[postgis-tickets] [PostGIS] #5046: Old postgis library needed to upgrade
trac at osgeo.org
Mon Jan 17 06:12:40 PST 2022
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.5
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"ab601a09099e12f2763e0f27a86134f9d644fdb2/git" ab601a0/git]:
#!CommitTicketReference repository="git"
revision="ab601a09099e12f2763e0f27a86134f9d644fdb2"
Rewrite _postgis_drop_if_needed to avoid expanding DEFAULT values
This prevents the function to fail when geometry canonical output
function is non-functional (maybe due to lack of library on system).
References #5046 in 3.2 branch (3.2.1dev)
Includes test ugprades in absence of old library
Includes NEWS item
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5046#comment:17>
