[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-402-gc3be78ad4
git at osgeo.org
git at osgeo.org
Fri Jan 28 14:21:03 PST 2022
the project "PostGIS".
via c3be78ad402662d62a58f4c01e642fa5b4e4a1c8 (commit)
via 90c87959713beb7f06457b3da7fd9059601cda7c (commit)
from 0f2afd2ac3f1a1e8faddd8b4e1aa3df6301848a5 (commit)
revisions in full, below.
commit c3be78ad402662d62a58f4c01e642fa5b4e4a1c8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jan 28 14:21:00 2022 -0800
Add a NEWS entry for the new GEOS concave hull binding
diff --git a/NEWS b/NEWS
index d49a15be8..c413340a6 100644
--- a/NEWS
+++ b/NEWS
@@ -10,9 +10,10 @@ PostGIS 3.3.0dev
- GH655, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)
- GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
- #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
+ - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
* New features*
- - ST_Letters creates geometries that look like letters.
+ - ST_Letters creates geometries that look like letters
PostGIS 3.2.0 (Olivier Courtin Edition)
commit 90c87959713beb7f06457b3da7fd9059601cda7c
Date: Fri Jan 28 14:19:09 2022 -0800
ST_Letters function and documentation
Generates geometry that has the shapes of the
letters in the function arguments. Size is
scalable and start point is changeable. Hooks
are there for alterate fonts for the suitably
motivated.
index fd7a7474d..d49a15be8 100644
--- a/NEWS
+++ b/NEWS
@@ -11,10 +11,14 @@ PostGIS 3.3.0dev
+ * New features*
+ - ST_Letters creates geometries that look like letters.
2021/12/17
-This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher
-, and Proj 4.9+.
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+.
Additional features are enabled if you are running GEOS 3.9+
(and ST_MakeValid enhancements with 3.10+),
Proj 6.1+, and PostgreSQL 14+.
@@ -28,9 +32,11 @@ If you are running PG14+, you can reenable it by doing
ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
ADD FUNCTION 11 (geometry)
geometry_gist_sortsupport_2d (internal);
and then reindex your gist indexes.
To revert back to the old index behavior:
ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
DROP FUNCTION 11 (geometry);
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index a88e08363..e11d3acb7 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -93,6 +93,7 @@ IMAGES= \
../images/st_isvalid07.png \
../images/st_isvalid08.png \
../images/st_isvalid09.png \
+ ../images/st_letters01.png \
../images/st_linecrossingdirection01.png \
../images/st_linecrossingdirection02.png \
../images/st_linecrossingdirection03.png \
diff --git a/doc/html/image_src/st_letters01.wkt b/doc/html/image_src/st_letters01.wkt
new file mode 100644
index 000000000..f9e39c557
--- /dev/null
+++ b/doc/html/image_src/st_letters01.wkt
@@ -0,0 +1 @@
+Style1;MULTIPOLYGON(((74.3 173.3,113.5 173.3,111.7 171.5,75.5 82.7,75.5 26.8,77.3 25,41.2 25,43.2 26.8,43.2 82.7,6.8 171.5,5 173.3,44.2 173.3,42.4 171.5,51.2 148.8,59.3 120.3,67.5 149.4,76.1 171.5,74.3 173.3)),((143.4 141.6,145.6 141.6,147.8 141.4,150 141.2,152 141,154.3 140.6,156.3 140.2,158.1 139.7,160.1 139.1,161.9 138.5,163.7 137.7,165.5 136.9,167.1 136.1,168.7 135.1,170.3 134.1,171.7 132.9,173.1 131.7,174.6 130.5,175.8 129.1,177 127.7,178 126.1,179 124.5,180 122.9,181 121.3,181.8 119.5,182.6 117.6,183.2 115.6,183.8 113.6,184.2 111.6,184.6 109.6,184.8 107.4,185 105.2,185 102.8,185 63,185 60.6,184.8 58.4,184.6 56.1,184.2 54.1,183.8 52.1,183.4 50.1,182.8 48.1,182 46.3,181.2 44.5,180.4 42.9,179.4 41.3,178.4 39.7,177.2 38.3,176 36.9,174.8 35.4,173.3 34.2,171.9 33,170.3 32,168.9 30.8,167.3 30,165.5 29,163.9 28.2,162.1 27.4,160.3 26.6,158.5 26,156.5 25.4,154.5 25,152.4 24.6,150.2 24.2,148 24,145.8 24,143.6 24,141.4 24,139.2 24.2,137 24.4,134.8 24.6,132.8 25,130.7 25.4,128.7 26,126.7 2
6.6,124.9 27.2,123.1 28,121.3 28.8,119.7 29.8,118.1 30.8,116.5 31.8,115.1 32.8,113.7 34,112.3 35.2,111 36.7,109.8 38.1,108.8 39.5,107.8 41.1,106.8 42.7,105.8 44.5,105 46.3,104.2 48.1,103.6 50.1,103 52.1,102.6 54.1,102.2 56.3,102 58.6,101.8 60.8,101.8 63,101.8 102.8,101.8 105.2,102 107.4,102.2 109.6,102.6 111.6,103 113.6,103.4 115.6,104 117.6,104.8 119.5,105.6 121.3,106.4 122.9,107.4 124.5,108.4 126.1,109.6 127.5,110.8 128.9,112.1 130.3,113.5 131.5,114.9 132.7,116.5 133.7,117.9 134.7,119.7 135.7,121.3 136.7,123.1 137.5,124.9 138.3,126.7 138.9,128.7 139.5,130.5 140.2,132.5 140.6,134.8 141,136.8 141.2,139 141.4,141.2 141.6,143.4 141.6),(153.2 103.2,150.2 108.6,143.6 110.6,136.8 108.8,133.8 103.2,133.8 63,136.6 57.6,143.2 55.5,149.8 57.4,153.2 63,153.2 103.2)))
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 36adb4366..5daa9d598 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1200,5 +1200,49 @@ FROM admin0 WHERE name = 'Canada'
+ <refentry id="ST_Letters">
+ <refnamediv>
+ <refname>ST_Letters</refname>
+ <refpurpose>Returns the input letters rendered as geometry with a default start position at the origin and default text height of 100.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_Letters</function></funcdef>
+ <paramdef><type>text</type> <parameter> letters</parameter></paramdef>
+ <paramdef choice="opt"><type>double precision</type> <parameter> text_height=100.0</parameter></paramdef>
+ <paramdef choice="opt"><type>geometry</type> <parameter> start_position=POINT(0 0)</parameter></paramdef>
+ <paramdef choice="opt"><type>json</type> <parameter> font</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Uses a built-in font to render out a string as a multipolygon geometry. The default text height is 100.0, the distance from the bottom of a descender to the top of a capital. The default start position places the start of the baseline at the origin. Over-riding the font involves passing in a json map, with a character as the key, and base64 encoded TWKB for the font shape, with the fonts having a height of 1000 units from the bottom of the descenders to the tops of the capitals.
+ </para>
+ <para>Availability: 3.3.0</para>
+ </refsection>
+ <refsection>
+ <title>Example: Generating the word 'Yo'</title>
+ <programlisting>SELECT ST_AsText(ST_Letters('Yo'), 1);</programlisting>
+ <informalfigure>
+ <mediaobject>
+ <imageobject>
+ <imagedata fileref="images/st_letters01.png" />
+ </imageobject>
+ <caption><para>Letters generated by ST_Letters</para></caption>
+ </mediaobject>
+ </informalfigure>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_AsTWKB" /></para>
+ </refsection>
+ </refentry>
</sect1>
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 1f20e43c0..f64577c97 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6726,8 +6726,8 @@ CREATE OR REPLACE FUNCTION ST_3DLineInterpolatePoint(geometry, float8)
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_LOW;
--- moved to separate file cause its invovled
+-- moved to separate file cause its involved
#include "postgis_spgist.sql.in"
+#include "postgis_letters.sql"
COMMIT;
diff --git a/postgis/postgis_letters.sql b/postgis/postgis_letters.sql
index 000000000..c8d66f944
--- /dev/null
+++ b/postgis/postgis_letters.sql
@@ -0,0 +1,148 @@
+CREATE OR REPLACE FUNCTION ST_Letters(letters text, text_height double precision DEFAULT 100, start_position geometry DEFAULT 'POINT(0 0)', font json DEFAULT NULL)
+RETURNS geometry
+AS
+DECLARE
+ letterarray text[];
+ letter text;
+ geom geometry;
+ prevgeom geometry = NULL;
+ adjustment float8 = 0.0;
+ position float8 = 0.0;
+ width float8;
+ m_width float8;
+ spacing float8;
+ dist float8;
+ wordarr geometry[];
+ wordgeom geometry;
+ -- geometry has been run through replace(encode(st_astwkb(geom),'base64'), E'\n', '')
+ font_default_height float8 = 1000.0;
+ font_default json = '{
+ "!":"BgACAQhUrgsTFOQCABQAExELiwi5AgAJiggBYQmJCgAOAg4CDAIOBAoEDAYKBgoGCggICAgICAgGCgYKBgoGCgQMBAoECgQMAgoADAIKAAoADAEKAAwBCgMKAQwDCgMKAwoFCAUKBwgHBgcIBwYJBgkECwYJBAsCDQILAg0CDQANAQ0BCwELAwsDCwUJBQkFCQcHBwcHBwcFCQUJBQkFCQMLAwkDCQMLAQkACwEJAAkACwIJAAsCCQQJAgsECQQJBAkGBwYJCAcIBQgHCAUKBQoDDAUKAQwDDgEMAQ4BDg==",
+ "&":"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",
+ "\"":"BgACAQUmwguEAgAAkwSDAgAAlAQBBfACAIACAACTBP8BAACUBA==",
+ "''":"BgABAQUmwguEAgAAkwSDAgAAlAQ=",
+ "(":"BgABAUOQBNwLDScNKw0rCysLLwsxCTEJMwc1BzcHNwM7AzsDPwE/AEEANwI1AjMEMwIzBjEGLwYvCC0ILQgrCCkKKQonCicMJbkCAAkqCSoHLAksBywFLgcuBS4FMAMwAzADMgEwATQBMgA0ADwCOgI6BDoEOAY4BjYINgg2CjQKMgoyCjIMMAwwDi7AAgA=",
+ ")":"BgABAUMQ3Au6AgAOLQwvDC8KMQoxCjEKMwg1CDUGNQY3BDcEOQI5AjkAOwAzATEBMQExAy8DLwMvBS8FLQctBS0HKwktBykJKwkpswIADCYKKAooCioIKggsCC4ILgYwBjAGMgQ0AjQCNAI2ADgAQgFAAz4DPAM8BzgHOAc2CTQJMgsyCzALLg0sDSoNKg==",
+ "+":"BgABAQ3IBOwGALcBuAEAANUBtwEAALcB0wEAALgBtwEAANYBuAEAALgB1AEA",
+ "/":"BgABAQVCAoIDwAuyAgCFA78LrQIA",
+ "4":"BgABAhDkBr4EkgEAEREApwJ/AADxARIR5QIAEhIA9AHdAwAA7ALIA9AG6gIAEREA8QYFqwIAAIIDwwH/AgABxAEA",
+ "v":"BgABASDmA5AEPu4CROwBExb6AgAZFdMC0wgUFaECABIU0wLWCBcW+AIAExVE6wEEFQQXBBUEFwQVBBUEFwQVBBUEFwQVBBUEFwQXBBUEFwYA",
+ ",":"BgABAWMYpAEADgIOAgwCDgQMBAoGDAYKBgoICAgICAgICAoGCgYKBAoEDAQKBAoCDAIKAgwCCgAKAAwACgEMAQoBCgMMAwoDCgUKBQgFCgUIBwYJCAcGCQYJBAsGCQQLAg0CCwINAg0AAwABAAMAAwADAQMAAwADAAMBBQAFAQcBBwEHAwcBCQMJAQsDCwMLAw0FDQMNBQ8FDwURBxMFEwkTBxcJFwkXswEAIMgBCQYJBgkGBwYJCAcIBQgHCgUKBQoFDAEMAwwBDgEOABA=",
+ "-":"BgABAQUq0AMArALEBAAAqwLDBAA=",
+ ".":"BgABAWFOrAEADgIOAg4CDgQMBAoGDAYKBgoICAgKCAgIBgoGCgYKBgoEDAQKBAwECgIMAAwCDAAMAAwBCgAMAQoDDAMKAwoDCgUKBQgFCgUIBwgJBgcICQYJBgsGCQQLAg0CDQINAA0ADQENAQ0BCwMNAwkFCwUJBQkHBwcJBwUHBwkFCQUJBQkDCwMJAwsDCQELAAsBCwALAAsCCQALAgkECwQJBAkECQYJBgcGBwgJBgcKBQgHCgUKBQwFCgEOAwwBDgEOAA4=",
+ "0":"BgABAoMB+APaCxwAHAEaARoDFgMYBRYFFAcUBxIJEgkQCRALEAsOCwwNDA0MDQoPCg0IDwgPBhEGDwYRBA8EEQIRAhMCEQITABMA4QUAEQETAREBEQMRAxEFEQURBREHDwkPBw8JDwsNCw0LDQ0NDQsNCw8JEQkRCREJEwcTBxUFFQUVAxUDFwEXARkAGQAZAhcCFwQXBBUGEwYTCBMIEQoRCg8KDwoPDA0MDQ4NDgsOCQ4JEAkQBxAHEAUSBRIDEgMSAxIDEgESARQAEgDiBQASAhQCEgISBBIEEgYSBhIGEggQChAIEAoQDBAMDgwODg4ODA4MEgwQChIKEggUCBQIFgYWBBYGGAQYAhgCGgILZIcDHTZBEkMRHTUA4QUeOUITRBIePADiBQ==",
+ "2":"BgABAWpUwALUA44GAAoBCAEKAQgDBgMGBQYFBgUEBwQFBAUCBwIHAgUABwAHAAUBBwMFAQcFBQMHBQUHBQcFBwMJAwkBCQELAQsAC68CAAAUAhIAFAISBBQCEgQUBBIEEgYUCBIGEAgSChAKEAoQDBAMDg4ODgwQDBIMEgoSChQIFggWCBgGGAQaAhwCHAIWABQBFgEUARQDFAMSAxQFEgUSBxIHEAkQCRALDgsODQ4NDA8KDwwRCBMKEwgTBhUGFwQXBBcEGwAbABsAHQEftwPJBdIDAACpAhIPzwYAFBIArgI=",
+ "1":"BgABARCsBLALAJ0LEhERADcA2QEANwATABQSAOYIpwEAALgCERKEBAASABER",
+ "3":"BgABAZ0B/gbEC/sB0QQOAwwBDAMMAwwFCgMKBQoFCgUIBwoFCAcICQgJBgkICQYLCAsECwYLBA0GDwINBA8CDwQRAhECEQITABUCFQAVAH0AEQETAREBEQETAxEDEQURBREFDwcRBw8JDwkNCQ8LDQsNDQsNCw0LDwsPCREJEQcRBxMFFQUVBRUDFwEXARkAGQAZAhkCFwQVBBUEEwYTCBEIEQgRCg0MDwoNDA0OCw4LDgkQCRAHEAkQBRAFEgUSAxIDFAMSAxYBFAEWARYAFqQCAAALAgkCCQQHAgcGBwYHBgUIBQYDCAMIAwYDCAEIAQgACAAIAAgCCAIIAgYCCAQIBAgGBgYEBgQIBAoCCgAKAAwAvAEABgEIAAYBBgMGAwQDBgMEBQQDBAUCBQQFAgUABwIFAJkBAACmAaIB3ALbAgAREQDmAhIRggYA",
+ "5":"BgABAaAB0APgBxIAFAESABIBEgMSARADEgMQAxIFEAcOBRAHDgkOCQ4JDgsMCwwLCgsKDQoPCA0IDwgPBhEEEwYTAhMEFwIXABcAiQIAEwETABEBEQMTAxEDDwMRBQ8FDwUPBw8JDQcNCQ0LDQsLCwsNCw0JDwkPCREHEQcTBxMFEwMVAxcDGQEZARkAFwAVAhUCFQQTBBMGEwYRCBEIDwoPCg8KDQwNDA0MCw4LDgkOCRAJEAcOBxAHEgUQBRIDEAMSAxIBEgEUARIAFLgCAAAFAgUABQIFBAUCBQQDBAUEAwYDBgMIAwgBCAEIAQoACAAIAgYACAQGAgQEBgQEBAQGBAQCBgIGAgYCBgIIAAYA4AEABgEIAAYBBgMGAQQDBgMEAwQFBAMCBQQFAgUABwIFAPkBAG+OAQCCBRESAgAAAuYFABMRAK8CjQMAAJ8BNgA=",
+ "7":"BgABAQrQBsILhQOvCxQR7wIAEhK+AvYIiwMAAKgCERKwBgA=",
+ "6":"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",
+ "8":"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",
+ "9":"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",
+ ":":"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",
+ "x":"BgABARHmAoAJMIMBNLUBNrYBMIQB1AIA9QG/BI4CvwTVAgA5hgFBwAFFxwE1fdUCAI4CwATzAcAE1AIA",
+ ";":"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",
+ "=":"BgACAQUawAUA5gHEBAAA5QHDBAABBQC5AgDsAcQEAADrAcMEAA==",
+ "B":"BgABA2e2BMQLFgAUARQBFAEUAxIDEgUSBRIFEAcQBxAJDgkOCQ4LDgsMCwwNDA0KDQgNCg0IDwYPBg8GDwQRBBEEEQIRAhMAEwAHAAkABwEHAAkBCQAHAQkBCQEHAQkBCQMJAwcDCQMJAwkFBwUJAwkHCQUHBQkHCQcJBwcHBwkHBwcJBwsHCQUQBQ4FDgcOCQ4JDAkMCwoNCg0IDwgRBhMEFQQXAhcCGwDJAQEvAysFJwklDSMPHREbFRkXFRsTHw8fCyUJJwcrAy0B6wMAEhIAoAsREuYDAAiRAYEElgEAKioSSA1EOR6JAQAA0wEJkAGPBSwSEiwAzAETKikSjwEAAMUCkAEA",
+ "A":"BgABAg/KBfIBqQIAN98BEhHzAgAWEuwCngsREvwCABMR8gKdCxIR8QIAFBI54AEFlwGCBk3TA6ABAE3UAwMA",
+ "?":"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",
+ "C":"BgABAWmmA4ADAAUCBQAFAgUEBQIDBAUEAwQDBgMEAQYDBgEGAAgBBgDWAgAAwQLVAgATABMCEQITBBEEEQQRBhEIEQgPCA8KDwoNCg0MDQwNDAsOCw4LDgkOCxAHEAkQBxIHEgUSBRIDEgEUARIBFAAUAMIFABQCFAISBBQEEgQSBhIIEggSCBAKEAoQCg4MDgwODA4ODA4MDgwQDA4KEggQChIIEggSBhIGFAQSAhQCEgIUAMYCAADBAsUCAAUABwEFAAUBBQMDAQUDAwMDAwMFAQMDBQEFAAUBBwAFAMEF",
+ "L":"BgABAQmcBhISEdkFABIQALQLwgIAAIEJ9AIAAK8C",
+ "D":"BgABAkeyBMQLFAAUARIBFAESAxIDEgMSBRIFEAcQBxAHDgkOCQ4LDgsMCwwNDA0KDwoPCg8IDwgRCBEGEwQTBBMEEwIVAhUAFwDBBQAXARcBFwMTAxUDEwUTBxEHEQcPCQ8JDwkNCw0LCwsLDQsNCQ0JDQcPBw8HDwcRBREFEQMRAxEDEwERARMBEwDfAwASEgCgCxES4AMACT6BAxEuKxKLAQAAvwaMAQAsEhIsAMIF",
+ "F":"BgABARGABoIJ2QIAAIECsgIAEhIA4QIRErECAACvBBIR5QIAEhIAsgucBQASEgDlAhES",
+ "E":"BgABARRkxAuWBQAQEgDlAhES0QIAAP0BtgIAEhIA5wIRFLUCAAD/AfACABISAOUCERLDBQASEgCyCw==",
+ "G":"BgABAZsBjgeIAgMNBQ8FDQUNBQ0HCwcNBwsHCwkLCQsJCwsJCwsLCQsJDQkLBw0HDwcNBw8FDwUPAw8DEQMPAxEBEQERARMBEQAXABUCFwIVAhMEFQQTBhMGEwYRCBEIDwoRCg8KDwwNDA0MDQ4LDgkQCRAJEAcQBxIFEgUUBRQDFAMUARYBFgEYAMoFABQCFAASBBQCEgQSBBIEEgYSBhAGEAgQCBAKDgoOCg4MDgwMDgwOChAKEAoSCBIIFAgUBhQEGAYWAhgEGAIaAOoCAAC3AukCAAcABwEFAQUBBQMFAwMFAwUDBQEFAQcBBQEFAQUABwAFAMUFAAUCBwIFAgUCBQQFBAMGBQYDBgUGAwgDBgMIAQgDCAEIAQoBCAEIAAgACgAIAAgCCAIIAggECgQGBAgECAYIBgC6AnEAAJwCmAMAAJcF",
+ "H":"BgABARbSB7ILAQAAnwsSEeUCABISAOAE5QEAAN8EEhHlAgASEgCiCxEQ5gIAEREA/QPmAQAAgAQPEOYCABER",
+ "I":"BgABAQmuA7ILAJ8LFBHtAgAUEgCgCxMS7gIAExE=",
+ "J":"BgABAWuqB7ILALEIABEBEwERAREDEwMRAxEFEQURBw8HEQcPCQ0LDwsNCw0NDQ0LDwsPCxEJEQkTCRMJFQcVBxcFFwMZAxsBGwEbAB8AHQIbAhsEGQYXBhcGFQgTCBMKEwoRDA8KDwwNDA0OCw4LDgkQCRAJEAcQBRIFEgUSAxQDEgESARIBFAESABIAgAEREtoCABERAn8ACQIHBAcEBwYHBgUIBQoDCgMKAwoDDAEKAQwBCgEMAAwACgAMAgoCDAIKBAoECgYKBggGBgYGCAQGBAgCCgAIALIIERLmAgAREQ==",
+ "M":"BgACAQRm1gsUABMAAAABE5wIAQDBCxIR5QIAEhIA6gIK5gLVAe0B1wHuAQztAgDhAhIR5QIAEhIAxAsUAPoDtwT4A7YEFgA=",
+ "K":"BgABAVXMCRoLBQsDCQMLAwsDCwMLAwsBCwELAQsBCwELAQ0ACwELAAsADQALAg0ACwILAA0CCwILAgsCDQQLBAsECwYNBAsGCwYLCAsGCwgJCgsICQoJCgkMCQwJDAkOCRALEAkQCRKZAdICUQAAiwQSEecCABQSAKALExLoAgAREQC3BEIA+AG4BAEAERKCAwAREdkCzQXGAYUDCA0KDQgJCgkMBwoFDAUMAQwBDgAMAg4CDAQOBAwGDghmlQI=",
+ "O":"BgABAoMBsATaCxwAHAEaARoDGgMYBRYFFgcWBxQJEgkSCRILEAsODQ4NDg0MDwoNDA8KDwgPCBEIDwYRBg8GEQQRAhMCEQITABMA0QUAEQETAREBEQMTBREFEQURBxEHDwcRCQ8LDQsPCw0NDQ0NDwsPCw8LEQkTCRMJEwkVBxUHFwUXAxkDGQEbARsAGwAZAhkCGQQXBhcGFQYVCBUIEwoRChEMEQoRDA8MDQ4NDg0OCxAJEAsQCRAHEgcSBxIFFAMSAxIDEgEUARIAEgDSBQASAhQCEgISBBIEEgYSBhIIEggQCBAKEgwODBAMEA4ODg4QDhIMEAwSChQKFAgUCBYIFgYYBBoGGgQcAh4CHgILggGLAylCWxZbFSlBANEFKklcGVwYKkwA0gU=",
+ "N":"BgABAQ+YA/oEAOUEEhHVAgASEgC+CxQAwATnBQDIBRMS2AIAExEAzQsRAL8ElgU=",
+ "P":"BgABAkqoB5AGABcBFQEVAxMDEwMTBREHEQcRBw8JDwkNCQ0LDQsNCwsNCw0JDQkNCQ8HDwcPBxEFEQURAxEDEQMTAREBEwETAH8AAIMDEhHlAgASEgCgCxES1AMAFAAUARIAFAESAxIDEgMSAxIFEAUQBRAHDgkOCQ4JDgsMCwwNDA0KDQoNCg8IDwgRCBEGEwQTBBUEFQIXAhkAGQCzAgnBAsoCESwrEn8AANUDgAEALBISLgDYAg==",
+ "R":"BgABAj9msgsREvYDABQAFAESARQBEgESAxIDEgUSBRAFEAcQBw4JDgkOCQ4LDAsMDQwLCg0KDwoNCA8IDwgPBhEEEwYTAhMEFQIXABcAowIAEwEVARMDEwMTBRMFEQcTBxELEQsRDQ8PDREPEQ0VC8QB/QMSEfkCABQSiQGyA3EAALEDFBHnAgASEgCgCwnCAscFogEALhISLACqAhEsLRKhAQAApQM=",
+ "Q":"BgABA4YBvAniAbkB8wGZAYABBQUFAwUFBQUHBQUDBwUFBQcFBQMHBQcDBwUJAwcDCQMJAwkDCQMJAQsDCwMLAQsDCwENAw0BDQEPAA8BDwAPABsAGwIZAhcEGQQXBBUGFQgVCBMIEQoTChEKDwwPDA8ODQ4NDgsQCxAJEAkQBxIHEgUSBRQFFAMUARQDFAEWABYAxgUAEgIUAhICEgQSBBIGEgYSCBIIEAgQChIMDgwQDBAODg4OEA4SDBAMEgoUChQIFAgWCBYGGAQaBhoEHAIeAh4CHAAcARoBGgMaAxgFFgUWBxYHFAkSCRIJEgsQCw4NDg0ODQwPCg0MDwoPCA8IEQgPBhEGDwYRBBECEwIRAhMAEwC7BdgBrwEImQSyAwC6AylAWxZbFSk/AP0BjAK7AQeLAoMCGEc4J0wHVBbvAaYBAEM=",
+ "S":"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",
+ "V":"BgABARG2BM4DXrYEbKwDERL0AgAVEesCnQsSEfsCABQS8QKeCxES8gIAExFuqwNgtQQEAA==",
+ "T":"BgABAQskxAv0BgAAtQKVAgAA+wgSEeUCABISAPwImwIAALYC",
+ "U":"BgABAW76B7ALAKMIABcBFwMXARUFFQUTBxMHEwkRCREJEQsPDQ0LDw0NDwsPCw8LEQkPCRMJEQcTBxMFEwUVBRUDEwMXARUBFQEXABUAEwIVAhMCFQQTBBUEEwYTBhMIEwgRChEIEQwRDA8MDw4PDg0OCxANEAsSCRIJEgcUBxQHFAMWBRYBGAEYARgApggBAREU9AIAExMAAgClCAALAgkECQQHBAcIBwgHCAUKBQoDCgMKAwwBCgEMAQwADAAMAgoCDAIKAgoECgQKBggGCAYICAYKBAgCCgIMAgwApggAARMU9AIAExM=",
+ "X":"BgABARmsCBISEYkDABQSS54BWYICXYkCRZUBEhGJAwAUEtYCzgXVAtIFExKIAwATEVClAVj3AVb0AVKqAREShgMAERHXAtEF2ALNBQ==",
+ "W":"BgABARuODcQLERHpAp8LFBHlAgASEnW8A2+7AxIR6wIAFBKNA6ALERKSAwATEdQB7wZigARZ8AIREugCAA8RaKsDYsMDXsoDaqYDExLqAgA=",
+ "Y":"BgABARK4BcQLhgMAERHnAvMGAKsEEhHnAgAUEgCsBOkC9AYREoYDABERWOEBUJsCUqICVtwBERI=",
+ "Z":"BgABAQmAB8QLnwOBCaADAADBAusGAMgDggmhAwAAwgLGBgA=",
+ "`":"BgABAQfqAd4JkQHmAQAOlgJCiAGpAgALiwIA",
+ "c":"BgABAW3UA84GBQAFAQUABQEFAwMBBQMDAwMDAwUBAwMFAQUABQEHAAUAnQMABQIFAAUCBQQFAgMEBQQDBAMGAwQBBgMGAQYABgEGAPABABoMAMsCGw7tAQATABMCEwARAhMEEQIPBBEEDwQPBg8IDwYNCA0KDQoNCgsMCwwLDAkOCRAHDgcQBxIFEgUUBRQDFAEWAxgBGAAYAKQDABQCFAISBBQCEgYSBhAGEggQCBAIEAoQCg4MDAwODAwODAwKDgwQCg4IEAgQCBAIEAYSBhIGEgQSAhQCFAIUAOABABwOAM0CGQzbAQA=",
+ "a":"BgABApoB8AYCxwF+BwkHCQcJCQkHBwkHBwcJBQkFBwUJBQkFCQMHBQkDCQMJAwcDCQEHAQkBBwEJAQcABwAHAQcABQAHAAUBBQAFABMAEwITAhEEEwQPBBEGDwgPCA0IDwoLCg0KCwwLDAsMCQ4JDgkOBw4HEAcQBRAFEAUSAxADEgESAxIBFAESABQAFAISAhQCEgQSBBIEEgYSBhIIEAgQChAIDgwODA4MDg4MDgwODBAMEAoSCBIKEggUCBQGFgYWBBgEGAIaAhoAcgAADgEMAQoBCgEIAwgDBgUEBQQFBAcCBwIHAgkCCQAJAKsCABcPAMwCHAvCAgAUABYBEgAUARIDFAMQAxIDEAUSBQ4FEAcOCRAJDAkOCwwLDA0MCwoNCg8IDwgPCA8GEQYRBhMEEwIXAhUCFwAZAIMGFwAKmQLqA38ATxchQwgnGiMwD1AMUDYAdg==",
+ "b":"BgABAkqmBIIJGAAYARYBFgEUAxQDEgUSBRIFEAcQCQ4HDgkOCw4LDAsMDQoNCg0KDQgPBg8GDwYRBBEEEQQTBBECEwIVAhMAFQD/AgAZARcBFwEXAxUDEwUTBREFEQcPBw8JDwkNCQ0LDQsLCwsNCQ0JDQcPBw8HDwURAxEDEQMTAxMBEwMVARUAFQHPAwAUEgCWCxEY5gIAERkAowKCAQAJOvECESwrEn8AAJsEgAEALBISLgCeAw==",
+ "d":"BgABAkryBgDLAXAREQ8NEQ0PDREJDwkRBw8FDwURAw8DDwERAw8BEQEPACMCHwQfCB0MGw4bEhcUFxgVGhEeDSANJAkmBSgDKgEuAIADABYCFAIUAhQCFAQUBBIGEgYSBhAIEAgQCBAKDgoODAwMDAwMDgoOCg4KEAgQCBIGEgYSBhQEFgQWBBYCGAIYAHwAAKQCERrmAgARFwCnCxcADOsCugJGMgDmA3sAKxERLQCfAwolHBUmBSQKBAA=",
+ "e":"BgABAqMBigP+AgAJAgkCCQQHBAcGBwYFCAUIBQgDCgMIAQoDCAEKAQoACgAKAAoCCAIKAggECgQIBAgGCAYGBgQIBAoECAIKAAyiAgAAGQEXARcBFwMVBRMFEwURBxEHDwcPCQ8LDQkNCwsNCw0LDQkNBw8JDwcPBQ8FEQURAxEDEwMTAxMBFQAVARcALwIrBCkIJwwlDiESHxQbGBkaFR4TIA0iCyQJKAMqASwAggMAFAIUABIEFAISBBIEEgQSBhIGEAgQCBAIEAoODA4MDgwODgwQDBAKEAoSChIIFAgUCBYGGAQYBhoCGgQcAh4ALgEqAygFJgkkDSANHhEaFRgXFBsSHQ4fDCUIJwQpAi0AGQEXAxcDFQcTBRMJEQkPCw8LDQ0PDQsNDQ8LEQsRCxEJEwkTCRMJEwcTBxUHFQUVBRUHFQUVBRUHFwcVBRUHCs4BkAMfOEUURxEfMwBvbBhAGBwaBiA=",
+ "h":"BgABAUHYBJAGAAYBBgAGAQYDBgEEAwYDBAMEBQQDAgUEBQIFAAUCBQB1AAC5BhIT5wIAFhQAlAsRGOYCABEZAKMCeAAYABgBFgEWARQDFAMSBRIFEgUQBxAJDgcOCQ4LDgsMCwwNCg0KDQoNCA8GDwYPBhEEEQQRBBMEEQITAhUCEwAVAO0FFhPnAgAUEgD+BQ==",
+ "g":"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",
+ "f":"BgABAUH8A6QJBwAHAAUABwEFAQcBBQEFAwUDBQMDAwMDAwUDAwMFAQUAwQHCAQAWEgDZAhUUwQEAAOMEFhftAgAWFADKCQoSChIKEAoQCg4KDgwOCgwMDAoKDAwMCgwIDAgMCAwIDAYOCAwEDgYMBA4GDAIOBA4CDgQOAg4CDgAOAg4ADgC2AQAcDgDRAhkQowEA",
+ "i":"BgACAQlQABISALoIERLqAgAREQC5CBIR6QIAAWELyAoADgIOAgwEDgIKBgwGCgYKCAoGCAgICggIBggGCgYKBAoECgQMBAoCDAIMAgwCDAAMAAwADAEMAQoBDAMKAwoDCgUKBQgFCgUIBwgHCAcICQgJBgkECwQJBA0CCwANAA0ADQELAQ0BCwMJBQsFCQUJBwkFBwcHBwcJBQcFCQUJBQkDCQMLAwkBCwELAQsACwALAAsCCwILAgkCCwIJBAkECQQJBgcGCQYHCAcIBwgHCgUKBQwFCgMMAQwBDgEMAA4=",
+ "j":"BgACAWFKyAoADgIOAgwEDgIKBgwGCgYKCAoGCAgICggIBggGCgYKBAoECgQMBAoCDAIMAgwCDAAMAAwADAEMAQoBDAMKAwoDCgUKBQgFCgUIBwgHCAcICQgJBgkECwQJBA0CCwANAA0ADQELAQ0BCwMJBQsFCQUJBwkFBwcHBwcJBQcFCQUJBQkDCQMLAwkBCwELAQsACwALAAsCCwILAgkCCwIJBAkECQQJBgcGCQYHCAcIBwgHCgUKBQwFCgMMAQwBDgEMAA4BO+YCnwwJEQkRCQ8JDwsNCQ0LDQkLCwsJCQsLCQkLBwsHCwcLBwsFCwcNAwsFDQMLBQ0BDQMNAQ0DDQENAQ0ADQENAA0AVwAbDQDSAhoPQgAIAAgABgAIAgYCCAIGAgYEBgQGBAQEBAQEBgQEBAYCBgC4CRES6gIAEREAowo=",
+ "k":"BgABARKoA/QFIAC0AYoD5gIAjwK5BJICwwTfAgDDAbIDFwAAnwMSEeUCABISAJILERLmAgAREQCvBQ==",
+ "n":"BgABAW1yggmQAU8GBAgEBgQGBgYCCAQGBAYEBgQIAgYECAQGAggEBgIIBAgCCAQIAggCCAIIAgoACAIKAAgCCgAKAgoADAAKAgwAFgAWARQAFAEUAxQDFAMSAxIFEgUQBRIHEAkOBxAJDgsOCwwLDA0MDQoPCA8IEQgRBhEGEwYVBBUEFQIXAhkCGQDtBRQR5QIAFBAA/AUACAEIAQYBCAMGBQQFBgUEBwQFBAcCBwIHAgcCCQIHAAcACQAHAQcABwMHAQUDBwMFAwUFBQUDBQEFAwcBBwAHAPkFEhHjAgASEgDwCBAA",
+ "m":"BgABAZoBfoIJigFbDAwMCg4KDggOCA4IDgYQBhAGEAQQBBAEEAISAhACEgAmASQDJAciCyANHhEcFRwXDg4QDBAKEAwQCBAKEggSBhIGEgYSBBQEEgIUAhICFAAUABQBEgEUARIDEgMSAxIFEgUQBxAHEAcQBw4JDgkOCw4LDAsMDQoNCg8KDwgPCBEIEQYRBBMEEwQTAhMCFQAVAP0FEhHlAgASEgCCBgAIAQgBBgEGAwYFBgUEBQQHBAUEBwIHAgcCBwIJAAcABwAJAAcBBwEHAQUBBwMFAwUDBQMDBQMFAwUBBQEHAQcAgQYSEeUCABISAIIGAAgBCAEGAQYDBgUGBQQFBAcEBQQHAgcCBwIHAgkABwAHAAkABwEHAQcBBQEHAwUDBQMFAwMFAwUDBQEFAQcBBwCBBhIR5QIAEhIA8AgYAA==",
+ "l":"BgABAQnAAwDrAgASFgDWCxEa6gIAERkA0wsUFw==",
+ "y":"BgABAZ8BogeNAg8ZERkRFxEVExMVERUPFQ8XDRcLGQkZBxsFGwUdAR0BDQALAA0ADQINAAsCDQANAg0CDQILAg0EDQINBA0GDQQNBg0EDQYNCA0GDwgNCA0IDQgPCg0KDwwNDA8MDw4PDqIB7gEQDRALEAkQCQ4JEAcOBw4FDgUOAwwFDgMMAQwBDAEMAQwACgEKAAoACAIIAAgCCAIGAggCBgIGBAYCBgQEAgYEAqIBAQADAAEBAwADAAMABQADAAUAAwAFAAMABQAFAAMABQA3ABMAEwIRABECEwQRAg8EEQQPBBEGDwgNCA8IDQgNCg0MDQwLDAkOCw4JDgcQBxAHEgUSBRQFFAMWARgDGAEaABwA9AUTEuQCABEPAP8FAAUCBQAFAgUEBQIDBAUEAwQDBgMEAQYDBgEGAAgBBgCAAQAAvAYREuICABMPAP0K",
+ "q":"BgABAmj0A4YJFgAWARQAEgESAxADEAMOAw4FDgUMBQ4HDgcOBwwJDgmeAU4A2QwWGesCABYaAN4DAwADAAMBAwADAAUAAwADAAMABQAFAAUABwAHAQcACQAVABUCFQATAhUCEwQRAhMEEQQRBhEGDwgPCA8IDQoNDA0MCwwLDgkOCRAJEAkQBxIHEgUUBRYDFgMYARoBGgAcAP4CABYCFgIWBBYEFAQSBhQIEggSCBAKEgoQDA4MDgwODg4ODBAMDgwQChIIEAoSCBIGEgYUBhQEFAQWAhYCFgIWAApbkQYSKy4ReAAAjARTEjkRHykJMwDvAg==",
+ "p":"BgABAmiCBIYJFgAWARYBFAEWAxQDEgUUBRIFEgcSBxAJEAkQCQ4LDgsOCwwNDA0KDwoPCg8IEQgRCBEGEwQTBhMCFQQVAhUAFQD9AgAbARkBFwMXAxcDEwUTBxMHEQcRCQ8JDQsNCw0LCw0LDQkPCQ0JDwURBxEFEQURAxMDEQMTARUBEwEVARUBFQAJAAcABwAFAAcABQAFAAMAAwADAAUAAwIDAAMAAwIDAADdAxYZ6wIAFhoA2gyeAU0OCgwIDgoMCA4GDgYMBg4GDgQQBBAEEgQUAhQCFgIWAApcoQMJNB8qNxJVEQCLBHgALhISLADwAg==",
+ "o":"BgABAoMB8gOICRYAFgEWARQBFgMUAxIDFAUSBRIHEgcQBxAJEAkOCw4LDgsMDQwNCg8KDwoPCg8IEQgRBhMGEwQTBBMCFQIVABcAiwMAFwEVARUDEwMTAxMFEwcRBxEHDwkPCQ8LDQsNCw0NCw0LDwkNCw8HEQkPBxEHEQcRBRMFEwMTAxUDFQEVABUAFQAVAhUCFQITBBMEEwYTBhEGEQgRCA8KDwoPCg0KDQwNDAsOCw4JDgkQCRAJEgcSBxIFFAUUAxQDFgEWARYAFgCMAwAYAhYCFgQUBBQEFAYUCBIIEggQChAKEAwODA4MDg4MDgwQCg4KEgoQChIIEggSBhQGEgYUBBYEFAIWAhYCFgALYv0CHTZBFEMRHTcAjwMcNUITQhIiOACQAw==",
+ "r":"BgACAQRigAkQAA8AAAABShAAhAFXDAwODAwKDgoOCBAIDgYQBhAEEAQQBBAEEAISABACEAAQAA4BEAAQARADEAEQAxADEAUSBRIHFAcUCxQLFA0WDVJFsQHzAQsMDQwLCgkICwgLCAkGCQYJBAkGBwIJBAcCBwQHAAcCBwAFAgcABQAHAQUABQEFAQUBBQEDAQUBAwMDAQMDAwEAmwYSEeMCABISAO4IEAA=",
+ "u":"BgABAV2KBwGPAVANCQsHDQcNBw0FCwUNBQ0FDQMPAw8DEQMTARMBFQEVABUAFQITABMEEwITBBMEEQQRBhEGDwYRCA8KDQgPCg0MDQwLDAsOCRALDgcQBxIHEgUUBRQFFAMWAxgBGAEYARoA7gUTEuYCABMPAPsFAAcCBwIFBAcCBQYDBgUGAwgDBgMIAQgBCAEIAQoBCAAIAAoACAIIAggCCAIGBAgEBgQGBgYGBAYCBgQIAggACAD6BRES5AIAEREA7wgPAA==",
+ "s":"BgABAasC/gLwBQoDCgMMBQ4DDgUOBRAFEAUSBRAHEgcQCRIJEAkSCxALEAsQDRANDg0ODw4PDA8MDwoRChEIEwYTBBcCFQIXABkBGQEXAxcFFQUTBRMHEwcRCREJDwkNCQ8LDQ0LCwsNCw0JDQkPBw8HDwUPBREDEQMRAREDEQETABEBEwARABMADwIRABECEQIRBBMCEwQVBBUEFQYVBhMIFwgVChUKFQxgsAIIAwYDCAMKAQgDCAMKAQoDCgEKAwoBCgMKAQwDCgEKAwoBDAMKAQoBCgEMAQoACgEKAAoBCgAKAQgACgAIAQgABgoECAIKAgoCCgAMAQoBDAUEBwIHBAcEBwIHBAkECQQJBAkECQYLBAkGCwYJBgsGCwYJCAsGCwgJBgsICQgLCAkICwgJCgkKCQoJCgcKCQwHDAcMBwwFDAcMAw4FDAMOAw4BDgMQARAAEAESABIAEgIQAg4CDgIOBA4CDgQMBAwEDAQMBgoECgYKBgoGCgYIBggGCAgIBggGBgYIBgYGBgYGBgYGBAgGBgQIBAYECAQQChIIEggSBhIEEgQSBBQCFAISABQAEgASABIAEgESARIBEAEQAxIDDgMQAxADDgUOBQwDDAMMAwoDCAMIAQYBe6cCAwIDAgUAAwIFAgUCBwIFAgcCBQIHAgUCBwIHAAUCBwIHAgUABwIHAgcABQIHAAcCBwAFAgUABQIFAAUABQIDAAEAAQABAQEAAQEBAQEBAQEBAQEDAQEAAwEBAQMAAwEDAAMBAwADAQMAAwABAQMAAwADAAEAAwIBAAMCAQQDAgE=",
+ "t":"BgABAUe8BLACWAAaEADRAhsOaQANAA0ADwINAA0CDQANAg0CDQINBA0CCwYNBA0GCwYNBgsIDQgLCAsKCwgJDAsKCQwJDAkOCQ4HEAcSBxIHEgUUAOAEawAVEQDWAhYTbAAAygIVFOYCABUXAMUCogEAFhQA1QIVEqEBAADzAwIFBAMEBQQDBAMEAwYDBgMGAwYBCAEGAQgBBgEIAAgA",
+ "w":"BgABARz8BsAEINYCKNgBERLuAgARD+8B3QgSEc0CABQSW7YCV7UCFBHJAgASEpMC3AgREvACABERmAHxBDDaAVeYAxES7gIAEREo1QE81wIIAA==",
+ "z":"BgABAQ6cA9AGuQIAFw8AzAIaC9QFAAAr9wKjBuACABYQAMsCGQyZBgCaA9AG"
+BEGIN
+ IF font IS NULL THEN
+ font := font_default;
+ END IF;
+ -- For character spacing, use m as guide size
+ geom := ST_GeomFromTWKB(decode(font->>'m', 'base64'));
+ m_width := ST_XMax(geom) - ST_XMin(geom);
+ spacing := m_width / 12;
+ letterarray := regexp_split_to_array(replace(letters, ' ', E'\t'), E'');
+ FOREACH letter IN ARRAY letterarray
+ LOOP
+ geom := ST_GeomFromTWKB(decode(font->>(letter), 'base64'));
+ -- Chars are not already zeroed out, so do it now
+ geom := ST_Translate(geom, -1 * ST_XMin(geom), 0.0);
+ -- unknown characters are treated as spaces
+ IF geom IS NULL THEN
+ -- spaces are a "quarter m" in width
+ width := m_width / 3.5;
+ ELSE
+ width := (ST_XMax(geom) - ST_XMin(geom));
+ END IF;
+ geom := ST_Translate(geom, position, 0.0);
+ -- Tighten up spacing when characters have a large gap
+ -- between them like Yo or To
+ adjustment := 0.0;
+ IF prevgeom IS NOT NULL AND geom IS NOT NULL THEN
+ dist = ST_Distance(prevgeom, geom);
+ IF dist > spacing THEN
+ adjustment = spacing - dist;
+ geom := ST_Translate(geom, adjustment, 0.0);
+ END IF;
+ END IF;
+ prevgeom := geom;
+ position := position + width + spacing + adjustment;
+ wordarr := array_append(wordarr, geom);
+ END LOOP;
+ -- apply the start point and scaling options
+ wordgeom := ST_CollectionExtract(ST_Collect(wordarr));
+ wordgeom := ST_Translate(ST_Scale(wordgeom,
+ text_height/font_default_height, text_height/font_default_height),
+ ST_XMin(start_position), ST_YMin(start_position));
+ return wordgeom;
+END;
+LANGUAGE 'plpgsql'
+IMMUTABLE STRICT _COST_MEDIUM;
Summary of changes:
NEWS | 11 ++-
doc/html/image_src/Makefile.in | 1 +
doc/html/image_src/st_letters01.wkt | 1 +
doc/reference_constructor.xml | 44 +++++++++++
postgis/postgis.sql.in | 4 +-
postgis/postgis_letters.sql | 148 ++++++++++++++++++++++++++++++++++++
6 files changed, 205 insertions(+), 4 deletions(-)
create mode 100644 doc/html/image_src/st_letters01.wkt
create mode 100644 postgis/postgis_letters.sql
hooks/post-receive
