[postgis-tickets] [PostGIS] #5065: PGXS is preventing out-of-tree builds of control files
trac at osgeo.org
Fri Jan 21 00:07:56 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: 3.2.x
Keywords: |
The pgxs.mk has, in the `install` target, this block:
ifneq (,$(EXTENSION))
$(INSTALL_DATA) $(addprefix $(srcdir)/, $(addsuffix .control,
$(EXTENSION))) '$(DESTDIR)$(datadir)/extension/'
endif # EXTENSION
The code is basically prepending $(srcdir) to the .control file path and
trying to install it, when EXTENSION variable is set.
In PostGIS we are generating the control files from the control.in files,
so when building out-of-source-tree we have those files in the *build*
directory, not the *source* directory.
I'd drop PGXS use completely to fix this issue, or at least we'd need to
override the install rule
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5065>
