[postgis-tickets] [PostGIS] #5066: Can't build under mingw64, might be sfcgal issue
PostGIS trac at osgeo.org
Fri Jan 21 07:55:08 PST 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.0
Component:  postgis  |    Version:  master
 Keywords:           |
 Since commit
 [dd4ab0d7/git]
 both winnie and I are getting error
 https://winnie.postgis.net/job/PostGIS_EDB_Regress_winnie/13183/consoleFull
 NOTICE:  schema "public" already exists, skipping
 CREATE SCHEMA
 SET
 BEGIN
 SET
 DO
 DO
 CREATE FUNCTION
 psql:E:/jenkins/postgis/branches/3.3/regress/00-regress-
 install/share/contrib/postgis/postgis.sql:106: ERROR:  could not access
 file "/projects/postgis/branches/3.3/regress/00-regress-
 install/lib/postgis-3.3": No such file or directory
  failed (Error encountered loading
 install/share/contrib/postgis/postgis_comments.sql:
 /projects/postgis/tmp/3.3.0dev_pg11_geos3.11_gdal3.3.3w64/regress_log)
 and last commit still has error
 -- https://winnie.postgis.net/job/PostGIS_EDB_Regress_winnie/13192/console
 -- corresponding to [cbb884c5/git]
 CREATE SCHEMA
 SET
 BEGIN
 SET
 DO
 DO
 CREATE FUNCTION
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5066>
