[postgis-tickets] [PostGIS] #5038: test_spheroid_distance in 3.2.0 fails on OpenBSD
trac at osgeo.org
Thu Jan 20 15:32:32 PST 2022
Reporter: landry | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by pramsey):
I guess what I'm saying is: probably you updated your underlying proj? I
didn't change postgis geodetic in this release cycle, so the churn is
coming from proj. I can bump the epsilon up even higher, or maybe strip
the tests out entirely, as testing upstream projects doesn't have a lot of
value, unless testing for gross failures.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5038#comment:4>
