[postgis-tickets] [PostGIS] #5038: test_spheroid_distance in 3.2.0 fails on OpenBSD
PostGIS trac at osgeo.org
Thu Jan 20 23:11:04 PST 2022
  Reporter:  landry   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.2.1
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by landry):
 Replying to [comment:4 pramsey]:
 > I guess what I'm saying is: probably you updated your underlying proj? I
 didn't change postgis geodetic in this release cycle, so the churn is
 coming from proj.
 Oh.. well if i updated proj in the meantime (eg since the last time i ran
 all tests) it was just minor updates eg 8.2.0 -> 8.2.1, cf
 https://github.com/openbsd/ports/commits/master/devel/proj/distinfo.
 But you're probably right, i've rolled back postgis to 3.1.4 locally
 (still with proj 8.2.1) and the test_spheroid_distance test still fails,
 so that might be fallout of some proj update.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5038#comment:6>
