[postgis-tickets] [PostGIS] #5072: ST_GeomFromTWKB rounding issue with negative xyprecision
trac at osgeo.org
Fri Jan 28 14:53:54 PST 2022
Reporter: murdos | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: postgis | Version: 3.1.x
Keywords: |
Consider the following query:
select
ST_AsText(ST_GeomFromTWKB(ST_AsTWKB(inputwkt::geometry,
xyprecision, 5, 5, false, false))) as reverted_wkt_from_twkb,
xyprecision,
encode(ST_AsTWKB(inputwkt::geometry, xyprecision, 5, 5, false,
false), 'hex')
from (select 'POINT (12345678.12345678 -12345678.12345678)'::text as
inputwkt) xx
cross join generate_series(-5, -5) as xyprecision
With postgis 3.1.4 or 3.2.0 it returns:
POINT(12299999.999999998 -12299999.999999998) -5 9100f601f501}}}
With postgis 3.0.4 it returns:
POINT(12300000 -12300000) -5 9100f601f501
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5072>
