[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-290-g1cedd55bc
git at osgeo.org
git at osgeo.org
Tue Jan 18 19:33:07 PST 2022
the project "PostGIS".
via 1cedd55bc98064a467a9c2197f4dc25dee842dc1 (commit)
from 1f4537873c838cfd41a79f3f836ddac6af36da2d (commit)
revisions in full, below.
commit 1cedd55bc98064a467a9c2197f4dc25dee842dc1
Author: Weblate <noreply at weblate.org>
Date: Wed Jan 19 03:32:56 2022 +0000
Update translation files
Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
Translation: postgis/reference_output.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_outputxml/
diff --git a/doc/po/de/reference_output.xml.po b/doc/po/de/reference_output.xml.po
index 31fb639fc..8fe4a93a6 100644
--- a/doc/po/de/reference_output.xml.po
+++ b/doc/po/de/reference_output.xml.po
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2022-01-19 00:25+0000\n"
+"POT-Creation-Date: 2022-01-19 03:22+0000\n"
"PO-Revision-Date: 2021-11-28 22:06+0000\n"
"Last-Translator: Regina Obe\n"
"Language-Team: German (http://www.transifex.com/postgis/postgis/language/de/)\n"
@@ -1876,8 +1876,9 @@ msgstr "Die Parameter \"sizes\" und \"bounding_boxes\" bestimmen ob zusätzliche
#. Tag: para
#: reference_output.xml:1150
-#, no-c-format
-msgid "The array-input form of the function is used to convert a collection of geometries and unique identifiers into a TWKB collection that preserves the identifiers. This is useful for clients that expect to unpack a collection and then access further information about the objects inside. You can create the arrays using the <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink> function. The other parameters operate the same as for the simple form of the function."
+#, fuzzy, no-c-format
+#| msgid "The array-input form of the function is used to convert a collection of geometries and unique identifiers into a TWKB collection that preserves the identifiers. This is useful for clients that expect to unpack a collection and then access further information about the objects inside. You can create the arrays using the <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink> function. The other parameters operate the same as for the simple form of the function."
+msgid "The array-input form of the function is used to convert a collection of geometries and unique identifiers into a TWKB collection that preserves the identifiers. This is useful for clients that expect to unpack a collection and then access further information about the objects inside. You can create the arrays using the <ulink url=\"https://www.postgresql.org/docs/current/functions-aggregate.html\">array_agg</ulink> function. The other parameters operate the same as for the simple form of the function."
msgstr "Das Feld-Eingabeformat dieser Funktion wird verwendet um eine Sammelgeometriee und eindeutige Identifikatoren in eine TWKB-Collection zu konvertieren, welche die Identifikatoren erhält. Dies ist nützlich für Clients, die davon ausgehen, eine Sammelgeometrie auszupacken, um so auf zusätzliche Information über die internen Objekte zuzugreifen. Sie können das Feld mit der Funktion <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink> erstellen. Die anderen Parameter bewirken dasselbe wie bei dem einfachen Format dieser Funktion."
#. Tag: para
diff --git a/doc/po/es/reference_output.xml.po b/doc/po/es/reference_output.xml.po
index 2fd170898..96c20e5f9 100644
--- a/doc/po/es/reference_output.xml.po
+++ b/doc/po/es/reference_output.xml.po
@@ -7,7 +7,7 @@ msgid ""
msgstr ""
"Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/es/)\n"
@@ -1698,7 +1698,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgstr ""
#. Tag: para
diff --git a/doc/po/fr/reference_output.xml.po b/doc/po/fr/reference_output.xml.po
index e19a6e56d..a8c55f793 100644
--- a/doc/po/fr/reference_output.xml.po
+++ b/doc/po/fr/reference_output.xml.po
@@ -8,7 +8,7 @@ msgid ""
msgstr ""
"Language-Team: French (http://www.transifex.com/postgis/postgis/language/fr/)\n"
@@ -1729,7 +1729,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgstr ""
#. Tag: para
diff --git a/doc/po/it_IT/reference_output.xml.po b/doc/po/it_IT/reference_output.xml.po
index ac445ed89..269dfe27c 100644
--- a/doc/po/it_IT/reference_output.xml.po
+++ b/doc/po/it_IT/reference_output.xml.po
msgstr ""
"PO-Revision-Date: 2022-01-19 00:27+0000\n"
"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/reference_outputxml/it/>\n"
@@ -1741,7 +1741,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgstr ""
#. Tag: para
diff --git a/doc/po/ja/reference_output.xml.po b/doc/po/ja/reference_output.xml.po
index 1e0bece13..42f4433e3 100644
--- a/doc/po/ja/reference_output.xml.po
+++ b/doc/po/ja/reference_output.xml.po
@@ -5,7 +5,7 @@ msgid ""
msgstr ""
"PO-Revision-Date: 2022-01-11 01:17+0000\n"
"Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
"Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/ja/)\n"
@@ -1957,8 +1957,9 @@ msgstr "include_sizesとinclude_bounding_boxesパラメータによって、符
#. Tag: para
-#, no-c-format
msgstr "配列入力の形式は、ジオメトリのコレクションを変換して、一意の識別子をTWKBコレクションに持たせるためのものです。これは、コレクションを展開して、オブジェクト内部に関する情報にさらにアクセスするのに使えます。<ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink>関数を使用して配列を生成できます。他のパラメータは、単純な形式のものと同じです。"
#. Tag: para
diff --git a/doc/po/ko_KR/reference_output.xml.po b/doc/po/ko_KR/reference_output.xml.po
index 566307448..002bae740 100644
--- a/doc/po/ko_KR/reference_output.xml.po
+++ b/doc/po/ko_KR/reference_output.xml.po
msgstr ""
"Language-Team: Korean (Korea) (http://www.transifex.com/postgis/postgis/language/ko_KR/)\n"
@@ -1856,8 +1856,9 @@ msgstr "크기 및 경계 상자 파라미터는 객체의 인코딩된 길이
#. Tag: para
-#, no-c-format
msgstr "이 함수의 배열 입력 형식은 도형 집합 및 유일 식별자를 식별자를 보전하는 TWKB 집합으로 변환하는 데 쓰입니다. 집합의 압축을 풀어 그 안에 있는 객체들에 대한 상세 정보에 접근하는 기능을 가진 클라이언트에 유용합니다. <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink> 함수를 이용해서 배열을 생성할 수 있습니다. 다른 파라미터들은 이 함수의 단순 형태의 경우와 동일하게 실행됩니다."
#. Tag: para
diff --git a/doc/po/pl/reference_output.xml.po b/doc/po/pl/reference_output.xml.po
index 83c4602f3..4f5b2823c 100644
--- a/doc/po/pl/reference_output.xml.po
+++ b/doc/po/pl/reference_output.xml.po
msgstr ""
"Language-Team: Polish (http://www.transifex.com/postgis/postgis/language/pl/)\n"
@@ -1696,7 +1696,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgstr ""
#. Tag: para
diff --git a/doc/po/pt_BR/reference_output.xml.po b/doc/po/pt_BR/reference_output.xml.po
index 5e9d1bedf..baef16e8c 100644
--- a/doc/po/pt_BR/reference_output.xml.po
+++ b/doc/po/pt_BR/reference_output.xml.po
msgstr ""
"Language-Team: Portuguese (Brazil) (http://www.transifex.com/postgis/postgis/language/pt_BR/)\n"
@@ -1857,8 +1857,9 @@ msgstr "Os tamanhos e os parâmetros das caixas limitadoras controlam onde as i
#. Tag: para
-#, no-c-format
msgstr "A forma arranjo entrada da função é usada para converter uma coleção de geometrias e identificadores únicos em uma coleção TWKB que preserva os identificadores. Isto é útil para clientes que esperam desempacotar uma coleção e acessar informações futuras sobre os objetos que estão dentro. Você pode criar os arranjos usando a função <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink>. Os outros parâmetros funcionam da mesma forma para o formato simples da função."
#. Tag: para
diff --git a/doc/po/ru/reference_output.xml.po b/doc/po/ru/reference_output.xml.po
index 4755258f8..80845fb2f 100644
--- a/doc/po/ru/reference_output.xml.po
+++ b/doc/po/ru/reference_output.xml.po
msgstr ""
"Language-Team: Russian (http://www.transifex.com/postgis/postgis/language/ru/)\n"
#. Tag: para
#, no-c-format
msgstr ""
#. Tag: para
Summary of changes:
doc/po/de/reference_output.xml.po | 7 ++++---
doc/po/es/reference_output.xml.po | 4 ++--
doc/po/fr/reference_output.xml.po | 4 ++--
doc/po/it_IT/reference_output.xml.po | 4 ++--
doc/po/ja/reference_output.xml.po | 7 ++++---
doc/po/ko_KR/reference_output.xml.po | 7 ++++---
doc/po/pl/reference_output.xml.po | 4 ++--
doc/po/pt_BR/reference_output.xml.po | 7 ++++---
doc/po/ru/reference_output.xml.po | 4 ++--
9 files changed, 26 insertions(+), 22 deletions(-)
hooks/post-receive
