[postgis-tickets] [SCM] PostGIS branch fix-upgrades-in-absence-of-old-library updated. 3.2.0-264-g8b934e52f
Sun Jan 16 14:04:04 PST 2022
the project "PostGIS".
The branch, fix-upgrades-in-absence-of-old-library has been updated
       via  8b934e52f7ba3e4d6d7244729fa01500f94683cc (commit)
       via  23321285607bc08fc50ea02d5f57af2270f91116 (commit)
       via  d026a315be25329e3956e8eda81dd2fe3d080d0c (commit)
      from  c2804639e68ff446f8e049ee67a611be638d1b64 (commit)
revisions in full, below.
commit 8b934e52f7ba3e4d6d7244729fa01500f94683cc
Merge: d026a315b 233212856
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Jan 16 23:03:55 2022 +0100
    Merge branch 'main' into fix-upgrades-in-absence-of-old-library
commit d026a315be25329e3956e8eda81dd2fe3d080d0c
Date:   Sun Jan 16 23:00:35 2022 +0100
    Revert "run_test.pl: include upgrade errors when in verbose mode"
    This reverts commit 9b186c4d3d23029f7164c54c9c6add440987cf3b.
diff --git a/regress/run_test.pl b/regress/run_test.pl
index a286540bb..9810a81d7 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -309,24 +309,22 @@ if ( $OPT_UPGRADE )
 	foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
 		print "Running before-upgrade-script $hook\n";
-		fail("before-upgrade-script $hook", $REGRESS_LOG)
-		    unless load_sql_file($hook, 1);
+		die unless load_sql_file($hook, 1);
-	if ( $OPT_EXTENSIONS )
-		upgrade_spatial_extensions();
-	else
-		upgrade_spatial();
+  if ( $OPT_EXTENSIONS )
+    upgrade_spatial_extensions();
+  else
+	  upgrade_spatial();
 	foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
 		print "Running after-upgrade-script $hook\n";
-		fail("after-upgrade-script $hook", $REGRESS_LOG)
   # Update libver
@@ -1542,31 +1540,27 @@ sub upgrade_spatial
     my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
     print "Upgrading core\n";
-    fail('core upgrading', $REGRESS_LOG)
-        unless load_sql_file($script, 1);
+    die unless load_sql_file($script, 1);
     if ( $OPT_WITH_TOPO )
         $script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
         print "Upgrading topology\n";
-        fail('topology upgrade', $REGRESS_LOG)
     if ( $OPT_WITH_RASTER )
         $script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
         print "Upgrading raster\n";
-        fail('raster upgrade', $REGRESS_LOG)
     if ( $OPT_WITH_SFCGAL )
         $script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
         print "Upgrading sfcgal\n";
-        fail('sfcgal upgrade', $REGRESS_LOG)
     return 1;
Summary of changes:
 regress/run_test.pl | 34 ++++++++++++++--------------------
 1 file changed, 14 insertions(+), 20 deletions(-)
hooks/post-receive
