[postgis-tickets] [PostGIS] #5069: Schema qualify pg_catalog functions and tables
PostGIS trac at osgeo.org
Thu Jan 27 11:44:50 PST 2022
 Reporter:  robe                   |      Owner:  robe
     Type:  defect                 |     Status:  assigned
 Priority:  medium                 |  Milestone:  PostGIS 2.4.10
Component:  build/upgrade/install  |    Version:  2.4.x
 Keywords:                         |
 To better protect against
 https://wiki.postgresql.org/wiki/A_Guide_to_CVE-2018-1058:_Protect_Your_Search_Path
 during PostGIS install and upgrade.
 The focus is on CREATE EXTENSION / select postgis_extensions_upgrade()  /
 ALTER EXTENSION
 I think the tables to change are not necessary, although in theory we
 should be since someone could define such tables in the schema they
 install postgis (like a view that calls a function).  I will be replacing
 these as well to prevent a rogue actor forcing some change by replacing
 key tables/views in pg_catalog.
 Sadly I think this changes quite a few files.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5069>
