[postgis-tickets] [SCM] PostGIS branch fix-upgrades-in-absence-of-old-library updated. 3.2.0-265-g569cac9c2
git at osgeo.org
git at osgeo.org
Mon Jan 17 05:43:18 PST 2022
the project "PostGIS".
The branch, fix-upgrades-in-absence-of-old-library has been updated
discards 89f1585e106df95ec18f87d8a84b7f946e562606 (commit)
via 569cac9c22186830958e3fd09e163922430dd14a (commit)
This update added new revisions after undoing existing revisions. That is
to say, the old revision is not a strict subset of the new revision. This
situation occurs when you --force push a change and generate a repository
containing something like this:
* -- * -- B -- O -- O -- O (89f1585e106df95ec18f87d8a84b7f946e562606)
N -- N -- N (569cac9c22186830958e3fd09e163922430dd14a)
When this happens we assume that you've already had alert emails for all
of the O revisions, and so we here report only the revisions in the N
branch from the common base, B.
revisions in full, below.
commit 569cac9c22186830958e3fd09e163922430dd14a
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 17 14:27:59 2022 +0100
Rewrite _postgis_drop_if_needed to avoid expanding DEFAULT values
Should fix 5046
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index ea84c524f..437476be0 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -37,34 +37,29 @@ CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
function_name text,
function_arguments text) RETURNS void AS $$
DECLARE
- frec RECORD;
sql_drop text;
+ postgis_namespace OID;
+ matching_function REGPROCEDURE;
BEGIN
- FOR frec IN
- SELECT p.oid as oid,
- n.nspname as schema,
- n.oid as schema_oid,
- p.proname as name,
- pg_catalog.pg_get_function_arguments(p.oid) as arguments,
- pg_catalog.pg_get_function_identity_arguments(p.oid) as identity_arguments
- FROM pg_catalog.pg_proc p
- LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
- WHERE
- n.oid = (
- SELECT n.oid
- FROM pg_proc p
- JOIN pg_namespace n ON p.pronamespace = n.oid
- WHERE proname = 'postgis_full_version'
- ) AND
- LOWER(p.proname) = LOWER(function_name) AND
- LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~ LOWER(function_arguments) AND
- pg_catalog.pg_function_is_visible(p.oid)
- ORDER BY 1, 2, 4
- LOOP
- sql_drop := 'DROP FUNCTION ' || quote_ident(frec.schema) || '.' || quote_ident(frec.name) || ' ( ' || frec.identity_arguments || ' ) ';
- RAISE DEBUG 'Name (%): %', frec.oid, frec.name;
- RAISE DEBUG 'Arguments: %', frec.arguments;
- RAISE DEBUG 'Identity arguments: %', frec.identity_arguments;
+ -- Fetch install namespace for PostGIS
+ SELECT n.oid
+ FROM pg_catalog.pg_proc p
+ JOIN pg_catalog.pg_namespace n ON p.pronamespace = n.oid
+ WHERE proname = 'postgis_full_version'
+ INTO postgis_namespace;
+ -- Find a function matching the given signature
+ SELECT oid
+ WHERE pronamespace = postgis_namespace
+ AND LOWER(p.proname) = LOWER(function_name)
+ AND pg_catalog.pg_function_is_visible(p.oid)
+ AND LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ LOWER(function_arguments)
+ INTO matching_function;
+ IF matching_function IS NOT NULL THEN
+ sql_drop := 'DROP FUNCTION ' || matching_function;
RAISE DEBUG 'SQL query: %', sql_drop;
BEGIN
EXECUTE sql_drop;
@@ -72,7 +67,8 @@ BEGIN
WHEN OTHERS THEN
RAISE EXCEPTION 'Could not drop function %. You might need to drop dependant objects. Postgres error: %', function_name, SQLERRM;
END;
- END LOOP;
+ END IF;
END;
$$ LANGUAGE plpgsql;
Summary of changes:
postgis/postgis_before_upgrade.sql | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
