[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-281-gd4ef31a6f
git at osgeo.org
git at osgeo.org
Tue Jan 18 16:27:51 PST 2022
the project "PostGIS".
via d4ef31a6fa590a61a3b8593a6268cad6684b3501 (commit)
from 5ae268c6e981800522093157b0ca4b219474a89a (commit)
revisions in full, below.
commit d4ef31a6fa590a61a3b8593a6268cad6684b3501
Author: Regina Obe <lr at pcorp.us>
Date: Tue Jan 18 19:27:47 2022 -0500
Pot update for https://github.com/postgis/postgis/pull/653
diff --git a/doc/po/templates/reference_output.xml.pot b/doc/po/templates/reference_output.xml.pot
index 0d85d7038..b9160ce63 100644
--- a/doc/po/templates/reference_output.xml.pot
+++ b/doc/po/templates/reference_output.xml.pot
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2022-01-10 13:02+0000\n"
+"POT-Creation-Date: 2022-01-19 00:25+0000\n"
"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -1990,7 +1990,12 @@ msgstr ""
#, no-c-format
msgid ""
"<varname>geom_name</varname> is the name of the geometry column in the row "
-"data. Default is the first geometry column."
+"data. Default is the first geometry column. Note that PostgreSQL by default "
+"automatically <ulink url=\"https://www.postgresql.org/docs/current/sql-"
+"syntax-lexical.html#SQL-SYNTAX-IDENTIFIERS\">folds unquoted identifiers to "
+"lower case</ulink>, which means that unless the geometry column is quoted, e."
+"g. <varname>\"MyMVTGeom\"</varname>, this parameter must be provided as "
+"lowercase."
msgstr ""
#. Tag: para
Summary of changes:
doc/po/templates/reference_output.xml.pot | 9 +++++++--
1 file changed, 7 insertions(+), 2 deletions(-)
hooks/post-receive
