[postgis-tickets] [PostGIS] #5046: Old postgis library needed to upgrade
trac at osgeo.org
Mon Jan 17 06:40:54 PST 2022
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.5
Component: build/upgrade/install | Version: 3.0.x
Resolution: fixed | Keywords:
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"4cb6c89523885bc0eaa0ac94a8e96d8715c0f6a9/git" 4cb6c89/git]:
#!CommitTicketReference repository="git"
revision="4cb6c89523885bc0eaa0ac94a8e96d8715c0f6a9"
Rewrite _postgis_drop_if_needed to avoid expanding DEFAULT values
This prevents the function to fail when geometry canonical output
function is non-functional (maybe due to lack of library on system).
Closes #5046 in 3.0 branch (3.0.5dev)
Includes NEWS item
Include ugprades tests in absence of old library
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5046#comment:19>
