[postgis-tickets] [PostGIS] #5060: Add support for out-of-tree builds
PostGIS trac at osgeo.org
Thu Jan 27 13:37:20 PST 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I'm going to close this out as DONE.
 The gitlab-ci bot is building out-of-tree while keeping the source tree
 READ-ONLY.
 Some build targets are still failing but none of them is performed by a
 bot.
 Please file separate tickets as you see such cases. I've started with
 #5067
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5060#comment:14>
