join=miter miter_limit=1', ST_AsText(st_buffer('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))', 2, 'quad_segs=2 join=miter miter_limit=1'), 5);
SELECT 'poly boundary rhr side=left', ST_AsText(ST_Buffer(ST_ForceRHR(ST_Boundary('POLYGON ((20 20, 20 40, 40 40, 40 40, 40 20, 20 20))')),10,'join=mitre side=left'),5);
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index 28847444e..3a5e50f7a 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -3,13 +3,9 @@ line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414
line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
line quadsegs=2 endcap=square|POLYGON((10 2,12 2,12 -2,0 -2,-2 -2,-2 2,10 2))
-line join=mitre mitre_limit=1.0 side=both|POLYGON((148.12357 161.60116,159.5301 156.87643,160 50,159.80785 48.0491,159.2388 46.17317,158.3147 44.4443,157.07107 42.92893,155.5557 41.6853,153.82683 40.7612,151.9509 40.19215,150 40,148.0491 40.19215,146.17317 40.7612,144.4443 41.6853,142.92893 42.92893,141.6853 44.4443,140.7612 46.17317,140.19215 48.0491,140 50,140 125.85786,57.07107 42.92893,55.5557 41.6853,53.82683 40.7612,51.9509 40.19215,50 40,48.0491 40.19215,46.17317 40.7612,44.4443 41.6853,42.92893 42.92893,41.6853 44.4443,40.7612 46.17317,40.19215 48.0491,40 50,40.19215 51.9509,40.7612 53.82683,41.6853 55.5557,42.92893 57.07107,148.12357 161.60116))
line side=left|POLYGON((150 50,150 150,50 50,42.92893 57.07107,142.92893 157.07107,144.4443 158.3147,146.17317 159.2388,148.0491 159.80785,150 160,151.9509 159.80785,153.82683 159.2388,155.5557 158.3147,157.07107 157.07107,158.3147 155.5557,159.2388 153.82683,159.80785 151.9509,160 150,160 50,150 50))
line side=right|POLYGON((50 50,150 150,150 50,140 50,140 125.85786,57.07107 42.92893,50 50))
line side=left join=mitre|POLYGON((150 50,150 150,50 50,42.92893 57.07107,160 174.14214,160 50,150 50))
poly quadsegs=2 join=round|POLYGON((-2 0,-2 10,-1.41421 11.41421,0 12,10 12,11.41421 11.41421,12 10,12 0,11.41421 -1.41421,10 -2,0 -2,-1.41421 -1.41421,-2 0))
poly quadsegs=2 join=bevel|POLYGON((-2 0,-2 10,0 12,10 12,12 10,12 0,10 -2,0 -2,-2 0))
-poly quadsegs=2 join=mitre|POLYGON((-2 -2,-2 12,12 12,12 -2,-2 -2))
-poly quadsegs=2 join=mitre mitre_limit=1|POLYGON((-1.82843 -1,-1.82843 11,-1 11.82843,11 11.82843,11.82843 11,11.82843 -1,11 -1.82843,-1 -1.82843,-1.82843 -1))
-poly quadsegs=2 join=miter miter_limit=1|POLYGON((-1.82843 -1,-1.82843 11,-1 11.82843,11 11.82843,11.82843 11,11.82843 -1,11 -1.82843,-1 -1.82843,-1.82843 -1))
poly boundary rhr side=left|POLYGON((20 20,10 20,10 50,50 50,50 10,20 10,20 20),(20 20,40 20,40 40,20 40,20 20))
Summary of changes:
regress/core/regress_buffer_params.sql | 8 ++++----
regress/core/regress_buffer_params_expected | 4 ----
2 files changed, 4 insertions(+), 8 deletions(-)
hooks/post-receive
