[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-231-gb5d1ec457
Fri Jan 14 05:11:01 PST 2022
the project "PostGIS".
       via  b5d1ec4570d759afa61a66bffc396edb84cdfad6 (commit)
       via  bafde33452753a9574d45308098bde0de7741147 (commit)
      from  dd794022afa8924d447702390c6e49c1f52284ca (commit)
revisions in full, below.
commit b5d1ec4570d759afa61a66bffc396edb84cdfad6
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 13 23:57:36 2022 +0100
    Test ugprades in absence of old library (cheating)
    We are cheating because the geometry_out function is
    NOT being pointed to unexisting library, due to a bug
    in our upgrade procedure which *requires* that function
    to work during upgrade.  See #5046
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 5f4678446..2dcddaf4b 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -74,3 +74,13 @@ SELECT
 	ST_DWithin(g1::text, g1::text, 1) as text_dwithin,
 	ST_DWithin(g2, g2, 1) as geography_dwithin
 FROM upgrade_test;
+-- Break probin of all postgis functions, as we expect
+-- the upgrade procedure to replace them all
+UPDATE pg_proc SET probin = probin || '-uninstalled' WHERE probin like '%postgis%'
+-- Some function have DEFAULT values for GEOMETRY type, which
+-- makes pg_get_function_arguments choke. This should be fixed!
+-- See https://trac.osgeo.org/postgis/ticket/5046#comment:5
+-- When ticket #5046 is fixed we can ALSO break geometry_out
+AND proname NOT IN ( 'geometry_out')
commit bafde33452753a9574d45308098bde0de7741147
Date:   Fri Jan 14 11:39:43 2022 +0100
    Run topology and raster --before-upgrade hooks *before* the core ones
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index db11bdd3e..50d0c11ea 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -12,9 +12,10 @@
 override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
-RUNTESTFLAGS_INTERNAL += \
+override RUNTESTFLAGS_INTERNAL := \
   --before-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
-  --after-upgrade-script  $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+  $(RUNTESTFLAGS_INTERNAL) \
+  --after-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
 RASTER_TEST_FIRST = \
 	$(topsrcdir)/raster/test/regress/check_gdal \
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 63cfaf20c..8255316c4 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -12,9 +12,10 @@
 override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
   --before-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-before-upgrade-topology.sql \
-  --after-upgrade-script  $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
+  --after-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
 TESTS += \
   $(topsrcdir)/topology/test/regress/addedge.sql \
Summary of changes:
 raster/test/regress/tests.mk          |  5 +++--
 regress/hooks/hook-before-upgrade.sql | 10 ++++++++++
 topology/test/tests.mk                |  5 +++--
 3 files changed, 16 insertions(+), 4 deletions(-)
hooks/post-receive
