[postgis-tickets] [PostGIS] #5051: check_all_upgrades step in Dronie is NOT testing topology and raster
PostGIS trac at osgeo.org
Fri Jan 14 03:11:05 PST 2022
 Reporter:  strk       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.3.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 I just found out that the Dronie run for `check_all_upgrades` is not
 running raster and topology tests. I believe this is because the script
 runs `make -C regress/ check` instead of `make check-regress`, which
 should enable topology and raster depending on ./configure settings.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5051>
