[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.4-4-g4cb6c8952
git at osgeo.org
git at osgeo.org
Mon Jan 17 06:40:52 PST 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
via 4cb6c89523885bc0eaa0ac94a8e96d8715c0f6a9 (commit)
from 4e1e532fd15b1153937c787fa1dcec6913c2d9d2 (commit)
revisions in full, below.
commit 4cb6c89523885bc0eaa0ac94a8e96d8715c0f6a9
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 13 23:57:36 2022 +0100
Rewrite _postgis_drop_if_needed to avoid expanding DEFAULT values
This prevents the function to fail when geometry canonical output
function is non-functional (maybe due to lack of library on system).
Closes #5046 in 3.0 branch (3.0.5dev)
Includes NEWS item
Include ugprades tests in absence of old library
diff --git a/NEWS b/NEWS
index f827b16ad..0cd4cd777 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ PostGIS 3.0.5
* Bug Fixes and Enhancements *
- #5026, fix DropTopology in presence of UPDATE triggers on
topology layers (Sandro Santilli)
+ - #5046, Fix upgrades in absence of old library (Sandro Santilli)
PostGIS 3.0.4
2021/09/04
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 02ff21306..0e841e40e 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -37,34 +37,29 @@ CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
function_name text,
function_arguments text) RETURNS void AS $$
DECLARE
- frec RECORD;
sql_drop text;
+ postgis_namespace OID;
+ matching_function REGPROCEDURE;
BEGIN
- FOR frec IN
- SELECT p.oid as oid,
- n.nspname as schema,
- n.oid as schema_oid,
- p.proname as name,
- pg_catalog.pg_get_function_arguments(p.oid) as arguments,
- pg_catalog.pg_get_function_identity_arguments(p.oid) as identity_arguments
- FROM pg_catalog.pg_proc p
- LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
- WHERE
- n.oid = (
- SELECT n.oid
- FROM pg_proc p
- JOIN pg_namespace n ON p.pronamespace = n.oid
- WHERE proname = 'postgis_full_version'
- ) AND
- LOWER(p.proname) = LOWER(function_name) AND
- LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~ LOWER(function_arguments) AND
- pg_catalog.pg_function_is_visible(p.oid)
- ORDER BY 1, 2, 4
- LOOP
- sql_drop := 'DROP FUNCTION ' || quote_ident(frec.schema) || '.' || quote_ident(frec.name) || ' ( ' || frec.identity_arguments || ' ) ';
- RAISE DEBUG 'Name (%): %', frec.oid, frec.name;
- RAISE DEBUG 'Arguments: %', frec.arguments;
- RAISE DEBUG 'Identity arguments: %', frec.identity_arguments;
+ -- Fetch install namespace for PostGIS
+ SELECT n.oid
+ FROM pg_catalog.pg_proc p
+ JOIN pg_catalog.pg_namespace n ON p.pronamespace = n.oid
+ WHERE proname = 'postgis_full_version'
+ INTO postgis_namespace;
+ -- Find a function matching the given signature
+ SELECT oid
+ WHERE pronamespace = postgis_namespace
+ AND LOWER(p.proname) = LOWER(function_name)
+ AND pg_catalog.pg_function_is_visible(p.oid)
+ AND LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ LOWER(function_arguments)
+ INTO matching_function;
+ IF matching_function IS NOT NULL THEN
+ sql_drop := 'DROP FUNCTION ' || matching_function;
RAISE DEBUG 'SQL query: %', sql_drop;
BEGIN
EXECUTE sql_drop;
@@ -72,7 +67,8 @@ BEGIN
WHEN OTHERS THEN
RAISE EXCEPTION 'Could not drop function %. You might need to drop dependant objects. Postgres error: %', function_name, SQLERRM;
END;
- END LOOP;
+ END IF;
END;
$$ LANGUAGE plpgsql;
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 8f32e5b79..bc2b1284e 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -350,6 +350,15 @@ sub create_upgrade_test_objects
exit(1);
+ # Break current binary postgis functions
+ $query = "UPDATE pg_proc SET probin = probin || '-uninstalled' WHERE probin like '%postgis%'";
+ my $ret = sql($query);
+ unless ( $ret =~ /^UPDATE/ ) {
+ `dropdb $DB`;
+ print "\nSomething went wrong breaking postgis funx probin: $ret.\n";
+ exit(1);
sub drop_upgrade_test_objects
Summary of changes:
NEWS | 1 +
postgis/postgis_before_upgrade.sql | 50 ++++++++++++++++++--------------------
regress/run_test.pl | 9 +++++++
3 files changed, 33 insertions(+), 27 deletions(-)
hooks/post-receive
