[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-275-g0c66acf10
Tue Jan 18 13:47:39 PST 2022
the project "PostGIS".
       via  0c66acf102dcde625c89576a02c88dacec29564c (commit)
       via  7ff006334eecda685974ad53e91b7d970648c7c4 (commit)
       via  16d5895aad3605c4ecaa2f0f51f95fa7efaa2e95 (commit)
       via  bb3c81d493ce9293dfc84cb033b5db47236dd502 (commit)
       via  63470972dc833f6cb7ea4e5f8b79bae3a9c25a3d (commit)
       via  742193de400f8cb504d4a091dd27c148becb4604 (commit)
      from  081b7bd514202da6dc7842263fa1aa0718e8d0ed (commit)
revisions in full, below.
commit 0c66acf102dcde625c89576a02c88dacec29564c
Author: Regina Obe <regina at arrival3d.com>
Date:   Mon Jan 17 23:11:24 2022 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (3 of 3 strings)
    Translation: postgis/extras.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extrasxml/ja/
diff --git a/doc/po/ja/extras.xml.po b/doc/po/ja/extras.xml.po
index 0cafd1e98..596519f3b 100644
--- a/doc/po/ja/extras.xml.po
+++ b/doc/po/ja/extras.xml.po
@@ -7,15 +7,16 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2016-01-20 02:09+0000\n"
-"Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/"
-"ja/)\n"
+"PO-Revision-Date: 2022-01-18 14:46+0000\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"extrasxml/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.10.1\n"
 #. Tag: title
 #: extras.xml:3
@@ -25,23 +26,21 @@ msgstr "PostGIS追加機能"
 #. Tag: para
 #: extras.xml:5
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "This chapter documents features found in the extras folder of the PostGIS "
 "source tarballs and source repository. These are not always packaged with "
 "PostGIS binary releases, but are usually PL/pgSQL based or standard shell "
 "scripts that can be run as is."
 msgstr ""
-"本章では、PostGISのソースアーカイブとソースレポジトリのextrasフォルダにある機"
-"能を記述します。 これらは必ずPostGISバイナリ版に同梱されているものではありま"
-"せんが、通常は実行可能なplpgsqlベースのものまたは標準的なシェルスクリプトで"
-"す。"
+"本章では、PostGISのソースアーカイブとソースレポジトリのextrasフォルダにある機能を記述します。 "
+"これらは必ずPostGISバイナリ版に同梱されているものではありませんが、通常は実行可能なplpgsqlベースのものまたは標準的なシェルスクリプトです。"
 #. Tag: chapter
 #: extras.xml:6
 #, no-c-format
 msgid "&extras_address_standardizer; &extras_tigergeocoder;"
-msgstr ""
+msgstr "&extras_address_standardizer; &extras_tigergeocoder;"
 #, no-c-format
 #~ msgid "&extras_tigergeocoder;"
commit 7ff006334eecda685974ad53e91b7d970648c7c4
Date:   Mon Jan 17 23:12:07 2022 +0000
    Translated using Weblate (German)
    Currently translated at 66.6% (2 of 3 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extrasxml/de/
diff --git a/doc/po/de/extras.xml.po b/doc/po/de/extras.xml.po
index 62fbe4662..3aa241652 100644
--- a/doc/po/de/extras.xml.po
+++ b/doc/po/de/extras.xml.po
@@ -7,25 +7,26 @@ msgstr ""
-"PO-Revision-Date: 2019-03-11 09:07+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
-"Language-Team: German (http://www.transifex.com/postgis/postgis/language/"
-"de/)\n"
+"Language-Team: German <https://weblate.osgeo.org/projects/postgis/extrasxml/"
+"de/>\n"
 "Language: de\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
 #. Tag: title
 #: extras.xml:3
 #, no-c-format
 msgid "PostGIS Extras"
-msgstr "PostGIS Extras"
+msgstr ""
 #. Tag: para
 #: extras.xml:5
+#, no-c-format
 msgid ""
@@ -42,7 +43,7 @@ msgstr ""
 #: extras.xml:6
 #, no-c-format
-msgstr ""
 #, no-c-format
commit 16d5895aad3605c4ecaa2f0f51f95fa7efaa2e95
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Jan 18 05:52:13 2022 +0000
    Currently translated at 64.3% (56 of 87 strings)
    Translation: postgis/administration.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ja/
diff --git a/doc/po/ja/administration.xml.po b/doc/po/ja/administration.xml.po
index 2565971ca..46c248216 100644
--- a/doc/po/ja/administration.xml.po
+++ b/doc/po/ja/administration.xml.po
@@ -7,7 +7,7 @@ msgstr ""
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "administrationxml/ja/>\n"
 "Language: ja\n"
@@ -209,7 +209,7 @@ msgstr ""
 #: administration.xml:63
 #, no-c-format
 msgid "Spatially enable database without using EXTENSION (discouraged)"
-msgstr ""
+msgstr "エクステンションを使わずに空間データベースを有効にする (お勧めできません)"
 #. Tag: para
 #: administration.xml:65
@@ -219,6 +219,8 @@ msgid ""
 "installed in the PostgreSQL extension directory (for example during testing, "
 "development or in a restricted environment)."
 msgstr ""
+"これは、通常はPostgreSQLのエクステンションのディレクトリ内にPostGISをインストールできないか、したくない場合 "
+"(たとえばテスト中や開発中、または制限のある環境内)にのみ必要となります。"
 #. Tag: para
 #: administration.xml:70
@@ -228,6 +230,8 @@ msgid ""
 "by loading the various sql files located in <filename>[prefix]/share/"
 "contrib</filename> as specified during the build phase."
 msgstr ""
+"ビルドの際に指定した<filename>[prefix]/share/"
+"contrib</filename>内にある様々なSQLファイルをロードしてPostGISオブジェクトと関数の定義をデータベースに追加します。"
 #. Tag: para
 #: administration.xml:77
@@ -238,6 +242,10 @@ msgid ""
 "objects are in the <filename>rtpostgis.sql</filename> script. Topology "
 "objects are in the <filename>topology.sql</filename> script."
 msgstr ""
+"中核のPostGISオブジェクト (ジオメトリ型とジオグラフィ型、これらに対応する関数)は<filename>postgis."
+"sql</filename>スクリプトにあります。ラスタオブジェクトは<filename>rtpostgis."
+"sql</filename>スクリプトにあります。トポロジオブジェクトは<filename>topology."
+"sql</filename>スクリプトにあります。"
 #. Tag: para
 #: administration.xml:85
@@ -248,6 +256,9 @@ msgid ""
 "populate the <varname>spatial_ref_sys</varname> table. This will permit you "
 "to perform ST_Transform() operations on geometries."
 msgstr ""
+"完全なEPSG座標系定義IDセットについては、<filename>spatial_ref_sys.sql</filename>定義ファイルをロードして<v"
+"arname>spatial_ref_sys</varname>テーブルを生成して下さい。これによりジオメトリ関数ST_Transform()が実行できる"
+"ようになります。"
 #. Tag: para
 #: administration.xml:92
@@ -258,12 +269,15 @@ msgid ""
 "by simply typing <command>\\dd [function_name]</command> from a "
 "<command>psql</command> terminal window."
 msgstr ""
+"PostGIS関数にコメントを追加したい場合には、<filename>postgis_comments.sql</filename>スクリプト内のコメント"
+"が見つかると思います。コメントは<command>psql</command>のターミナルウィンドウから単に<command>\\dd "
+"[関数名]</command>と打ち込むだけで見ることができます。"
 #. Tag: para
 #: administration.xml:99
 #, no-c-format
 msgid "Run the following Shell commands in your terminal:"
-msgstr ""
+msgstr "ターミナルで次のシェルコマンドを実行します。"
 #. Tag: programlisting
 #: administration.xml:101
@@ -285,12 +299,27 @@ msgid ""
 "    psql -d ${DB} -f ${SCRIPTSDIR}/topology.sql\n"
 "    psql -d ${DB} -f ${SCRIPTSDIR}/topology_comments.sql # OPTIONAL"
 msgstr ""
+"DB=[データベース名]\n"
+"    SCRIPTSDIR=`pg_config --sharedir`/contrib/postgis-3.1/\n"
+"\n"
+"    # 中核\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/postgis.sql\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/spatial_ref_sys.sql\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/postgis_comments.sql # 任意\n"
+"\n"
+"    # ラスタ機能 (任意)\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/rtpostgis.sql\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/raster_comments.sql # 任意\n"
+"\n"
+"    # トポロジ機能 (任意)\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/topology.sql\n"
+"    psql -d ${DB} -f ${SCRIPTSDIR}/topology_comments.sql # 任意"
 #. Tag: title
 #: administration.xml:107
 #, no-c-format
 msgid "Create a spatially-enabled database from a template"
-msgstr ""
+msgstr "空間データベースをテンプレートから生成する"
 #. Tag: para
 #: administration.xml:109
@@ -305,36 +334,40 @@ msgid ""
 "the database user must have been granted the privilege to create new "
 "databases."
 msgstr ""
+"PostGISのディストリビューション (特にPostGIS >= 1.1.5のWin32インストーラ)の中には、<varname>template"
+"_postgis</varname>というテンプレートにPostGIS関数をロードしていることがあります。PostgreSQLに<varname>temp"
+"late_postgis</varname>データベースが存在するなら、ユーザやアプリケーションは、空間データベースの生成をコマンドひとつで済ませられます"
+"。この2種類のやり方のどちらを使うににしても、データベースユーザは、新しいデータベースを作成する権限を与えられている必要があります。"
 #. Tag: para
 #: administration.xml:120
 #, no-c-format
 msgid "From the shell:"
-msgstr ""
+msgstr "シェルからの実行は次の通りです。"
 #: administration.xml:124
-#, no-c-format
+#, fuzzy, no-c-format
 msgid "# createdb -T template_postgis my_spatial_db"
-msgstr ""
+msgstr "# createdb -T template_postgis my_spatial_db"
 #. Tag: para
 #: administration.xml:126
 #, no-c-format
 msgid "From SQL:"
-msgstr ""
+msgstr "SQLからの実行は次の通りです。"
 #: administration.xml:130
-#, no-c-format
 msgid "postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis"
-msgstr ""
+msgstr "postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis"
 #. Tag: title
 #: administration.xml:136
 #, no-c-format
 msgid "Upgrading spatial databases"
-msgstr ""
+msgstr "空間データベースのアップグレード"
 #. Tag: para
 #: administration.xml:138
@@ -342,7 +375,7 @@ msgstr ""
 msgid ""
 "Upgrading existing spatial databases can be tricky as it requires "
 "replacement or introduction of new PostGIS object definitions."
-msgstr ""
+msgstr "既存の空間データベースのアップグレードは、新しいPostGISオブジェクト定義の置き換えや導入を必要とするとき、慎重を要することがあります。"
 #. Tag: para
 #: administration.xml:143
@@ -350,7 +383,7 @@ msgstr ""
 msgid ""
 "Unfortunately not all definitions can be easily replaced in a live database, "
 "so sometimes your best bet is a dump/reload process."
-msgstr ""
+msgstr "不幸なことに、定義の全てが実行中のデータベース内で簡単には置き換えられるわけではないので、ダンプ/リロードが最善策となることがあります。"
 #. Tag: para
 #: administration.xml:148
@@ -359,6 +392,8 @@ msgid ""
 "PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases, and "
 "a HARD UPGRADE procedure for major releases."
 msgstr ""
+"PostGISには、マイナーバージョンアップやバグフィクスリリースの場合に使うソフトアップグレードと、メジャーアップグレードで使うハードアップグレードが用"
+"意されています。"
 #. Tag: para
 #: administration.xml:153
@@ -368,12 +403,14 @@ msgid ""
 "data. If you use the -Fc flag to pg_dump you will always be able to restore "
 "the dump with a HARD UPGRADE."
 msgstr ""
+"PostGISをアップグレードしようとする前にデータのバックアップを取ることは、常に価値のあるものです。pg_dumpで -Fc "
+"フラグを使うと、ハードアップグレードによってダンプを常にリストアすることができます。"
 #. Tag: title
 #: administration.xml:160
 #, no-c-format
 msgid "Soft upgrade"
-msgstr ""
+msgstr "ソフトアップグレード"
 #. Tag: para
 #: administration.xml:162
@@ -384,12 +421,14 @@ msgid ""
 "way, then you should upgrade using the sql script way. Please refer to the "
 "appropriate."
 msgstr ""
+"エクステンションを使ってインストールした場合は、エクステンションモデルでアップグレードしなければなりません。 "
+"古いSQLスクリプトを使ってインストールした場合は、SQLスクリプトでアップグレードすべきです。適切な方を参照して下さい。"
 #. Tag: title
 #: administration.xml:166
 #, no-c-format
 msgid "Soft Upgrade Pre 9.1+ or without extensions"
-msgstr ""
+msgstr "9.1より前またはエクステンションを使わないソフトアップグレード"
 #. Tag: para
 #: administration.xml:168
@@ -399,12 +438,13 @@ msgid ""
 "extensions. If you have extensions and try to upgrade with this approach "
 "you'll get messages like:"
 msgstr ""
+"PostGISをエクステンションを使わずにインストールした人向けです。エクステンションを使っていてこの方法を使うと、次のようなメッセージが現れます。"
 #: administration.xml:172
-#, no-c-format
 msgid "can't drop ... because postgis extension depends on it"
-msgstr ""
+msgstr "can't drop ... because postgis extension depends on it"
 #. Tag: para
 #: administration.xml:174
@@ -414,6 +454,8 @@ msgid ""
 "prior to r7409, you cannot use this procedure but would rather need to do a "
 "<link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
 msgstr ""
+"ご注意: PostGIS 1.*またはr7429以前のPostGIS 2.*へ移行する場合には、この手続きを使うことができませんが、<link "
+"linkend=\"hard_upgrade\">ハードアップグレード</link>を実行する必要があります。"
 #. Tag: para
 #: administration.xml:180
@@ -423,14 +465,18 @@ msgid ""
 "<filename>*_upgrade.sql</filename> files in the installation folders. You "
 "can list them all with:"
 msgstr ""
+"コンパイルとインストール (make install)の実行後に、インストール先フォルダ内にある<filename>*_upgrade."
+"sql</filename>のファイルの集合を見つけておくべきです。次のコマンドで一覧を得られます。"
 #: administration.xml:187
-#, no-c-format
 msgid ""
 "ls `pg_config --sharedir`/contrib/postgis-&last_release_version;/*_upgrade."
 "sql"
 msgstr ""
+"ls `pg_config --sharedir`/contrib/postgis-&last_release_version;/*_upgrade."
+"sql"
 #. Tag: para
 #: administration.xml:189
@@ -438,13 +484,13 @@ msgstr ""
 msgid ""
 "Load them all in turn, starting from <filename>postgis_upgrade.sql</"
 "filename>."
-msgstr ""
+msgstr "<filename>postgis_upgrade.sql</filename>から順番に全てをロードします。"
 #: administration.xml:193
 #, no-c-format
 msgid "psql -f postgis_upgrade.sql -d your_spatial_database"
-msgstr ""
+msgstr "psql -f postgis_upgrade.sql -d [データベース名]"
 #. Tag: para
 #: administration.xml:195
@@ -455,24 +501,27 @@ msgid ""
 "<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
 "filename> respectively. If you need them:"
 msgstr ""
+"同じ手続きをラスタ、トポロジ、SFCGALエクステンションに適用します。それぞれのファイル名は<filename>rtpostgis_upgrade."
+"sql</filename>, <filename>topology_upgrade.sql</filename>, "
+"<filename>sfcgal_upgrade.sql</filename>になります。次のように実行します。"
 #: administration.xml:204
 #, no-c-format
 msgid "psql -f rtpostgis_upgrade.sql -d your_spatial_database"
-msgstr ""
+msgstr "psql -f rtpostgis_upgrade.sql -d [データベース名]"
 #: administration.xml:205
 #, no-c-format
 msgid "psql -f topology_upgrade.sql -d your_spatial_database"
-msgstr ""
+msgstr "psql -f topology_upgrade.sql -d [データベース名]"
 #: administration.xml:206
 #, no-c-format
 msgid "psql -f sfcgal_upgrade.sql -d your_spatial_database"
-msgstr ""
+msgstr "psql -f sfcgal_upgrade.sql -d [データベース名]"
 #. Tag: para
 #: administration.xml:209
@@ -482,6 +531,9 @@ msgid ""
 "upgrading your version you are using a version too early for a soft upgrade "
 "and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
 msgstr ""
+"求める版へのアップグレードに使う特定の<filename>postgis_upgrade."
+"sql</filename>が発見できない場合には、ソフトアップグレードを実行するにはあまりに前の版を使っています。<link linkend="
+"\"hard_upgrade\">ハードアップグレード</link>が必要です。"
 #. Tag: para
 #: administration.xml:218
@@ -491,12 +543,14 @@ msgid ""
 "about the need to run this kind of upgrade using a \"procs need upgrade\" "
 "message."
 msgstr ""
+"<xref linkend=\"PostGIS_Full_Version\"/>関数の\"procs need upgrade\"というメッセージで"
+"、この種のアップグレードを実行する必要性についての情報が得られます。"
 #. Tag: title
 #: administration.xml:225
 #, no-c-format
 msgid "Soft Upgrade 9.1+ using extensions"
-msgstr ""
+msgstr "9.1以上でエクステンションを使ったソフトアップグレード"
 #. Tag: para
 #: administration.xml:226
@@ -506,6 +560,8 @@ msgid ""
 "upgrade using extensions as well. Doing a minor upgrade with extensions, is "
 "fairly painless."
 msgstr ""
+"エクステンションを使ってPostGISをインストールした場合には、エクステンションを使ってアップグレードする必要があります。エクステンションを使ったマイナ"
+"ーアップグレードはかなり楽です。"
 #: administration.xml:227
@@ -519,7 +575,7 @@ msgstr ""
 #: administration.xml:228
 #, no-c-format
 msgid "If you get an error notice something like:"
-msgstr ""
+msgstr "次のようなエラー通知が表示されることがあります。"
 #: administration.xml:229
commit bb3c81d493ce9293dfc84cb033b5db47236dd502
Date:   Mon Jan 17 17:48:04 2022 +0000
index 94e3e18db..2565971ca 100644
@@ -6,8 +6,8 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
-"PO-Revision-Date: 2022-01-17 17:45+0000\n"
-"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language: ja\n"
@@ -25,7 +25,7 @@ msgstr "PostGIS管理"
 #. Tag: chapter
 #: administration.xml:3
+#, no-c-format
 msgid "&database_tuning;"
 msgstr "&database_tuning;"
@@ -67,7 +67,7 @@ msgstr "データベース外ラスタを有効にするには次のようにし
+#, no-c-format
 msgid "POSTGIS_ENABLE_OUTDB_RASTERS=1"
 msgstr "POSTGIS_ENABLE_OUTDB_RASTERS=1"
@@ -87,7 +87,7 @@ msgstr "インストールしたGDALのドライバを有効にするには、
 #: administration.xml:23
+#, no-c-format
 msgid "POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL"
 msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL"
@@ -101,7 +101,7 @@ msgstr "一部のドライバのみ有効にしたい場合には、環境変数
 #: administration.xml:25
+#, no-c-format
 msgid "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
 msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
@@ -193,7 +193,7 @@ msgstr "空間データベースにしたいデータベース上で次のSQLを
 #: administration.xml:57
+#, no-c-format
 msgid ""
 "CREATE EXTENSION IF NOT EXISTS plpgsql;\n"
 "      CREATE EXTENSION postgis;\n"
commit 63470972dc833f6cb7ea4e5f8b79bae3a9c25a3d
Date:   Mon Jan 17 17:52:13 2022 +0000
    Translated using Weblate (Spanish)
    Currently translated at 1.1% (1 of 87 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/es/
diff --git a/doc/po/es/administration.xml.po b/doc/po/es/administration.xml.po
index 1d4d94b14..fd94cb8f4 100644
--- a/doc/po/es/administration.xml.po
+++ b/doc/po/es/administration.xml.po
-"PO-Revision-Date: 2022-01-14 16:01+0000\n"
-"Last-Translator: Carlos <carlos.lopez at psig.es>\n"
 "Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
 "administrationxml/es/>\n"
 "Language: es\n"
commit 742193de400f8cb504d4a091dd27c148becb4604
Date:   Mon Jan 17 17:50:37 2022 +0000
    Currently translated at 3.0% (1 of 33 strings)
    Translation: postgis/database_tuning.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/database_tuningxml/de/
diff --git a/doc/po/de/database_tuning.xml.po b/doc/po/de/database_tuning.xml.po
index aeb8504e0..1af336314 100644
--- a/doc/po/de/database_tuning.xml.po
+++ b/doc/po/de/database_tuning.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "POT-Creation-Date: 2020-12-19 17:06+0000\n"
-"PO-Revision-Date: 2022-01-15 01:45+0000\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "database_tuningxml/de/>\n"
Summary of changes:
 doc/po/de/database_tuning.xml.po |   2 +-
 doc/po/de/extras.xml.po          |  17 +++---
 doc/po/es/administration.xml.po  |   4 +-
 doc/po/ja/administration.xml.po  | 116 +++++++++++++++++++++++++++++----------
 doc/po/ja/extras.xml.po          |  19 +++----
 5 files changed, 107 insertions(+), 51 deletions(-)
hooks/post-receive
