[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-260-g9b186c4d3
git at osgeo.org
git at osgeo.org
Sun Jan 16 13:49:20 PST 2022
the project "PostGIS".
via 9b186c4d3d23029f7164c54c9c6add440987cf3b (commit)
from 6d2d12c1441a0a9157c0824dae11271cb0b646ec (commit)
revisions in full, below.
commit 9b186c4d3d23029f7164c54c9c6add440987cf3b
Author: Sandro Santilli <strk at kbt.io>
Date: Sun Jan 16 22:48:57 2022 +0100
run_test.pl: include upgrade errors when in verbose mode
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 9810a81d7..a286540bb 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -309,22 +309,24 @@ if ( $OPT_UPGRADE )
foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
print "Running before-upgrade-script $hook\n";
- die unless load_sql_file($hook, 1);
+ fail("before-upgrade-script $hook", $REGRESS_LOG)
+ unless load_sql_file($hook, 1);
- if ( $OPT_EXTENSIONS )
- upgrade_spatial_extensions();
- else
- upgrade_spatial();
+ if ( $OPT_EXTENSIONS )
+ upgrade_spatial_extensions();
+ else
+ upgrade_spatial();
foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
print "Running after-upgrade-script $hook\n";
+ fail("after-upgrade-script $hook", $REGRESS_LOG)
# Update libver
@@ -1540,27 +1542,31 @@ sub upgrade_spatial
my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
print "Upgrading core\n";
- die unless load_sql_file($script, 1);
+ fail('core upgrading', $REGRESS_LOG)
+ unless load_sql_file($script, 1);
if ( $OPT_WITH_TOPO )
$script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
print "Upgrading topology\n";
+ fail('topology upgrade', $REGRESS_LOG)
if ( $OPT_WITH_RASTER )
$script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
print "Upgrading raster\n";
+ fail('raster upgrade', $REGRESS_LOG)
if ( $OPT_WITH_SFCGAL )
$script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
print "Upgrading sfcgal\n";
+ fail('sfcgal upgrade', $REGRESS_LOG)
return 1;
Summary of changes:
regress/run_test.pl | 34 ++++++++++++++++++++--------------
1 file changed, 20 insertions(+), 14 deletions(-)
hooks/post-receive
