[postgis-tickets] [SCM] PostGIS branch 3.2-no-default-in-drop-if-needed-signature created. 3.2.0-18-ge78c543b5
Mon Jan 17 07:26:14 PST 2022
the project "PostGIS".
The branch, 3.2-no-default-in-drop-if-needed-signature has been created
        at  e78c543b5e48a007e9a5ec9d85f399c42c4898e5 (commit)
commit e78c543b5e48a007e9a5ec9d85f399c42c4898e5
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 17 16:25:30 2022 +0100
    Do not include default value in _postgis_drop_if_needed calls
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 437476be0..d02bdc42e 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -164,7 +164,7 @@ SELECT _postgis_drop_function_if_needed
 	'ST_AsGeoJson',
-	$args$r record, geom_column text DEFAULT ''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean DEFAULT false$args$
+	$args$r record, geom_column text, maxdecimaldigits integer, pretty_print boolean$args$
 -- FUNCTION _st_orderingequals changed argument names in 3.0
@@ -187,7 +187,7 @@ SELECT _postgis_drop_function_if_needed
     'st_tileenvelope',
-    'zoom integer, x integer, y integer, bounds geometry DEFAULT ''0102000020110F00000200000052107C45F81B73C152107C45F81B73C152107C45F81B734152107C45F81B7341''::geometry'
+    'zoom integer, x integer, y integer, bounds geometry'
hooks/post-receive
