[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-397-g3f8705564
git at osgeo.org
git at osgeo.org
Fri Jan 28 06:12:04 PST 2022
the project "PostGIS".
via 3f8705564479f88da266e9f3384f2c646180ef94 (commit)
via afcf9cde39fcf905c17f7df8a445e58fcdc6b0c8 (commit)
from 0a74375ea8600c6053e399fea0e5a823bc422aaa (commit)
revisions in full, below.
commit 3f8705564479f88da266e9f3384f2c646180ef94
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jan 28 14:52:07 2022 +0100
Fix broken translations
Closes #5071
diff --git a/doc/po/ko_KR/reference_sfcgal.xml.po b/doc/po/ko_KR/reference_sfcgal.xml.po
index ef47d9827..ebdb5af90 100644
--- a/doc/po/ko_KR/reference_sfcgal.xml.po
+++ b/doc/po/ko_KR/reference_sfcgal.xml.po
@@ -58,7 +58,7 @@ msgstr "postgis_sfcgal_version"
#: reference_sfcgal.xml:21
#, fuzzy, no-c-format
msgid "<refpurpose>Returns the version of SFCGAL in use</refpurpose>"
-msgstr "실행중인 SFCGAL의 버전을 반환합니다."
+msgstr "<refpurpose>실행중인 SFCGAL의 버전을 반환합니다.</refpurpose>"
#. Tag: funcdef
#: reference_sfcgal.xml:27
@@ -82,7 +82,7 @@ msgstr "설명"
#: reference_sfcgal.xml:36
msgid "<para>Returns the version of SFCGAL in use</para>"
+msgstr "<para>실행중인 SFCGAL의 버전을 반환합니다.</para>"
#. Tag: para
#: reference_sfcgal.xml:38 reference_sfcgal.xml:109 reference_sfcgal.xml:202
diff --git a/doc/po/pt_BR/reference_sfcgal.xml.po b/doc/po/pt_BR/reference_sfcgal.xml.po
index afdc782a6..0f36ffde7 100644
--- a/doc/po/pt_BR/reference_sfcgal.xml.po
+++ b/doc/po/pt_BR/reference_sfcgal.xml.po
@@ -59,7 +59,7 @@ msgstr "postgis_sfcgal_version"
-msgstr "retorna a versão do SFCGAL em uso"
+msgstr "<refpurpose>retorna a versão do SFCGAL em uso</refpurpose>"
#. Tag: funcdef
@@ -83,7 +83,7 @@ msgstr "Descrição"
+msgstr "<para>retorna a versão do SFCGAL em uso</para>"
#. Tag: para
commit afcf9cde39fcf905c17f7df8a445e58fcdc6b0c8
Date: Fri Jan 28 13:25:50 2022 +0100
Add docs-localized top-level Makefile rule
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 371c56543..246a822ee 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -131,6 +131,9 @@ templategis-uninstall:
docs:
$(MAKE) -C doc html
+docs-localized: postgis_revision.h
+ $(MAKE) -C doc html-localized
docs-clean:
$(MAKE) -C doc clean
Summary of changes:
GNUmakefile.in | 3 +++
doc/po/ko_KR/reference_sfcgal.xml.po | 4 ++--
doc/po/pt_BR/reference_sfcgal.xml.po | 4 ++--
3 files changed, 7 insertions(+), 4 deletions(-)
hooks/post-receive
