[postgis-tickets] [SCM] PostGIS branch out-of-build-docs updated. 3.2.0-383-g24df40f76
git at osgeo.org
git at osgeo.org
Thu Jan 27 09:26:15 PST 2022
the project "PostGIS".
The branch, out-of-build-docs has been updated
discards 598ffa3f99b7648d45e361bc91d36e9a8c70038d (commit)
discards bb827330ed16bdf88dbe793b67beaa2b0e9de81d (commit)
discards 99809f9f1a0391b2dc44b4eaff94a2bbf3cf2852 (commit)
discards 146820e013003c0c2a19a322ae0a1cdf4fcc22ce (commit)
via 24df40f76bb9c9ed10ccb1e44668fa06c8d37132 (commit)
via 82fe97d436ab8a5ad726fba5464c341295c1ef8a (commit)
via 193f0510f3b516d77a0cdd4549dcf681dbcc9ed9 (commit)
via e9bb35128b80fe9b2f29229ffc390dbad7810958 (commit)
via 286625d4807fe44f5bf0a5334f6eeba08685a35f (commit)
via 0cfdff58c3de7266d8b799350fdff4fb3d61a4d5 (commit)
This update added new revisions after undoing existing revisions. That is
to say, the old revision is not a strict subset of the new revision. This
situation occurs when you --force push a change and generate a repository
containing something like this:
* -- * -- B -- O -- O -- O (598ffa3f99b7648d45e361bc91d36e9a8c70038d)
N -- N -- N (24df40f76bb9c9ed10ccb1e44668fa06c8d37132)
When this happens we assume that you've already had alert emails for all
of the O revisions, and so we here report only the revisions in the N
branch from the common base, B.
revisions in full, below.
commit 24df40f76bb9c9ed10ccb1e44668fa06c8d37132
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 27 18:25:48 2022 +0100
Fix `make html` in out-of-tree builds
Puts xsltproc path in XSLTPROC_COMMONOPTS
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 5aa799dbd..7ce5fb714 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -57,6 +57,7 @@ ifeq ($(XSLTPROCFLAGS),)
endif
XSLTPROC_COMMONOPTS= \
+ --path $(srcdir) \
--param section.autolabel 1 \
--param section.label.includes.component.label 1 \
--param chunk.section.depth 0 \
@@ -258,7 +259,6 @@ postgis-out.xml: postgis.xml Makefile
chunked-html: postgis-out.xml Makefile images $(XML_INPUTS)
$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
- --path $(srcdir) \
--output html/ \
$(CHUNK_HTML_DOCBOOK_XSL) \
Summary of changes:
doc/Makefile.in | 2 +-
doc/po/de/extras_tigergeocoder.xml.po | 18 ++++++++++--------
doc/po/de/faq.xml.po | 17 ++++++++++++-----
doc/po/ru/reference_accessor.xml.po | 11 ++++++-----
doc/po/ru/reference_constructor.xml.po | 11 ++++++-----
doc/po/ru/reference_editor.xml.po | 12 +++++++-----
doc/po/ru/reference_input.xml.po | 10 ++++++----
doc/po/ru/reference_management.xml.po | 11 ++++++-----
doc/po/ru/reference_measure.xml.po | 11 ++++++-----
doc/po/ru/reference_processing.xml.po | 11 ++++++-----
doc/po/ru/reference_relationship.xml.po | 10 ++++++----
doc/po/ru/reference_srs.xml.po | 10 ++++++----
doc/po/ru/reference_validation.xml.po | 10 ++++++----
13 files changed, 84 insertions(+), 60 deletions(-)
hooks/post-receive
