[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-346-g6a48844bd
Fri Jan 21 22:52:29 PST 2022
the project "PostGIS".
       via  6a48844bd75afa4a773a22dd20bb507023fdab88 (commit)
       via  859a9dbe99b24184e8dbfaf96f74a856853ed989 (commit)
      from  cbb884c59085c1d4df6d8636938ae3904d2d4560 (commit)
revisions in full, below.
commit 6a48844bd75afa4a773a22dd20bb507023fdab88
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri Jan 21 06:29:47 2022 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (87 of 87 strings)
    Translation: postgis/administration.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ja/
diff --git a/doc/po/ja/administration.xml.po b/doc/po/ja/administration.xml.po
index 21ccebcfb..fd6c34c10 100644
--- a/doc/po/ja/administration.xml.po
+++ b/doc/po/ja/administration.xml.po
@@ -1,12 +1,11 @@
 # SOME DESCRIPTIVE TITLE.
-# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022.
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-01-20 18:53+0000\n"
-"PO-Revision-Date: 2022-01-18 14:46+0000\n"
+"PO-Revision-Date: 2022-01-22 06:52+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "administrationxml/ja/>\n"
@@ -368,7 +367,7 @@ msgstr "シェルからの実行は次の通りです。"
 #. Tag: programlisting
 #: administration.xml:124
-#, fuzzy, no-c-format
+#, no-c-format
 msgid "# createdb -T template_postgis my_spatial_db"
 msgstr "# createdb -T template_postgis my_spatial_db"
@@ -380,7 +379,7 @@ msgstr "SQLからの実行は次の通りです。"
 #: administration.xml:130
+#, no-c-format
 msgid "postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis"
 msgstr "postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis"
@@ -471,7 +470,7 @@ msgstr ""
 #: administration.xml:172
+#, no-c-format
 msgid "can't drop … because postgis extension depends on it"
 msgstr "can't drop ... because postgis extension depends on it"
@@ -501,7 +500,7 @@ msgstr ""
 #: administration.xml:187
+#, no-c-format
 msgid ""
 "ls `pg_config --sharedir`/contrib/postgis-&last_release_version;/*_upgrade."
 "sql"
@@ -600,7 +599,7 @@ msgstr ""
 #: administration.xml:227
+#, no-c-format
 msgid ""
 "ALTER EXTENSION postgis UPDATE TO \"&last_release_version;\";\n"
 "ALTER EXTENSION postgis_topology UPDATE TO \"&last_release_version;\";"
@@ -618,7 +617,7 @@ msgstr "次のようなエラー通知が表示されることがあります。
 #: administration.xml:229
 #, no-c-format
 msgid "No migration path defined for … to &last_release_version;"
-msgstr ""
+msgstr "No migration path defined for … to &last_release_version;"
 #. Tag: para
 #: administration.xml:230
@@ -640,7 +639,7 @@ msgstr "次のようなメッセージを得ることがあります。"
 #: administration.xml:232
+#, no-c-format
 msgid ""
 "Version \"&last_release_version;\" of extension \"postgis\" is already "
 "installed"
@@ -665,7 +664,7 @@ msgstr ""
 #: administration.xml:239
+#, no-c-format
 msgid ""
 "ALTER EXTENSION postgis UPDATE TO \"&last_release_version;next\";\n"
 "ALTER EXTENSION postgis_topology UPDATE TO \"&last_release_version;next\";"
@@ -704,7 +703,7 @@ msgstr ""
 #: administration.xml:250
+#, no-c-format
 msgid "DROP EXTENSION postgis_raster;"
 msgstr "DROP EXTENSION postgis_raster;"
@@ -778,7 +777,7 @@ msgstr ""
 #: administration.xml:298
+#, no-c-format
 msgid ""
 "pg_dump -h localhost -p 5432 -U postgres -Fc -b -v -f \"/somepath/olddb."
 "backup\" olddb"
@@ -847,7 +846,7 @@ msgstr ""
 #: administration.xml:345
+#, no-c-format
 msgid ""
 "perl utils/postgis_restore.pl \"/somepath/olddb.backup\" | psql -h localhost "
 "-p 5432 -U postgres newdb 2> errors.txt"
@@ -953,7 +952,7 @@ msgstr ""
 #: administration.xml:420
+#, no-c-format
 msgid ""
 "psql -h localhost -p 5432 -U postgres -d newdb -f olddb-without-IGN.sql  2> "
 "errors.txt"
commit 859a9dbe99b24184e8dbfaf96f74a856853ed989
Date:   Fri Jan 21 06:35:26 2022 +0000
    Currently translated at 30.3% (10 of 33 strings)
    Translation: postgis/database_tuning.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/database_tuningxml/ja/
diff --git a/doc/po/ja/database_tuning.xml.po b/doc/po/ja/database_tuning.xml.po
index 86648ec87..9baf850a1 100644
--- a/doc/po/ja/database_tuning.xml.po
+++ b/doc/po/ja/database_tuning.xml.po
@@ -1,25 +1,27 @@
-#, fuzzy
 msgid ""
 msgstr ""
 "POT-Creation-Date: 2020-12-19 17:06+0000\n"
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
-"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
-"Language: \n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"database_tuningxml/ja/>\n"
+"Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.10.1\n"
 #. Tag: title
 #: database_tuning.xml:4
 #, no-c-format
 msgid "Performance Tuning"
-msgstr ""
+msgstr "パフォーマンスチューニング"
 #. Tag: para
 #: database_tuning.xml:6
@@ -30,6 +32,8 @@ msgid ""
 "are usually large, so memory-related optimizations generally have more of an "
 "impact on PostGIS than other types of PostgreSQL queries."
 msgstr ""
+"PostGISの調整はPostgreSQLの作業量の調整と非常に似ています。ジオメトリとラスタは重く、メモリ関連の最適化は他のPostgreSQLクエリと"
+"比べて影響が大きい点だけは留意して下さい。"
 #. Tag: para
 #: database_tuning.xml:10
@@ -39,6 +43,8 @@ msgid ""
 "\"https://wiki.postgresql.org/wiki/Tuning_Your_PostgreSQL_Server\">Tuning "
 "your PostgreSQL Server</ulink>."
 msgstr ""
+"PostgreSQLの最適化に関する一般的な詳細は、 <ulink url=\"https://wiki.postgresql.org/wiki/"
+"Tuning_Your_PostgreSQL_Server\">Tuning your PostgreSQL Server</ulink>をご覧ください。"
 #. Tag: para
 #: database_tuning.xml:12
@@ -48,6 +54,8 @@ msgid ""
 "touching <code>postgresql.conf</code> or <code>postgresql.auto.conf</code> "
 "by using the <code>ALTER SYSTEM</code> command."
 msgstr ""
+"PostgreSQL 9.4以上では、<code>ALTER SYSTEM</code>を使うことで、<code>postgresql."
+"conf</code>や<code>postgresql.auto.conf</code>を触ることなくサーバレベルで設定できます。"
 #: database_tuning.xml:14
@@ -60,6 +68,12 @@ msgid ""
 "-- use SHOW ALL to see all settings\n"
 "SHOW work_mem;"
 msgstr ""
+"ALTER SYSTEM SET work_mem = '256MB';\n"
+"-- 起動時設定でない設定を強制します。新規接続に影響を与えます。\n"
+"SELECT pg_reload_conf();\n"
+"-- 現在の設定値を表示\n"
+"-- 全ての設定を見るにはSHOW ALLを使います\n"
+"SHOW work_mem;"
 #. Tag: para
 #: database_tuning.xml:16
@@ -68,30 +82,31 @@ msgid ""
 "In addition to the Postgres settings, PostGIS has some custom settings which "
 "are listed in <xref linkend=\"PostGIS_GUC\"/>."
 msgstr ""
+"PostgreSQLの設定に加えて、PostGISには <xref linkend=\"PostGIS_GUC\"/>で挙げる独自設定があります。"
 #. Tag: title
 #: database_tuning.xml:19
 #, no-c-format
 msgid "Startup"
-msgstr ""
+msgstr "起動時"
 #. Tag: para
 #: database_tuning.xml:21
 #, no-c-format
 msgid "These settings are configured in <code>postgresql.conf</code>:"
-msgstr ""
+msgstr "次に示す設定は<code>postgresql.conf</code>にあります。"
 #. Tag: ulink
 #: database_tuning.xml:26
 #, no-c-format
 msgid "constraint_exclusion"
-msgstr ""
+msgstr "constraint_exclusion"
 #. Tag: para
 #: database_tuning.xml:31
 #, no-c-format
 msgid "Default: partition"
-msgstr ""
+msgstr "デフォルト: partition"
 #. Tag: para
 #: database_tuning.xml:36
Summary of changes:
 doc/po/ja/administration.xml.po  | 29 ++++++++++++++---------------
 doc/po/ja/database_tuning.xml.po | 35 +++++++++++++++++++++++++----------
 2 files changed, 39 insertions(+), 25 deletions(-)
hooks/post-receive
