[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-259-g6d2d12c14
git at osgeo.org
git at osgeo.org
Sun Jan 16 13:27:13 PST 2022
the project "PostGIS".
via 6d2d12c1441a0a9157c0824dae11271cb0b646ec (commit)
via 6a802d8c4fb4b9eeab71703f7d7063a5bde6629a (commit)
from 4c3c8e37839127b67dc3f0cf08f67cddc7441d89 (commit)
revisions in full, below.
commit 6d2d12c1441a0a9157c0824dae11271cb0b646ec
Author: Sandro Santilli <strk at kbt.io>
Date: Sun Jan 16 22:15:08 2022 +0100
run_test.pl: fail immediately if upgrade of any component fails
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 5322e5e95..9810a81d7 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1538,62 +1538,29 @@ sub upgrade_spatial
print "Upgrading PostGIS in '${DB}' \n" ;
- my $script = `ls ${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading core\n";
- load_sql_file($script);
- else
- die "$script not found\n";
+ my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
+ print "Upgrading core\n";
+ die unless load_sql_file($script, 1);
if ( $OPT_WITH_TOPO )
- my $script = `ls ${STAGED_SCRIPTS_DIR}/topology_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading topology\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
+ print "Upgrading topology\n";
if ( $OPT_WITH_RASTER )
- my $script = `ls ${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading raster\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
+ print "Upgrading raster\n";
if ( $OPT_WITH_SFCGAL )
- my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading sfcgal\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
+ print "Upgrading sfcgal\n";
return 1;
commit 6a802d8c4fb4b9eeab71703f7d7063a5bde6629a
Date: Sun Jan 16 21:52:25 2022 +0100
Include internal RUNTESTFLAGS when testing upgrades
Fixes #5054
diff --git a/regress/runtest.mk b/regress/runtest.mk
index 382c25d2a..bfad91b7e 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -16,6 +16,7 @@ check-regress:
$(PERL) $(topsrcdir)/regress/run_test.pl \
--upgrade \
$(RUNTESTFLAGS) \
+ $(RUNTESTFLAGS_INTERNAL) \
$(TESTS); \
else \
echo "Skipping upgrade test as RUNTESTFLAGS already requested upgrades"; \
Summary of changes:
regress/run_test.pl | 57 +++++++++++------------------------------------------
regress/runtest.mk | 1 +
2 files changed, 13 insertions(+), 45 deletions(-)
hooks/post-receive
