[postgis-tickets] [PostGIS] #5066: Can't build under mingw64
trac at osgeo.org
Fri Jan 28 17:29:18 PST 2022
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by robe):
no it doesn't need a suffix. I'm working on 3.0 branch right now and my
regress paths look like "C:/ming64gcc81/projects/postgis/postgis-
git/regress/00-regress-install/lib/postgis-3.0".
Oh I think I see the issue now. You see under mingw64, I have fstab which
makes my and winnies C:/ming64gcc81/projects/postgis
E:/ming64gcc81/projects/postgis
look like /projects/postgis/branches.
But the PostgreSQL testing environment is pure windows, doesn't use
mingw64.
Before the scripts would correctly resolve to the windows path, this seems
to have changed with your logic, so now it's using the mingw64 linux
pathing rules.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5066#comment:12>
