[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-254-g3a3a84df8
git at osgeo.org
git at osgeo.org
Sat Jan 15 09:52:52 PST 2022
the project "PostGIS".
via 3a3a84df865fc111ba35b2e123ae8abde0398f41 (commit)
via f7db3058861cde4c950f346b4cdcefcc0d2fceba (commit)
from f10b31fbc7222e6763bf90248d3f8ca2086997e2 (commit)
revisions in full, below.
commit 3a3a84df865fc111ba35b2e123ae8abde0398f41
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Jan 15 16:30:32 2022 +0100
[dronie] give a summary of upgrade tests
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 2ae83b059..0dae3653c 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -18,5 +18,7 @@ make install
RUNTESTFLAGS=-v make installcheck
CURRENTVERSION=`grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
-utils/check_all_upgrades.sh -s ${CURRENTVERSION}
-utils/check_all_upgrades.sh -s ${CURRENTVERSION}!
+utils/check_all_upgrades.sh -s ${CURRENTVERSION} | tee check.log
+utils/check_all_upgrades.sh -s ${CURRENTVERSION}! | tee -a check.log
+echo "-- Summary of upgrade tests --"
+egrep '(PASS|FAIL)' check.log
commit f7db3058861cde4c950f346b4cdcefcc0d2fceba
Date: Sat Jan 15 15:15:33 2022 +0100
Improve check_all_upgrades.sh
- Report target version when testing upgrades from unpackaged to :auto
- Fix handling all specific-version parameter followed by exclamation mark
- Check availability of unpackaged upgrade file
- Report extension in PASS/FAIL messages
NOTE: this makes dronie really test upgrades via function, which
was NOT really working as of 8c741465d
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index ff8a2b59b..9e49c295d 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -19,6 +19,8 @@ to_version=$to_version_param
if expr $to_version : ':auto' >/dev/null; then
export PGDATABASE=template1
to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
+elif expr $to_version : '.*!$' >/dev/null; then
+ to_version=$(echo "${to_version}" | sed 's/\!$//')
fi
@@ -110,9 +112,9 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
fi
RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
make -C ${REGDIR} check && {
- echo "PASS: upgrade $UPGRADE_PATH"
+ echo "PASS: ${EXT} upgrade $UPGRADE_PATH"
- echo "FAIL: upgrade $UPGRADE_PATH"
+ echo "FAIL: ${EXT} upgrade $UPGRADE_PATH"
failed
else
@@ -123,18 +125,27 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
# Check unpackaged->extension upgrades
for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
+ UPGRADE_FILE="${EXT}--unpackaged--${to_version}.sql"
+ if ! test -e ${UPGRADE_FILE}; then
+ echo "SKIP: ${EXT} upgrade $UPGRADE_FILE is missing"
+ continue
+ fi
# only consider versions older than ${to_version_param}
- cmp=`semver_compare "${majmin}" "${to_version_param}"`
+ cmp=`semver_compare "${majmin}" "${to_version}"`
if test $cmp -ge 0; then
echo "SKIP: upgrade $UPGRADE_PATH ($to_version_param is not newer than $majmin)"
continue
fi
- echo "Testing ${EXT} upgrade $UPGRADE_PATH"
+ if expr $to_version_param : ':auto' >/dev/null; then
+ echo "Testing ${EXT} upgrade $UPGRADE_PATH ($to_version)"
+ else
+ echo "Testing ${EXT} upgrade $UPGRADE_PATH"
+ fi
failed
done
Summary of changes:
ci/dronie/postgis_regress.sh | 6 ++++--
utils/check_all_upgrades.sh | 23 +++++++++++++++++------
2 files changed, 21 insertions(+), 8 deletions(-)
hooks/post-receive
