[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-329-g91eb4c577
git at osgeo.org
git at osgeo.org
Thu Jan 20 12:16:16 PST 2022
the project "PostGIS".
via 91eb4c577b842978e37294871a91952765448749 (commit)
via 2e7c205c1590015d36119e0fb516dbc42e63a32a (commit)
via 5c970f355b655d09846695d34da5aca3b84431e5 (commit)
via 4d2757695a0a1d3ee4b7db07a0c5e5577d4b3ce8 (commit)
via ae320031d06f4cc663c70e634b8823c81ff3245a (commit)
from 2e6f56fdbd7f61f0b9650a23db2ed7f24a51b457 (commit)
revisions in full, below.
commit 91eb4c577b842978e37294871a91952765448749
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 20 20:34:34 2022 +0100
Fix out-of-tree topology regression tests
diff --git a/topology/test/Makefile.in b/topology/test/Makefile.in
index 1636c71c1..9f6c8020d 100644
--- a/topology/test/Makefile.in
+++ b/topology/test/Makefile.in
@@ -41,14 +41,14 @@ edit:
$(PSQL) -X -f edit_topology.sql $(DATABASE)
-topo_predicates.sql: predicates.sql.in
- cpp -P -traditional-cpp predicates.sql.in | sed -e 's:@COLUMN@:feature:g;s:@SCHEMA@:topology.:g' > topo_predicates.sql
+topo_predicates.sql: predicates.sql.in Makefile
+ cpp -P -traditional-cpp $< | sed -e 's:@COLUMN@:feature:g;s:@SCHEMA@:topology.:g' > $@
-load_topology.sql: load_topology.sql.in
- cpp -P -traditional-cpp load_topology.sql.in | sed -e 's:@SRID@:-1:g' > load_topology.sql
+load_topology.sql: load_topology.sql.in Makefile
+ cpp -P -traditional-cpp $< | sed -e 's:@SRID@:-1:g' > $@
-load_topology-4326.sql: load_topology.sql.in
- cpp -P -traditional-cpp load_topology.sql.in | sed -e 's:@SRID@:4326:g' > load_topology-4326.sql
+load_topology-4326.sql: load_topology.sql.in Makefile
+ cpp -P -traditional-cpp $< | sed -e 's:@SRID@:4326:g' > $@
clean distclean:
rm -f topo_predicates.sql load_topology.sql load_topology-4326.sql
diff --git a/topology/test/regress/cleartopogeom.sql b/topology/test/regress/cleartopogeom.sql
index e8d8c5797..4462d7416 100644
--- a/topology/test/regress/cleartopogeom.sql
+++ b/topology/test/regress/cleartopogeom.sql
@@ -1,7 +1,7 @@
\set VERBOSITY terse
set client_min_messages to ERROR;
-\i ../load_topology.sql
+\i :top_builddir/topology/test/load_topology.sql
\i ../load_features.sql
SELECT 'relation before', count(distinct topogeo_id)
diff --git a/topology/test/regress/copytopology.sql b/topology/test/regress/copytopology.sql
index aca4a2a34..6602b0aed 100644
--- a/topology/test/regress/copytopology.sql
+++ b/topology/test/regress/copytopology.sql
@@ -1,6 +1,6 @@
set client_min_messages to WARNING;
-\i ../load_topology-4326.sql
+\i :top_builddir/topology/test/load_topology-4326.sql
\i ../more_features.sql
diff --git a/topology/test/regress/getfacecontainingpoint.sql b/topology/test/regress/getfacecontainingpoint.sql
index df7a48581..16e80ad1a 100644
--- a/topology/test/regress/getfacecontainingpoint.sql
+++ b/topology/test/regress/getfacecontainingpoint.sql
@@ -1,7 +1,7 @@
-- Add holes touching shell defined in CW order
SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(24 14, 23 17,25 17, 24 14)');
diff --git a/topology/test/regress/getnodeedges.sql b/topology/test/regress/getnodeedges.sql
index e4198b1a1..d2daebf1c 100644
--- a/topology/test/regress/getnodeedges.sql
+++ b/topology/test/regress/getnodeedges.sql
@@ -1,6 +1,6 @@
SELECT 'N'||node_id, (topology.GetNodeEdges('city_data', node_id)).*
FROM city_data.node ORDER BY node_id, sequence;
diff --git a/topology/test/regress/getringedges.sql b/topology/test/regress/getringedges.sql
index 6d23626a4..d54f53df3 100644
--- a/topology/test/regress/getringedges.sql
+++ b/topology/test/regress/getringedges.sql
@@ -1,6 +1,6 @@
-- Test bogus calls
SELECT 'non-existent-topo', topology.GetRingEdges('non-existent', 1);
diff --git a/topology/test/regress/gettopogeomelements.sql b/topology/test/regress/gettopogeomelements.sql
index e3a70afc5..03efdfcc7 100644
--- a/topology/test/regress/gettopogeomelements.sql
+++ b/topology/test/regress/gettopogeomelements.sql
@@ -1,6 +1,6 @@
SELECT lid, tid, GetTopoGeomElements('city_data', lid, tid)
diff --git a/topology/test/regress/gml.sql b/topology/test/regress/gml.sql
index 0582ca7cb..2a7b168b0 100644
--- a/topology/test/regress/gml.sql
+++ b/topology/test/regress/gml.sql
@@ -1,6 +1,6 @@
diff --git a/topology/test/regress/legacy_predicate.sql b/topology/test/regress/legacy_predicate.sql
index 88ee4da42..a644c2e28 100644
--- a/topology/test/regress/legacy_predicate.sql
+++ b/topology/test/regress/legacy_predicate.sql
@@ -1,10 +1,10 @@
-\i ../load_features.sql
-\i ../more_features.sql
-\i ../hierarchy.sql
-\i ../topo_predicates.sql
+\i :regdir/../topology/test/load_features.sql
+\i :regdir/../topology/test/more_features.sql
+\i :regdir/../topology/test/hierarchy.sql
+\i :top_builddir/topology/test/topo_predicates.sql
-- clean up
SELECT topology.DropTopology('city_data');
diff --git a/topology/test/regress/legacy_query.sql b/topology/test/regress/legacy_query.sql
index 21d0fd39e..3729773a9 100644
--- a/topology/test/regress/legacy_query.sql
+++ b/topology/test/regress/legacy_query.sql
@@ -2,7 +2,7 @@ set client_min_messages to WARNING;
-- Tests TopoGeometry->Geometry cast and id(TopoGeometry)
\i ../hierarchy.sql
diff --git a/topology/test/regress/legacy_validate.sql b/topology/test/regress/legacy_validate.sql
index 1dd8f0428..a3985621b 100644
--- a/topology/test/regress/legacy_validate.sql
+++ b/topology/test/regress/legacy_validate.sql
@@ -1,6 +1,6 @@
\i ../validate_topology.sql
-- clean up
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 047bd6c45..c39424f73 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -1,6 +1,6 @@
-- Endpoint / node mismatch
SELECT topology.ST_AddEdgeModFace('city_data', 7, 6,
diff --git a/topology/test/regress/st_addedgenewfaces.sql b/topology/test/regress/st_addedgenewfaces.sql
index db90018b9..af25a0a21 100644
--- a/topology/test/regress/st_addedgenewfaces.sql
+++ b/topology/test/regress/st_addedgenewfaces.sql
@@ -1,6 +1,6 @@
SELECT topology.ST_AddEdgeNewFaces('city_data', 7, 6,
diff --git a/topology/test/regress/st_addisonode.sql b/topology/test/regress/st_addisonode.sql
index 2a9678db9..09827a627 100644
--- a/topology/test/regress/st_addisonode.sql
+++ b/topology/test/regress/st_addisonode.sql
@@ -3,7 +3,7 @@ set client_min_messages to WARNING;
-- Usual city_data input
-- NULL exceptions
select ST_AddIsoNode(NULL, 0, 'POINT(1 4)');
diff --git a/topology/test/regress/st_changeedgegeom.sql b/topology/test/regress/st_changeedgegeom.sql
index bc1887818..1d8a6395e 100644
--- a/topology/test/regress/st_changeedgegeom.sql
+++ b/topology/test/regress/st_changeedgegeom.sql
@@ -1,6 +1,6 @@
-- good one
SELECT 'T1', topology.ST_ChangeEdgeGeom('city_data', 25,
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index b00c87eac..628c470d7 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -2,7 +2,7 @@
-- Import city_data
SELECT topology.ST_ModEdgeHeal('city_data', 1, null);
SELECT topology.ST_ModEdgeHeal('city_data', null, 1);
diff --git a/topology/test/regress/st_modedgesplit.sql b/topology/test/regress/st_modedgesplit.sql
index 98310fe34..fa7fb00d4 100644
--- a/topology/test/regress/st_modedgesplit.sql
+++ b/topology/test/regress/st_modedgesplit.sql
@@ -3,7 +3,7 @@
-- Import city_data
-- Save max node id
select 'node'::text as what, max(node_id) INTO city_data.limits FROM city_data.node;
diff --git a/topology/test/regress/st_moveisonode.sql b/topology/test/regress/st_moveisonode.sql
index feb544fc5..2457a3967 100644
--- a/topology/test/regress/st_moveisonode.sql
+++ b/topology/test/regress/st_moveisonode.sql
@@ -2,7 +2,7 @@
-- Import city_data
-- Isolated node to invalid location (coincident)
SELECT 'coincident_node', topology.ST_MoveIsoNode('city_data', 4, 'POINT(25 35)');
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index 51bf3157f..a97ec9791 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
@@ -2,7 +2,7 @@
-- Import city_data
SELECT topology.ST_NewEdgeHeal('city_data', 1, null);
SELECT topology.ST_NewEdgeHeal('city_data', null, 1);
diff --git a/topology/test/regress/st_newedgessplit.sql b/topology/test/regress/st_newedgessplit.sql
index abaeafd97..075f599b3 100644
--- a/topology/test/regress/st_newedgessplit.sql
+++ b/topology/test/regress/st_newedgessplit.sql
@@ -3,7 +3,7 @@
-- Import city_data
-- Save max node id
diff --git a/topology/test/regress/st_remedgemodface.sql b/topology/test/regress/st_remedgemodface.sql
index a8ac67434..320571da2 100644
--- a/topology/test/regress/st_remedgemodface.sql
+++ b/topology/test/regress/st_remedgemodface.sql
@@ -2,7 +2,7 @@
-- Import city_data
-- Utility functions for the test {
@@ -375,7 +375,7 @@ SELECT topology.DropTopology('city_data');
-- Import city_data
\i ../cache_geometries.sql
diff --git a/topology/test/regress/st_remedgenewface.sql b/topology/test/regress/st_remedgenewface.sql
index c5f5413ba..ebaa42207 100644
--- a/topology/test/regress/st_remedgenewface.sql
+++ b/topology/test/regress/st_remedgenewface.sql
@@ -2,7 +2,7 @@
-- Import city_data
-- Import city_data
diff --git a/topology/test/regress/st_removeisoedge.sql b/topology/test/regress/st_removeisoedge.sql
index 38a2db0ad..afe686f30 100644
--- a/topology/test/regress/st_removeisoedge.sql
+++ b/topology/test/regress/st_removeisoedge.sql
@@ -2,7 +2,7 @@
-- Import city_data
CREATE TABLE city_data.f_lin(id serial primary key);
SELECT NULL FROM AddTopoGeometryColumn('city_data', 'city_data', 'f_lin', 'tg', 'LINE');
diff --git a/topology/test/regress/st_removeisonode.sql b/topology/test/regress/st_removeisonode.sql
index ea25c67d6..5551195dc 100644
--- a/topology/test/regress/st_removeisonode.sql
+++ b/topology/test/regress/st_removeisonode.sql
@@ -2,7 +2,7 @@
-- Import city_data
-- Non isolated node (is used by an edge);
SELECT 'non-iso', topology.ST_RemoveIsoNode('city_data', 1);
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 60cabfe26..7a9a871ca 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -1,7 +1,7 @@
-- Save max node id
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index 3f7cd3e80..155db91af 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -1,7 +1,7 @@
-- Invalid calls
SELECT 'invalid', TopoGeo_addPoint('city_data', 'LINESTRING(36 26, 38 30)');
diff --git a/topology/test/regress/topogeo_addpolygon.sql b/topology/test/regress/topogeo_addpolygon.sql
index 68863b0b5..f7ace00a1 100644
--- a/topology/test/regress/topogeo_addpolygon.sql
+++ b/topology/test/regress/topogeo_addpolygon.sql
@@ -1,7 +1,7 @@
-- Save max node,edge and face ids
diff --git a/topology/test/regress/topogeometry_srid.sql b/topology/test/regress/topogeometry_srid.sql
index af455d4f5..08fe7dafa 100644
--- a/topology/test/regress/topogeometry_srid.sql
+++ b/topology/test/regress/topogeometry_srid.sql
@@ -1,6 +1,6 @@
\i ../hierarchy.sql
diff --git a/topology/test/regress/topogeometry_type.sql b/topology/test/regress/topogeometry_type.sql
index 4da8a3167..1970898fc 100644
--- a/topology/test/regress/topogeometry_type.sql
+++ b/topology/test/regress/topogeometry_type.sql
@@ -1,6 +1,6 @@
\i ../hierarchy.sql
diff --git a/topology/test/regress/topojson.sql b/topology/test/regress/topojson.sql
index e5ccf1444..1305ac58f 100644
--- a/topology/test/regress/topojson.sql
+++ b/topology/test/regress/topojson.sql
@@ -1,6 +1,6 @@
\i ../hierarchy.sql
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index 2d7caeaa5..d18067dc6 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -49,7 +49,8 @@ SELECT null from ( select topology.DropTopology('t') ) as dt;
-- Following tests will use the city_data topology as a base
SELECT 'unexpected_city_data_invalidities', * FROM ValidateTopology('city_data');
-- Test correctness of edge linking
diff --git a/topology/test/regress/validatetopologyrelation.sql b/topology/test/regress/validatetopologyrelation.sql
index 36ab03651..c8edc01f0 100644
--- a/topology/test/regress/validatetopologyrelation.sql
+++ b/topology/test/regress/validatetopologyrelation.sql
@@ -2,7 +2,7 @@
\i ../hierarchy.sql
--\i ../more_features.sql
commit 2e7c205c1590015d36119e0fb516dbc42e63a32a
Date: Thu Jan 20 19:55:52 2022 +0100
Add top_builddir variable
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 21507a565..475928e0a 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -400,6 +400,7 @@ foreach $TEST (@ARGV)
# TODO: add more variables?
my $cmd = "psql -Xq"
. " -v \"regdir=$REGDIR\""
+ . " -v \"top_builddir=$TOP_BUILDDIR\""
. " -v \"scriptdir=$scriptdir\""
. " -v \"schema=$OPT_SCHEMA.\""
# TODO: inject search_path somehow
@@ -660,6 +661,7 @@ sub run_simple_sql
my $tmpfile = sprintf("%s/test_%s_tmp", $TMPDIR, $RUN);
my $cmd = "psql -v \"VERBOSITY=terse\" "
. " -tXAq $DB < $sql > $tmpfile 2>&1";
#print($cmd);
my $rv = system($cmd);
@@ -757,6 +759,7 @@ sub run_simple_test
. " -v \"tmpfile='$tmpfile'\""
. " -c \"SET search_path TO public,$OPT_SCHEMA,topology\""
. " -tXAq -f $sqlfile $DB > $outfile 2>&1";
commit 5c970f355b655d09846695d34da5aca3b84431e5
Date: Thu Jan 20 19:47:29 2022 +0100
Fix check-unit under doc/
diff --git a/doc/Makefile.in b/doc/Makefile.in
index f63f08eeb..d15ba8190 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -432,7 +432,7 @@ ifeq ($(XMLLINT),)
check-unit: requirements_not_met_xmllint
else
check-unit: $(XML_INPUTS)
- $(XMLLINT) --loaddtd --xinclude --valid postgis-out.xml > /dev/null
+ $(XMLLINT) --loaddtd --path $(srcdir) --xinclude --valid postgis-out.xml > /dev/null
endif
check-localized:
commit 4d2757695a0a1d3ee4b7db07a0c5e5577d4b3ce8
Date: Thu Jan 20 19:43:18 2022 +0100
Fix build of unit tests of loader
diff --git a/loader/cunit/Makefile.in b/loader/cunit/Makefile.in
index 429fa8521..a6f842a73 100644
--- a/loader/cunit/Makefile.in
+++ b/loader/cunit/Makefile.in
@@ -2,6 +2,8 @@
# * PostGIS - Spatial Types for PostgreSQL
# * http://postgis.net
+# * Copyright 2022 Sandro Santilli <strk at kbt.io>
# * Copyright 2008 Paul Ramsey, Mark Cave-Ayland
# * This is free software; you can redistribute and/or modify it under
@@ -10,13 +12,22 @@
top_builddir = @top_builddir@
+srcdir = @srcdir@
+top_srcdir = @top_srcdir@
CC=@CC@
CFLAGS=@CFLAGS@
SHELL = @SHELL@
LIBTOOL = @LIBTOOL@
CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
-CUNIT_CPPFLAGS=-I.. @CUNIT_CPPFLAGS@ @CPPFLAGS@
+CUNIT_CPPFLAGS = \
+ -I$(srcdir)/.. \
+ -I$(top_builddir)/liblwgeom \
+ -I$(top_srcdir)/liblwgeom \
+ -I.. \
+ @CUNIT_CPPFLAGS@ \
+ @CPPFLAGS@
# GTK includes and libraries
GTK_CFLAGS = @GTK_CFLAGS@ @IGE_MAC_CFLAGS@
@@ -28,7 +39,7 @@ PGSQL_FE_CPPFLAGS=@PGSQL_FE_CPPFLAGS@
PGSQL_FE_LDFLAGS=@PGSQL_FE_LDFLAGS@
# liblwgeom
-LIBLWGEOM=../../liblwgeom/.libs/liblwgeom.la
+LIBLWGEOM = $(top_builddir)/liblwgeom/.libs/liblwgeom.la
# iconv flags
ICONV_LDFLAGS=@ICONV_LDFLAGS@
@@ -48,6 +59,8 @@ CFLAGS += $(GETTEXT_CFLAGS) $(ICONV_CFLAGS) $(PROJ_CFLAGS)
# Build full linking line
LDFLAGS = $(GEOS_LDFLAGS) $(GETTEXT_LDFLAGS) $(PGSQL_FE_LDFLAGS) $(ICONV_LDFLAGS) $(CUNIT_LDFLAGS) $(PROJ_LDFLAGS)
+VPATH = $(srcdir)
# Object files
OBJS= \
cu_pgsql2shp.o \
commit ae320031d06f4cc663c70e634b8823c81ff3245a
Date: Thu Jan 20 19:32:52 2022 +0100
Fix out-of-tree raster unit tests
diff --git a/raster/test/cunit/Makefile.in b/raster/test/cunit/Makefile.in
index 4e217ffb0..03f3d1344 100644
--- a/raster/test/cunit/Makefile.in
+++ b/raster/test/cunit/Makefile.in
@@ -39,6 +39,7 @@ CFLAGS = \
-I$(top_builddir)/raster \
-I$(builddir) \
-I$(builddir)/.. \
+ -DPOSTGIS_TOP_SRC_DIR='"$(realpath $(top_srcdir))"' \
$(LIBLWGEOM_CFLAGS) \
$(RTCORE_CFLAGS) \
$(PROJ_CFLAGS) \
diff --git a/raster/test/cunit/cu_band_basics.c b/raster/test/cunit/cu_band_basics.c
index 836e66145..5219442e9 100644
--- a/raster/test/cunit/cu_band_basics.c
+++ b/raster/test/cunit/cu_band_basics.c
@@ -33,7 +33,7 @@ static void test_band_metadata() {
int height = 5;
int temp = 0;
double val = 0;
- char *path = "../regress/loader/testraster.tif";
+ char *path = POSTGIS_TOP_SRC_DIR "/raster/test/regress/loader/testraster.tif";
uint8_t extband = 0;
int x;
int y;
@@ -1263,7 +1263,7 @@ static void test_band_new_offline_from_path() {
rt_band band = NULL;
int width = 10;
int height = 10;
/* offline band */
Summary of changes:
doc/Makefile.in | 2 +-
loader/cunit/Makefile.in | 17 +++++++++++++++--
raster/test/cunit/Makefile.in | 1 +
raster/test/cunit/cu_band_basics.c | 4 ++--
regress/run_test.pl | 3 +++
topology/test/Makefile.in | 12 ++++++------
topology/test/regress/cleartopogeom.sql | 2 +-
topology/test/regress/copytopology.sql | 2 +-
topology/test/regress/getfacecontainingpoint.sql | 2 +-
topology/test/regress/getnodeedges.sql | 2 +-
topology/test/regress/getringedges.sql | 2 +-
topology/test/regress/gettopogeomelements.sql | 2 +-
topology/test/regress/gml.sql | 2 +-
topology/test/regress/legacy_predicate.sql | 10 +++++-----
topology/test/regress/legacy_query.sql | 2 +-
topology/test/regress/legacy_validate.sql | 2 +-
topology/test/regress/st_addedgemodface.sql | 2 +-
topology/test/regress/st_addedgenewfaces.sql | 2 +-
topology/test/regress/st_addisonode.sql | 2 +-
topology/test/regress/st_changeedgegeom.sql | 2 +-
topology/test/regress/st_modedgeheal.sql | 2 +-
topology/test/regress/st_modedgesplit.sql | 2 +-
topology/test/regress/st_moveisonode.sql | 2 +-
topology/test/regress/st_newedgeheal.sql | 2 +-
topology/test/regress/st_newedgessplit.sql | 2 +-
topology/test/regress/st_remedgemodface.sql | 4 ++--
topology/test/regress/st_remedgenewface.sql | 4 ++--
topology/test/regress/st_removeisoedge.sql | 2 +-
topology/test/regress/st_removeisonode.sql | 2 +-
topology/test/regress/topogeo_addlinestring.sql | 2 +-
topology/test/regress/topogeo_addpoint.sql | 2 +-
topology/test/regress/topogeo_addpolygon.sql | 2 +-
topology/test/regress/topogeometry_srid.sql | 2 +-
topology/test/regress/topogeometry_type.sql | 2 +-
topology/test/regress/topojson.sql | 2 +-
topology/test/regress/validatetopology.sql | 3 ++-
topology/test/regress/validatetopologyrelation.sql | 2 +-
37 files changed, 66 insertions(+), 48 deletions(-)
hooks/post-receive
