[postgis-tickets] [PostGIS] #5046: Old postgis library needed to upgrade
trac at osgeo.org
Sat Jan 15 10:56:25 PST 2022
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.1
Component: build/upgrade/install | Version: 3.2.x
Resolution: | Keywords:
Comment (by strk):
I now pushed a branch in which we ALSO break the `geometry_out` function,
so to have a confirmation of this bug. The bug is confirmed by:
- Dronie: https://dronie.osgeo.org/postgis/postgis/2426/1/2
- GitLab-CI: https://gitlab.com/postgis/postgis/-/jobs/1979025558#L15207
GitLab actions are NOT testing upgrades, so won't catch this.
Debbie and friends I'm not sure they kick for non standard branchs
(Regina?)
What I think we could test in that branch is if rewriting the
_postgis_drop_if_needed function can help (we'd basically need a way to
find argument names without evaluating default values, although we MIGHT
want to change default values in the future ?).
In general, it would probably be more robust if the defaults would always
be NULL, although I do understand that means removing the STRICT and
handling it at the library level...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5046#comment:13>
