[postgis-tickets] [SCM] PostGIS branch 3.0-no-default-in-drop-if-needed-signature created. 3.0.4-5-g6287b0999
git at osgeo.org
git at osgeo.org
Mon Jan 17 07:27:46 PST 2022
the project "PostGIS".
The branch, 3.0-no-default-in-drop-if-needed-signature has been created
at 6287b09999f5f033ea8d3257b402fa69e47a3730 (commit)
commit 6287b09999f5f033ea8d3257b402fa69e47a3730
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 17 16:25:30 2022 +0100
Do not include default value in _postgis_drop_if_needed calls
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 0e841e40e..5fdadad54 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -164,7 +164,7 @@ SELECT _postgis_drop_function_if_needed
'ST_AsGeoJson',
- $args$r record, geom_column text DEFAULT ''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean DEFAULT false$args$
+ $args$r record, geom_column text, maxdecimaldigits integer, pretty_print boolean$args$
-- FUNCTION _st_orderingequals changed argument names in 3.0
@@ -183,7 +183,6 @@ SELECT _postgis_drop_function_if_needed
'GeometryA geometry, GeometryB geometry'
-- FUNCTION st_askml changed to add defaults in 3.0 / r17357
-- These signatures were superseeded
DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- Does not conflict
hooks/post-receive
