[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-409-gd137d9d6b
git at osgeo.org
git at osgeo.org
Sun Jan 30 15:27:37 PST 2022
the project "PostGIS".
via d137d9d6b97258024b7a4f8f27ba7de7b589bf3e (commit)
from 8fb375fb18d96ff0c11ec9a1fd55a5cdc0fc220f (commit)
revisions in full, below.
commit d137d9d6b97258024b7a4f8f27ba7de7b589bf3e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 00:27:08 2022 +0100
Fix structure of pt_BR translation
It still fail make check but with less errors
diff --git a/doc/po/pt_BR/reference_accessor.xml.po b/doc/po/pt_BR/reference_accessor.xml.po
index c02ee1777..7d20fd05c 100644
--- a/doc/po/pt_BR/reference_accessor.xml.po
+++ b/doc/po/pt_BR/reference_accessor.xml.po
@@ -80,8 +80,8 @@ msgid ""
"Returns the type of the geometry as a string. Eg: 'LINESTRING', 'POLYGON', "
"'MULTIPOINT', etc."
msgstr ""
-"<para>Retorna o tipo de geometria como uma string. Exemplos: 'LINESTRING', "
-"'POLÍGONO', 'MULTIPOINT', etc.</para>"
+"Retorna o tipo de geometria como uma string. Exemplos: 'LINESTRING', "
+"'POLÍGONO', 'MULTIPOINT', etc."
#. Tag: para
#: reference_accessor.xml:28
@@ -666,7 +666,7 @@ msgstr "ST_CoordDim"
#: reference_accessor.xml:220
#, fuzzy, no-c-format
msgid "Return the coordinate dimension of a geometry."
-msgstr "<para>Retorna a dimensão da coordenada do valor ST_Geometry.</para>"
+msgstr "Retorna a dimensão da coordenada do valor ST_Geometry."
#. Tag: funcprototype
#: reference_accessor.xml:225
@@ -682,7 +682,7 @@ msgstr ""
#: reference_accessor.xml:235
msgid "Return the coordinate dimension of the ST_Geometry value."
#. Tag: para
#: reference_accessor.xml:237
@@ -735,7 +735,7 @@ msgstr "ST_Dimension"
#: reference_accessor.xml:266
msgid "Returns the topological dimension of a geometry."
#: reference_accessor.xml:271
@@ -1025,7 +1025,7 @@ msgstr "ST_NumPoints"
msgid ""
"Returns a set of <varname>geometry_dump</varname> rows for the coordinates "
"in a geometry."
-msgstr "<para>Retorna um texto resumo dos conteúdos da geometria.</para>"
+msgstr "Retorna um texto resumo dos conteúdos da geometria."
#: reference_accessor.xml:378
@@ -1358,7 +1358,7 @@ msgstr "ST_NumPoints"
msgid ""
"Returns a set of <varname>geometry_dump</varname> rows for the segments in a "
"geometry."
#: reference_accessor.xml:464
@@ -3345,8 +3345,8 @@ msgid ""
"Return the M coordinate of a Point, or NULL if not available. Input must be "
"a Point."
msgstr ""
-"<para>Retorna a coordenada M do ponto, ou NULA se não estiver disponível. "
-"Entrada deve ser um ponto.</para>"
+"Retorna a coordenada M do ponto, ou NULA se não estiver disponível. "
+"Entrada deve ser um ponto."
#. Tag: para
#: reference_accessor.xml:1372
@@ -3507,7 +3507,7 @@ msgstr "ST_NDims"
#: reference_accessor.xml:1442
msgid "Returns the coordinate dimension of a geometry."
#: reference_accessor.xml:1447
@@ -4489,7 +4489,7 @@ msgstr "ST_Summary"
#: reference_accessor.xml:1980
msgid "Returns a text summary of the contents of a geometry."
#. Tag: funcsynopsis
#: reference_accessor.xml:1985
@@ -4511,7 +4511,7 @@ msgstr ""
#: reference_accessor.xml:2000
msgid "Returns a text summary of the contents of the geometry."
#. Tag: para
#: reference_accessor.xml:2002
@@ -4681,8 +4681,8 @@ msgid ""
"Return the X coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>Retorna a coordenada X do ponto, ou NULA se não estiver disponível. "
+"Retorna a coordenada X do ponto, ou NULA se não estiver disponível. "
#. Tag: para
#: reference_accessor.xml:2076
@@ -4777,8 +4777,8 @@ msgid ""
"Return the Y coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>Retorna a coordenada Y do ponto, ou NULA se não estiver disponível. "
+"Retorna a coordenada Y do ponto, ou NULA se não estiver disponível. "
#. Tag: para
#: reference_accessor.xml:2120
@@ -4863,8 +4863,8 @@ msgid ""
"Return the Z coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>Retorna a coordenada Z do ponto, ou NULA se não estiver disponível. "
+"Retorna a coordenada Z do ponto, ou NULA se não estiver disponível. "
#. Tag: para
#: reference_accessor.xml:2165
@@ -4992,1217 +4992,3 @@ msgstr ""
msgid ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
msgstr ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
-#~ msgid "Only works with POLYGON geometry types"
-#~ msgstr "Funciona somente com geometrias tipo POLÍGONO."
-#~ msgid ""
-#~ "Return the 1-based Nth geometry if the geometry is a GEOMETRYCOLLECTION, "
-#~ "(MULTI)POINT, (MULTI)LINESTRING, MULTICURVE or (MULTI)POLYGON, "
-#~ "POLYHEDRALSURFACE Otherwise, return NULL"
-#~ msgstr ""
-#~ "Retorna a geometria de 1-base Nth se a geometria é uma "
-#~ "GEOMETRYCOLLECTION, (MULTI)POINT, (MULTI)LINESTRING, MULTICURVE ou "
-#~ "(MULTI)POLYGON, POLYHEDRALSURFACE. Senão, retorna NULA. "
-#, fuzzy
-#~ msgid ""
-#~ "Returns the Nth interior linestring ring of the polygon geometry. Returns "
-#~ "NULL if the geometry is not a polygon or the given N is out of range. The "
-#~ "index starts at 1."
-#~ msgstr ""
-#~ "Retorna o anel linestring Nth interior do polígono. Retorna NULO se a "
-#~ "geometria não for um polígono ou o dado N está fora da extensão. index "
-#~ "começa em 1. "
-#~ msgid ""
-#~ ", <xref linkend=\"ST_Collect\"/>, <xref linkend=\"ST_Dump\"/>, <xref "
-#~ "linkend=\"ST_NumInteriorRing\"/>,"
-#~ msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Returns the last point of a LINESTRING as a POINT. Returns <varname>NULL</"
-#~ "varname> if the input is not a LINESTRING."
-#~ msgstr ""
-#~ "Retorna ao último ponto de uma <varname>LINESTRING</varname> geometria "
-#~ "como um <varname>PONTO</varname> ou <varname>NULO</varname> se o "
-#~ "parâmetro de entrada não é uma <varname>LINESTRING</varname>."
-#~ msgid ""
-#~ "postgis=# SELECT ST_AsText(ST_EndPoint('LINESTRING(1 1, 2 2, 3 3)'::"
-#~ "geometry));\n"
-#~ " st_astext\n"
-#~ "------------\n"
-#~ " POINT(3 3)\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ "postgis=# SELECT ST_EndPoint('POINT(1 1)'::geometry) IS NULL AS is_null;\n"
-#~ " is_null\n"
-#~ "----------\n"
-#~ " t\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ "--3d endpoint\n"
-#~ "SELECT ST_AsEWKT(ST_EndPoint('LINESTRING(1 1 2, 1 2 3, 0 0 5)'));\n"
-#~ " st_asewkt\n"
-#~ "--------------\n"
-#~ " POINT(0 0 5)\n"
-#~ "(1 row)"
-#~ msgstr ""
-#~ "geometry));\n"
-#~ " st_astext\n"
-#~ " POINT(3 3)\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ " is_null\n"
-#~ "----------\n"
-#~ " t\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "(1 row)"
-#~ msgid ""
-#~ "SELECT ST_AsText(ST_StartPoint('LINESTRING(0 1, 0 2)'::geometry));\n"
-#~ " st_astext\n"
-#~ " POINT(0 1)\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ "SELECT ST_StartPoint('POINT(0 1)'::geometry) IS NULL AS is_null;\n"
-#~ " is_null\n"
-#~ "----------\n"
-#~ " t\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ "--3d line\n"
-#~ "SELECT ST_AsEWKT(ST_StartPoint('LINESTRING(0 1 1, 0 2 2)'::geometry));\n"
-#~ " st_asewkt\n"
-#~ " POINT(0 1 1)\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ "-- circular linestring --\n"
-#~ "SELECT ST_AsText(ST_StartPoint('CIRCULARSTRING(5 2,-3 1.999999, -2 1, -4 "
-#~ "2, 5 2)'::geometry));\n"
-#~ " st_astext\n"
-#~ " POINT(5 2)"
-#~ msgstr ""
-#~ " st_astext\n"
-#~ " POINT(0 1)\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ " is_null\n"
-#~ "----------\n"
-#~ " t\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ "--3d line\n"
-#~ " st_asewkt\n"
-#~ "(1 row)\n"
-#~ "\n"
-#~ " st_astext\n"
-#~ " POINT(5 2)"
-#~ msgid ""
-#~ "<refpurpose>Returns the type of the geometry as a string. Eg: "
-#~ "'LINESTRING', 'POLYGON', 'MULTIPOINT', etc.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o tipo de geometria como uma string. Exemplos: "
-#~ "'LINESTRING', 'POLÍGONO', 'MULTIPOINT', etc.</refpurpose>"
-#~ msgid ""
-#~ "The inherent dimension of this Geometry object, which must be less than "
-#~ "or equal to the coordinate dimension."
-#~ msgstr ""
-#~ "A dimensão herdada desse objeto geométrico, o qual deve ser menor ou "
-#~ "igual à dimensão coordenada. "
-#~ msgid ""
-#~ "Returns the last point of a <varname>LINESTRING</varname> or "
-#~ "<varname>CIRCULARLINESTRING</varname> geometry as a <varname>POINT</"
-#~ "varname>."
-#~ msgstr ""
-#~ "Retorna ao último ponto de uma <varname>LINESTRING</varname> ou "
-#~ "<varname>CIRCULARLINESTRING</varname> geometria como um <varname>PONTO</"
-#~ "varname>."
-#~ msgid ""
-#~ "<funcdef>boolean <function>ST_EndPoint</function></funcdef> "
-#~ "<paramdef><type>geometry </type> <parameter>g</parameter></paramdef>"
-#~ msgstr ""
-#~ "<funcdef>booleana <function>ST_EndPoint</function></funcdef> "
-#~ "<paramdef><type>geometria </type> <parameter>g</parameter></paramdef>"
-#~ msgid ""
-#~ "Returns a line string representing the exterior ring of the "
-#~ "<varname>POLYGON</varname> geometry. Return NULL if the geometry is not a "
-#~ "polygon. Will not work with MULTIPOLYGON"
-#~ msgstr ""
-#~ "Retorna uma line string representando o anel exterior da geometria "
-#~ "<varname>POLÍGONO</varname>. Retorna NULA se a geometria não for um "
-#~ "polígono. Não funcionará com MULTIPOLÍGONO. "
-#~ msgid ""
-#~ "Returns <varname>TRUE</varname> if the argument is a collection "
-#~ "(<varname>MULTI*</varname>, <varname>GEOMETRYCOLLECTION</varname>, ...)"
-#~ msgstr ""
-#~ "Retorna <varname>VERDADEIRO</varname> se o argumento é uma coleção "
-#~ msgid "ST_IsValid"
-#~ msgstr "ST_IsValid"
-#~ msgid ""
-#~ "Returns <varname>true</varname> if the <varname>ST_Geometry</varname> is "
-#~ "well formed."
-#~ msgstr ""
-#~ "Retorna <varname>verdadeira</varname> se a <varname>ST_Geometry</"
-#~ "varname> é bem formada."
-#~ msgid ""
-#~ "<funcprototype> <funcdef>boolean <function>ST_IsValid</function></"
-#~ "funcdef> <paramdef><type>geometry </type> <parameter>g</parameter></"
-#~ "paramdef> </funcprototype> <funcprototype> <funcdef>boolean "
-#~ "<function>ST_IsValid</function></funcdef> <paramdef><type>geometry </"
-#~ "type> <parameter>g</parameter></paramdef> <paramdef><type>integer </type> "
-#~ "<parameter>flags</parameter></paramdef> </funcprototype>"
-#~ msgstr ""
-#~ "<funcprototype> <funcdef>booleana <function>ST_IsValid</function></"
-#~ "funcdef> <paramdef><type>geometria </type> <parameter>g</parameter></"
-#~ "paramdef> </funcprototype> <funcprototype> <funcdef>booleana "
-#~ "<function>ST_IsValid</function></funcdef> <paramdef><type>geometria </"
-#~ "type> <parameter>g</parameter></paramdef> <paramdef><type>inteiro </type> "
-#~ msgid ""
-#~ "Test if an ST_Geometry value is well formed. For geometries that are "
-#~ "invalid, the PostgreSQL NOTICE will provide details of why it is not "
-#~ "valid. For more information on the OGC's definition of geometry "
-#~ "simplicity and validity, refer to <link linkend=\"OGC_Validity\">"
-#~ "\"Ensuring OpenGIS compliancy of geometries\"</link>"
-#~ msgstr ""
-#~ "Testa se um valor ST_Geometry é bem formado. Para geometrias que são "
-#~ "inválidas, o PostgreSQL NOTICE irá fornecer detalhes da razão de não "
-#~ "serem válidas. Para maiores informações na definição OGC da simplicidade "
-#~ "e validade de geometrias, use <link linkend=\"OGC_Validity\">\"Ensuring "
-#~ "OpenGIS compliancy of geometries\"</link>"
-#~ msgid ""
-#~ "SQL-MM defines the result of ST_IsValid(NULL) to be 0, while PostGIS "
-#~ "returns NULL."
-#~ msgstr ""
-#~ "SQL-MM define o resultado da ST_IsValid(NULA) para ser 0, enquanto o "
-#~ "PostGIS retorna NULO."
-#~ msgid ""
-#~ "The version accepting flags is available starting with 2.0.0 and requires "
-#~ "GEOS >= 3.3.0. Such version does not print a NOTICE explaining the "
-#~ "invalidity. Allowed <varname>flags</varname> are documented in <xref "
-#~ "linkend=\"ST_IsValidDetail\"/>."
-#~ msgstr ""
-#~ "A versão que aceita bandeiras está disponível com a 2.0.0 e requer GEOS "
-#~ ">= 3.3.0. Tal versão não imprime um AVISO explicando a invalidade. As "
-#~ "<varname>bandeiras</varname> permitidas estão documentadas em <xref "
-#~ msgid "&sqlmm_compliant; SQL-MM 3: 5.1.9"
-#~ msgstr "&sqlmm_compliant; SQL-MM 3: 5.1.9"
-#~ msgid ""
-#~ "Neither OGC-SFS nor SQL-MM specifications include a flag argument for "
-#~ "ST_IsValid. The flag is a PostGIS extension."
-#~ msgstr ""
-#~ "Nem as especificações do OGC-SFS ou do SQL-MM incluem um argumento "
-#~ "bandeira para ST_IsValid. A bandeira é uma extensão do PostGIS. "
-#~ msgid ""
-#~ "SELECT ST_IsValid(ST_GeomFromText('LINESTRING(0 0, 1 1)')) As good_line,\n"
-#~ " ST_IsValid(ST_GeomFromText('POLYGON((0 0, 1 1, 1 2, 1 1, 0 0))')) "
-#~ "As bad_poly\n"
-#~ "--results\n"
-#~ "NOTICE: Self-intersection at or near point 0 0\n"
-#~ " good_line | bad_poly\n"
-#~ "-----------+----------\n"
-#~ " t | f"
-#~ msgstr ""
-#~ "As bad_poly\n"
-#~ "--results\n"
-#~ " t | f"
-#~ msgid ""
-#~ ", <xref linkend=\"ST_IsValidReason\"/>, <xref linkend=\"ST_IsValidDetail"
-#~ "\"/>, <xref linkend=\"ST_Summary\"/>"
-#~ msgstr ""
-#~ msgid "ST_IsValidReason"
-#~ msgstr "ST_IsValidReason"
-#~ msgid ""
-#~ "Returns text stating if a geometry is valid or not and if not valid, a "
-#~ "reason why."
-#~ msgstr ""
-#~ "Retorna texto declarando se uma geometria é válida ou não e se não for "
-#~ "válida, uma razão do porquê."
-#~ msgid ""
-#~ "<funcprototype> <funcdef>text <function>ST_IsValidReason</function></"
-#~ "funcdef> <paramdef><type>geometry </type> <parameter>geomA</parameter></"
-#~ "paramdef> </funcprototype> <funcprototype> <funcdef>text "
-#~ "<function>ST_IsValidReason</function></funcdef> <paramdef><type>geometry "
-#~ "</type> <parameter>geomA</parameter></paramdef> <paramdef><type>integer </"
-#~ "type> <parameter>flags</parameter></paramdef> </funcprototype>"
-#~ msgstr ""
-#~ "<funcprototype> <funcdef>texto <function>ST_IsValidReason</function></"
-#~ "funcdef> <paramdef><type>geometria </type> <parameter>geomA</parameter></"
-#~ "<function>ST_IsValidReason</function></funcdef> <paramdef><type>geometria "
-#~ "</type> <parameter>geomA</parameter></paramdef> <paramdef><type>inteiro </"
-#~ msgid ""
-#~ "Returns text stating if a geometry is valid or not an if not valid, a "
-#~ "reason why."
-#~ msgstr ""
-#~ msgid ""
-#~ "Useful in combination with ST_IsValid to generate a detailed report of "
-#~ "invalid geometries and reasons."
-#~ msgstr ""
-#~ "Vantajoso em combinação com ST_IsValid para gerar um relato detalhado das "
-#~ "geometrias inválidas e seus motivos."
-#~ msgid ""
-#~ "Allowed <varname>flags</varname> are documented in <xref linkend="
-#~ "\"ST_IsValidDetail\"/>."
-#~ msgstr ""
-#~ "As <varname>bandeiras</varname> permitidas estão documentadas em <xref "
-#~ msgid "Availability: 1.4 - requires GEOS >= 3.1.0."
-#~ msgstr "Disponibilidade: 1.4 - requer GEOS >= 3.1.0."
-#~ msgid ""
-#~ "Availability: 2.0 - requires GEOS >= 3.3.0 for the version taking "
-#~ "flags."
-#~ msgstr ""
-#~ "Disponibilidade: 2.0 - requer GEOS >= 3.3.0 para a versão pegando "
-#~ "bandeiras."
-#~ msgid ""
-#~ "--First 3 Rejects from a successful quintuplet experiment\n"
-#~ "SELECT gid, ST_IsValidReason(the_geom) as validity_info\n"
-#~ "FROM\n"
-#~ "(SELECT ST_MakePolygon(ST_ExteriorRing(e.buff), ST_Accum(f.line)) As "
-#~ "the_geom, gid\n"
-#~ "FROM (SELECT ST_Buffer(ST_MakePoint(x1*10,y1), z1) As buff, x1*10 + "
-#~ "y1*100 + z1*1000 As gid\n"
-#~ " FROM generate_series(-4,6) x1\n"
-#~ " CROSS JOIN generate_series(2,5) y1\n"
-#~ " CROSS JOIN generate_series(1,8) z1\n"
-#~ " WHERE x1 > y1*0.5 AND z1 < x1*y1) As e\n"
-#~ " INNER JOIN (SELECT "
-#~ "ST_Translate(ST_ExteriorRing(ST_Buffer(ST_MakePoint(x1*10,y1), z1)),y1*1, "
-#~ "z1*2) As line\n"
-#~ " FROM generate_series(-3,6) x1\n"
-#~ " CROSS JOIN generate_series(1,10) z1\n"
-#~ " WHERE x1 > y1*0.75 AND z1 < x1*y1) As f\n"
-#~ "ON (ST_Area(e.buff) > 78 AND ST_Contains(e.buff, f.line))\n"
-#~ "GROUP BY gid, e.buff) As quintuplet_experiment\n"
-#~ "WHERE ST_IsValid(the_geom) = false\n"
-#~ "ORDER BY gid\n"
-#~ "LIMIT 3;\n"
-#~ "\n"
-#~ " gid | validity_info\n"
-#~ "------+--------------------------\n"
-#~ " 5330 | Self-intersection [32 5]\n"
-#~ " 5340 | Self-intersection [42 5]\n"
-#~ " 5350 | Self-intersection [52 5]\n"
-#~ "\n"
-#~ " --simple example\n"
-#~ "SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 "
-#~ "150410)');\n"
-#~ "\n"
-#~ " st_isvalidreason\n"
-#~ "------------------\n"
-#~ " Valid Geometry"
-#~ msgstr ""
-#~ "FROM\n"
-#~ "LIMIT 3;\n"
-#~ "\n"
-#~ "\n"
-#~ "150410)');\n"
-#~ "\n"
-#~ msgid ", <xref linkend=\"ST_Summary\"/>"
-#~ msgstr ", <xref linkend=\"ST_Summary\"/>"
-#~ msgid "ST_IsValidDetail"
-#~ msgstr "ST_IsValidDetail"
-#~ msgid ""
-#~ "Returns a valid_detail (valid,reason,location) row stating if a geometry "
-#~ "is valid or not and if not valid, a reason why and a location where."
-#~ msgstr ""
-#~ "Retorna uma fila valid_detail (válida, motivo, localização) se uma "
-#~ "geometria é válida ou não e, se não for, uma razão do porquê e uma "
-#~ "localização."
-#~ msgid ""
-#~ "<funcprototype> <funcdef>valid_detail <function>ST_IsValidDetail</"
-#~ "function></funcdef> <paramdef><type>geometry </type> <parameter>geom</"
-#~ "parameter></paramdef> </funcprototype> <funcprototype> "
-#~ "<funcdef>valid_detail <function>ST_IsValidDetail</function></funcdef> "
-#~ "<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef> "
-#~ "<paramdef><type>integer </type> <parameter>flags</parameter></paramdef> </"
-#~ "funcprototype>"
-#~ msgstr ""
-#~ "<paramdef><type>geometria </type> <parameter>geom</parameter></paramdef> "
-#~ "<paramdef><type>inteiro </type> <parameter>flags</parameter></paramdef> </"
-#~ msgid ""
-#~ "Returns a valid_detail row, formed by a boolean (valid) stating if a "
-#~ "geometry is valid, a varchar (reason) stating a reason why it is invalid "
-#~ "and a geometry (location) pointing out where it is invalid."
-#~ msgstr ""
-#~ "Retorna uma linha valid_detail, formada por uma declaração booleana "
-#~ "(válida) se uma geometria é válida, uma declaração varchar (motivo) uma "
-#~ "razão de porquê é inválida e uma geometria (localização) pontuando onde "
-#~ "ela é inválida. "
-#~ msgid ""
-#~ "Useful to substitute and improve the combination of ST_IsValid and "
-#~ "ST_IsValidReason to generate a detailed report of invalid geometries."
-#~ msgstr ""
-#~ "Vantajoso para substituir e melhorar a combinação de ST_IsValid e "
-#~ "ST_IsValidReason para gerar um relato detalhado de geometrias inválidas."
-#~ msgid ""
-#~ "The 'flags' argument is a bitfield. It can have the following values:"
-#~ msgstr ""
-#~ "O argumento das \"bandeiras\" é um bitfield. Não pode ter os seguintes "
-#~ "valores: "
-#~ msgid ""
-#~ "1: Consider self-intersecting rings forming holes as valid. This is also "
-#~ "know as \"the ESRI flag\". Note that this is against the OGC model."
-#~ msgstr ""
-#~ "1: Considere anéis que tem auto intersecção formando buracos como "
-#~ "válidos. Isso também pode ser conhecido como \"a bandeira ESRI\". Note "
-#~ "que isso vai contra o modelo OGC. "
-#~ msgid "Availability: 2.0.0 - requires GEOS >= 3.3.0."
-#~ msgstr "Disponibilidade: 2.0.0 - requer GEOS >= 3.3.0."
-#~ msgid ""
-#~ "SELECT gid, reason(ST_IsValidDetail(the_geom)), "
-#~ "ST_AsText(location(ST_IsValidDetail(the_geom))) as location\n"
-#~ "FROM\n"
-#~ "LIMIT 3;\n"
-#~ "\n"
-#~ " gid | reason | location\n"
-#~ "------+-------------------+-------------\n"
-#~ " 5330 | Self-intersection | POINT(32 5)\n"
-#~ " 5340 | Self-intersection | POINT(42 5)\n"
-#~ " 5350 | Self-intersection | POINT(52 5)\n"
-#~ "\n"
-#~ "SELECT * FROM ST_IsValidDetail('LINESTRING(220227 150406,2220227 "
-#~ "150407,222020 150410)');\n"
-#~ "\n"
-#~ " valid | reason | location\n"
-#~ "-------+--------+----------\n"
-#~ " t | |"
-#~ msgstr ""
-#~ "FROM\n"
-#~ "LIMIT 3;\n"
-#~ "\n"
-#~ "\n"
-#~ "\n"
-#~ " t | |"
-#~ msgid ", <xref linkend=\"ST_IsValidReason\"/>"
-#~ msgstr ", <xref linkend=\"ST_IsValidReason\"/>"
-#~ msgid ""
-#~ "<refpurpose>Return the M coordinate of the point, or NULL if not "
-#~ "available. Input must be a point.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna a coordenada M do ponto, ou NULA se não estiver "
-#~ "disponível. Entrada deve ser um ponto.</refpurpose>"
-#~ msgid ""
-#~ "Returns coordinate dimension of the geometry as a small int. Values are: "
-#~ "2,3 or 4."
-#~ msgstr ""
-#~ "Retorna a dimensão coordenada da geometria como uma small int. Os valores "
-#~ "são: 2, 3 ou 4."
-#~ msgid ""
-#~ "If the geometry is a polygon or multi-polygon returns the number of rings."
-#~ msgstr ""
-#~ "Se a geometria for um polígono ou multi polígono, retorna o número de "
-#~ "anéis."
-#~ msgid ""
-#~ "If geometry is a GEOMETRYCOLLECTION (or MULTI*) return the number of "
-#~ "geometries, for single geometries will return 1, otherwise return NULL."
-#~ msgstr ""
-#~ "Se a geometria é uma GEOMETRYCOLLECTION (ou MULTI*), retorna o número de "
-#~ "geometria, para geometrias únicas retornará 1, senão retorna NULO. "
-#~ msgid ""
-#~ "Return the 1-based Nth geometry (face) if the geometry is a "
-#~ "POLYHEDRALSURFACE, POLYHEDRALSURFACEM. Otherwise, return NULL."
-#~ msgstr ""
-#~ "Retorna a geometria (face) de 1-base Nth se a geometria é uma "
-#~ "POLYHEDRALSURFACE, POLYHEDRALSURFACEM. Senão, retorna NULA. "
-#~ msgid ""
-#~ "Return the Nth point in the first LineString or circular LineString in "
-#~ "the geometry. Negative values are counted backwards from the end of the "
-#~ "LineString. Returns NULL if there is no linestring in the geometry."
-#~ msgstr ""
-#~ "Retorna o ponto Nth na primeira linestring ou linestring circular na "
-#~ "geometria. Valores negativos são contados tardiamente do fim da "
-#~ "linestring. Retorna NULA se não há uma linestring na geometria."
-#~ msgid "ST_SRID"
-#~ msgstr "ST_SRID"
-#~ msgid ""
-#~ "Returns the spatial reference identifier for the ST_Geometry as defined "
-#~ "in spatial_ref_sys table."
-#~ msgstr ""
-#~ "Retorna o identificador de referência espacial para a ST_Geometry como "
-#~ "definido na table spatial_ref_sys."
-#~ msgid ""
-#~ "<funcdef>integer <function>ST_SRID</function></funcdef> "
-#~ "<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>"
-#~ msgstr ""
-#~ "<funcdef>inteiro <function>ST_SRID</function></funcdef> "
-#~ "<paramdef><type>geometria </type> <parameter>g1</parameter></paramdef>"
-#~ msgid ""
-#~ "in spatial_ref_sys table. <xref linkend=\"spatial_ref_sys\"/>"
-#~ msgstr ""
-#~ "definido na table spatial_ref_sys. <xref linkend=\"spatial_ref_sys\"/>"
-#~ msgid ""
-#~ "spatial_ref_sys table is a table that catalogs all spatial reference "
-#~ "systems known to PostGIS and is used for transformations from one spatial "
-#~ "reference system to another. So verifying you have the right spatial "
-#~ "reference system identifier is important if you plan to ever transform "
-#~ "your geometries."
-#~ msgstr ""
-#~ "A table spatial_ref_sys cataloga todos os sistemas de referência espacial "
-#~ "conhecidos pelo PostGIS e é usada para transformações de um sistema de "
-#~ "referência espacial para outro. Portanto, verificar que você possui o "
-#~ "identificador de sistema de referência espacial é importante se planeja "
-#~ "transformar suas geometrias em algum momento. "
-#~ msgid "&sqlmm_compliant; SQL-MM 3: 5.1.5"
-#~ msgstr "&sqlmm_compliant; SQL-MM 3: 5.1.5"
-#~ msgid ""
-#~ "SELECT ST_SRID(ST_GeomFromText('POINT(-71.1043 42.315)',4326));\n"
-#~ " --result\n"
-#~ " 4326"
-#~ msgstr ""
-#~ "\n"
-#~ "--result\n"
-#~ "\n"
-#~ "4326"
-#~ msgid ""
-#~ ", <xref linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_SetSRID\"/>, "
-#~ "<xref linkend=\"ST_Transform\"/>"
-#~ msgstr ""
-#~ msgid ""
-#~ "Returns the first point of a <varname>LINESTRING</varname> geometry as a "
-#~ "<varname>POINT</varname>."
-#~ msgstr ""
-#~ "como um <varname>PONTO</varname>."
-#~ msgid ""
-#~ "<refpurpose>Returns a text summary of the contents of the geometry.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna um texto resumo dos conteúdos da geometria.</"
-#~ "refpurpose>"
-#~ msgid ""
-#~ "<refpurpose>Return the X coordinate of the point, or NULL if not "
-#~ msgstr ""
-#~ "<refpurpose>Retorna a coordenada X do ponto, ou NULA se não estiver "
-#~ msgid ""
-#~ "If you want to get the max min x values of any geometry look at ST_XMin, "
-#~ "ST_XMax functions."
-#~ msgstr ""
-#~ "Se você quer valores máximos e mínimos de x de qualquer geometria, veja "
-#~ "nas funções ST_XMin, ST_XMax."
-#~ msgid "ST_XMax"
-#~ msgstr "ST_XMax"
-#~ msgid ""
-#~ "<refpurpose>Returns X maxima of a bounding box 2d or 3d or a geometry.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o X máximo de uma caixa limitante 2d ou 3d ou uma "
-#~ "geometria.</refpurpose>"
-#~ msgid ""
-#~ "<funcdef>float <function>ST_XMax</function></funcdef> "
-#~ "<paramdef><type>box3d </type> <parameter>aGeomorBox2DorBox3D</parameter></"
-#~ "paramdef>"
-#~ msgstr ""
-#~ "paramdef>"
-#~ msgid ""
-#~ "<para>Returns X maxima of a bounding box 2d or 3d or a geometry.</para>"
-#~ msgstr ""
-#~ "<para>Retorna o X máximo de uma caixa limitante 2d ou 3d ou uma geometria."
-#~ "</para>"
-#~ msgid ""
-#~ "Although this function is only defined for box3d, it will work for box2d "
-#~ "and geometry because of the auto-casting behavior defined for geometries "
-#~ "and box2d. However you can not feed it a geometry or box2d text "
-#~ "representation, since that will not auto-cast."
-#~ msgstr ""
-#~ "Embora essa função só seja definida para caixa3d, ela funcionará para "
-#~ "caixa2d e geometria, por causa do comportamento auto-casting definido "
-#~ "para geometria e caixa2d. Entretanto você não pode abastecer uma "
-#~ "geometria ou uma representação de texto de uma caixa2d com ele, já que "
-#~ "não irá auto-cast."
-#~ msgid ""
-#~ "SELECT ST_XMax('BOX3D(1 2 3, 4 5 6)');\n"
-#~ "st_xmax\n"
-#~ "-------\n"
-#~ "4\n"
-#~ "\n"
-#~ "SELECT ST_XMax(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)'));\n"
-#~ "st_xmax\n"
-#~ "-------\n"
-#~ "5\n"
-#~ "\n"
-#~ "SELECT ST_XMax(CAST('BOX(-3 2, 3 4)' As box2d));\n"
-#~ "st_xmax\n"
-#~ "-------\n"
-#~ "3\n"
-#~ "--Observe THIS DOES NOT WORK because it will try to autocast the string "
-#~ "representation to a BOX3D\n"
-#~ "SELECT ST_XMax('LINESTRING(1 3, 5 6)');\n"
-#~ "\n"
-#~ "--ERROR: BOX3D parser - doesn't start with BOX3D(\n"
-#~ "\n"
-#~ "SELECT ST_XMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 "
-#~ "150505 2,220227 150406 3)'));\n"
-#~ "st_xmax\n"
-#~ "--------\n"
-#~ "220288.248780547"
-#~ msgstr ""
-#~ "st_xmax\n"
-#~ "-------\n"
-#~ "4\n"
-#~ "\n"
-#~ "st_xmax\n"
-#~ "-------\n"
-#~ "5\n"
-#~ "\n"
-#~ "st_xmax\n"
-#~ "-------\n"
-#~ "3\n"
-#~ "\n"
-#~ "\n"
-#~ "st_xmax\n"
-#~ "--------\n"
-#~ msgid ""
-#~ ", <xref linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend="
-#~ "\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
-#~ msgstr ""
-#~ msgid "ST_XMin"
-#~ msgstr "ST_XMin"
-#~ msgid ""
-#~ "<refpurpose>Returns X minima of a bounding box 2d or 3d or a geometry.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o X mínimo de uma caixa limitante 2d ou 3d ou uma "
-#~ msgid ""
-#~ "<funcdef>float <function>ST_XMin</function></funcdef> "
-#~ "paramdef>"
-#~ msgstr ""
-#~ "paramdef>"
-#~ msgid ""
-#~ "<para>Returns X minima of a bounding box 2d or 3d or a geometry.</para>"
-#~ msgstr ""
-#~ "<para>Retorna o X mínimo de uma caixa limitante 2d ou 3d ou uma geometria."
-#~ "</para>"
-#~ msgid ""
-#~ "SELECT ST_XMin('BOX3D(1 2 3, 4 5 6)');\n"
-#~ "st_xmin\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "\n"
-#~ "SELECT ST_XMin(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)'));\n"
-#~ "st_xmin\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "\n"
-#~ "SELECT ST_XMin(CAST('BOX(-3 2, 3 4)' As box2d));\n"
-#~ "st_xmin\n"
-#~ "-------\n"
-#~ "-3\n"
-#~ "SELECT ST_XMin('LINESTRING(1 3, 5 6)');\n"
-#~ "\n"
-#~ "\n"
-#~ "SELECT ST_XMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 "
-#~ "st_xmin\n"
-#~ "--------\n"
-#~ "220186.995121892"
-#~ msgstr ""
-#~ "st_xmin\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "\n"
-#~ "st_xmin\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "\n"
-#~ "st_xmin\n"
-#~ "-------\n"
-#~ "-3\n"
-#~ "\n"
-#~ "\n"
-#~ "st_xmin\n"
-#~ "--------\n"
-#~ msgid ""
-#~ "<refpurpose>Return the Y coordinate of the point, or NULL if not "
-#~ msgstr ""
-#~ "<refpurpose>Retorna a coordenada Y do ponto, ou NULA se não estiver "
-#~ msgid "ST_YMax"
-#~ msgstr "ST_YMax"
-#~ msgid ""
-#~ "<refpurpose>Returns Y maxima of a bounding box 2d or 3d or a geometry.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o Y máximo de uma caixa limitante 2d ou 3d ou uma "
-#~ msgid ""
-#~ "<funcdef>float <function>ST_YMax</function></funcdef> "
-#~ "paramdef>"
-#~ msgstr ""
-#~ "paramdef>"
-#~ msgid ""
-#~ "<para>Returns Y maxima of a bounding box 2d or 3d or a geometry.</para>"
-#~ msgstr ""
-#~ "<para>Retorna o Y máximo de uma caixa limitante 2d ou 3d ou uma geometria."
-#~ "</para>"
-#~ msgid ""
-#~ "SELECT ST_YMax('BOX3D(1 2 3, 4 5 6)');\n"
-#~ "st_ymax\n"
-#~ "-------\n"
-#~ "5\n"
-#~ "\n"
-#~ "SELECT ST_YMax(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)'));\n"
-#~ "st_ymax\n"
-#~ "-------\n"
-#~ "6\n"
-#~ "\n"
-#~ "SELECT ST_YMax(CAST('BOX(-3 2, 3 4)' As box2d));\n"
-#~ "st_ymax\n"
-#~ "-------\n"
-#~ "4\n"
-#~ "SELECT ST_YMax('LINESTRING(1 3, 5 6)');\n"
-#~ "\n"
-#~ "\n"
-#~ "SELECT ST_YMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 "
-#~ "st_ymax\n"
-#~ "--------\n"
-#~ "150506.126829327"
-#~ msgstr ""
-#~ "st_ymax\n"
-#~ "-------\n"
-#~ "5\n"
-#~ "\n"
-#~ "st_ymax\n"
-#~ "-------\n"
-#~ "6\n"
-#~ "\n"
-#~ "st_ymax\n"
-#~ "-------\n"
-#~ "4\n"
-#~ "\n"
-#~ "\n"
-#~ "st_ymax\n"
-#~ "--------\n"
-#~ msgid ""
-#~ ", <xref linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend="
-#~ msgstr ""
-#~ msgid "ST_YMin"
-#~ msgstr "ST_YMin"
-#~ msgid ""
-#~ "<refpurpose>Returns Y minima of a bounding box 2d or 3d or a geometry.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o Y mínimo de uma caixa limitante 2d ou 3d ou uma "
-#~ msgid ""
-#~ "<funcdef>float <function>ST_YMin</function></funcdef> "
-#~ "paramdef>"
-#~ msgstr ""
-#~ "paramdef>"
-#~ msgid ""
-#~ "<para>Returns Y minima of a bounding box 2d or 3d or a geometry.</para>"
-#~ msgstr ""
-#~ "<para>Retorna o Y mínimo de uma caixa limitante 2d ou 3d ou uma geometria."
-#~ "</para>"
-#~ msgid ""
-#~ "SELECT ST_YMin('BOX3D(1 2 3, 4 5 6)');\n"
-#~ "st_ymin\n"
-#~ "-------\n"
-#~ "2\n"
-#~ "\n"
-#~ "SELECT ST_YMin(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)'));\n"
-#~ "st_ymin\n"
-#~ "-------\n"
-#~ "3\n"
-#~ "\n"
-#~ "SELECT ST_YMin(CAST('BOX(-3 2, 3 4)' As box2d));\n"
-#~ "st_ymin\n"
-#~ "-------\n"
-#~ "2\n"
-#~ "SELECT ST_YMin('LINESTRING(1 3, 5 6)');\n"
-#~ "\n"
-#~ "\n"
-#~ "SELECT ST_YMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 "
-#~ "st_ymin\n"
-#~ "--------\n"
-#~ "150406"
-#~ msgstr ""
-#~ "st_ymin\n"
-#~ "-------\n"
-#~ "2\n"
-#~ "\n"
-#~ "st_ymin\n"
-#~ "-------\n"
-#~ "3\n"
-#~ "\n"
-#~ "st_ymin\n"
-#~ "-------\n"
-#~ "2\n"
-#~ "\n"
-#~ "\n"
-#~ "st_ymin\n"
-#~ "--------\n"
-#~ "150406"
-#~ msgid ""
-#~ ", <xref linkend=\"ST_XMin\"/>, <xref linkend=\"ST_XMax\"/>, <xref linkend="
-#~ "\"ST_YMax\"/>, <xref linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
-#~ msgstr ""
-#~ msgid ""
-#~ "<refpurpose>Return the Z coordinate of the point, or NULL if not "
-#~ msgstr ""
-#~ "<refpurpose>Retorna a coordenada Z do ponto, ou NULA se não estiver "
-#~ msgid "ST_ZMax"
-#~ msgstr "ST_ZMax"
-#~ msgid ""
-#~ "<refpurpose>Returns Z minima of a bounding box 2d or 3d or a geometry.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o Z mínimo de uma caixa limitante 2d ou 3d ou uma "
-#~ msgid ""
-#~ "<funcdef>float <function>ST_ZMax</function></funcdef> "
-#~ "paramdef>"
-#~ msgstr ""
-#~ "paramdef>"
-#~ msgid "Returns Z maxima of a bounding box 2d or 3d or a geometry."
-#~ msgstr ""
-#~ "Retorna o Z máximo de uma caixa limitante 2d ou 3d ou uma geometria."
-#~ msgid ""
-#~ "SELECT ST_ZMax('BOX3D(1 2 3, 4 5 6)');\n"
-#~ "st_zmax\n"
-#~ "-------\n"
-#~ "6\n"
-#~ "\n"
-#~ "SELECT ST_ZMax(ST_GeomFromEWKT('LINESTRING(1 3 4, 5 6 7)'));\n"
-#~ "st_zmax\n"
-#~ "-------\n"
-#~ "7\n"
-#~ "\n"
-#~ "SELECT ST_ZMax('BOX3D(-3 2 1, 3 4 1)' );\n"
-#~ "st_zmax\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "SELECT ST_ZMax('LINESTRING(1 3 4, 5 6 7)');\n"
-#~ "\n"
-#~ "\n"
-#~ "SELECT ST_ZMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 "
-#~ "st_zmax\n"
-#~ "--------\n"
-#~ "3"
-#~ msgstr ""
-#~ "st_zmax\n"
-#~ "-------\n"
-#~ "6\n"
-#~ "\n"
-#~ "st_zmax\n"
-#~ "-------\n"
-#~ "7\n"
-#~ "\n"
-#~ "st_zmax\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "\n"
-#~ "\n"
-#~ "st_zmax\n"
-#~ "--------\n"
-#~ "3"
-#~ msgid ""
-#~ "\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend=\"ST_ZMax\"/>"
-#~ msgstr ""
-#~ msgid ""
-#~ "<refpurpose>Returns ZM (dimension semantic) flag of the geometries as a "
-#~ "small int. Values are: 0=2d, 1=3dm, 2=3dz, 3=4d.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna a bandeira ZM (dimensão semântica) das geometrias "
-#~ "como uma small int. Os valores são: 0=2d, 1=3dm, 2=3dz, 3=4d.</refpurpose>"
-#~ msgid ""
-#~ "<para>Returns ZM (dimension semantic) flag of the geometries as a small "
-#~ "int. Values are: 0=2d, 1=3dm, 2=3dz, 3=4d.</para>"
-#~ msgstr ""
-#~ "<para>Retorna a bandeira ZM (dimensão semântica) das geometrias como uma "
-#~ "small int. Os valores são: 0=2d, 1=3dm, 2=3dz, 3=4d.</para>"
-#~ msgid "ST_ZMin"
-#~ msgstr "ST_ZMin"
-#~ msgid ""
-#~ "<funcdef>float <function>ST_ZMin</function></funcdef> "
-#~ "paramdef>"
-#~ msgstr ""
-#~ "paramdef>"
-#~ msgid ""
-#~ "<para>Returns Z minima of a bounding box 2d or 3d or a geometry.</para>"
-#~ msgstr ""
-#~ "<para>Retorna o Z mínimo de uma caixa limitante 2d ou 3d ou uma geometria."
-#~ "</para>"
-#~ msgid ""
-#~ "SELECT ST_ZMin('BOX3D(1 2 3, 4 5 6)');\n"
-#~ "st_zmin\n"
-#~ "-------\n"
-#~ "3\n"
-#~ "\n"
-#~ "SELECT ST_ZMin(ST_GeomFromEWKT('LINESTRING(1 3 4, 5 6 7)'));\n"
-#~ "st_zmin\n"
-#~ "-------\n"
-#~ "4\n"
-#~ "\n"
-#~ "SELECT ST_ZMin('BOX3D(-3 2 1, 3 4 1)' );\n"
-#~ "st_zmin\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "SELECT ST_ZMin('LINESTRING(1 3 4, 5 6 7)');\n"
-#~ "\n"
-#~ "\n"
-#~ "SELECT ST_ZMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 "
-#~ "st_zmin\n"
-#~ "--------\n"
-#~ "1"
-#~ msgstr ""
-#~ "st_zmin\n"
-#~ "-------\n"
-#~ "3\n"
-#~ "\n"
-#~ "st_zmin\n"
-#~ "-------\n"
-#~ "4\n"
-#~ "\n"
-#~ "st_zmin\n"
-#~ "-------\n"
-#~ "1\n"
-#~ "\n"
-#~ "\n"
-#~ "st_zmin\n"
-#~ "--------\n"
-#~ "1"
-#~ msgid ""
-#~ ", <xref linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_XMin\"/>, <xref "
-#~ "linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMax\"/>, <xref linkend="
-#~ "\"ST_YMin\"/>, <xref linkend=\"ST_ZMax\"/>"
-#~ msgstr ""
diff --git a/doc/po/pt_BR/reference_constructor.xml.po b/doc/po/pt_BR/reference_constructor.xml.po
index a5a85d611..6dfeb6497 100644
--- a/doc/po/pt_BR/reference_constructor.xml.po
+++ b/doc/po/pt_BR/reference_constructor.xml.po
@@ -348,7 +348,7 @@ msgstr "Examples"
#: reference_constructor.xml:121
msgid "Create a 3D line string from a 3D MultiPoint"
-msgstr "<para>Cria uma LineString de uma geometria MultiPointo.</para>"
+msgstr "Cria uma LineString de uma geometria MultiPointo."
#. Tag: programlisting
#: reference_constructor.xml:122
diff --git a/doc/po/pt_BR/reference_lrs.xml.po b/doc/po/pt_BR/reference_lrs.xml.po
index 77caaa6c8..f4afecc63 100644
--- a/doc/po/pt_BR/reference_lrs.xml.po
+++ b/doc/po/pt_BR/reference_lrs.xml.po
@@ -748,9 +748,8 @@ msgid ""
"Returns the locations along a measured geometry (as a Point or MultiPoint) "
"that match a measure value. Polygonal elements are not supported."
msgstr ""
-"<para>Retorna um valor de coleção de geometria derivado com elementos que "
-"combinam com a medida específica. Elementos polígonos não são suportados.</"
-"para>"
+"Retorna um valor de coleção de geometria derivado com elementos que "
+"combinam com a medida específica. Elementos polígonos não são suportados."
#. Tag: para
#: reference_lrs.xml:365 reference_lrs.xml:419
@@ -854,9 +853,8 @@ msgid ""
"Return a geometry (collection) with the portions of the input measured "
"geometry that match the specified measure range (inclusively)."
msgstr ""
-"para>"
#. Tag: para
#: reference_lrs.xml:423 reference_lrs.xml:474
@@ -986,8 +984,8 @@ msgstr "ST_InterpolatePoint"
msgid "Returns the interpolated measure of a geometry closest to a point."
msgstr ""
-"<para>Retorna o valor da dimensão de medida da geometria no ponto fechado "
-"para o ponto fornecido.</para>"
+"Retorna o valor da dimensão de medida da geometria no ponto fechado "
+"para o ponto fornecido."
#: reference_lrs.xml:506
@@ -1008,8 +1006,8 @@ msgid ""
"Returns the value of the measure dimension of a geometry at the point closed "
"to the provided point."
msgstr ""
#. Tag: para
#: reference_lrs.xml:520
@@ -1142,438 +1140,3 @@ msgstr ""
"-----------------------------------------------------------------\n"
" MULTILINESTRINGM((1 0 10,2 0 20,4 0 40),(1 0 40,2 0 50,4 0 70))"
-#, no-c-format
-#~ msgid ""
-#~ "Returns a point interpolated along a line. Second argument is a float8 "
-#~ "between 0 and 1 representing fraction of total length of linestring the "
-#~ "point has to be located."
-#~ msgstr ""
-#~ "Retorna um ponto interpolar ao longo de uma linha. Segundo argumento é um "
-#~ "float8 entre 0 e 1 representando fração do comprimento total da "
-#~ "linestring do ponto tem que ser localizado. "
-#, no-c-format
-#~ msgid ""
-#~ "--Return point mid-way of 3d line\n"
-#~ "SELECT ST_AsEWKT(ST_LineInterpolatePoint(the_line, 0.5))\n"
-#~ " FROM (SELECT ST_GeomFromEWKT('LINESTRING(1 2 3, 4 5 6, 6 7 8)') "
-#~ "as the_line) As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "--------------------\n"
-#~ " POINT(3.5 4.5 5.5)\n"
-#~ "\n"
-#~ "\n"
-#~ "--find closest point on a line to a point or other geometry\n"
-#~ " SELECT ST_AsText(ST_LineInterpolatePoint(foo.the_line, "
-#~ "ST_LineLocatePoint(foo.the_line, ST_GeomFromText('POINT(4 3)'))))\n"
-#~ "FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As "
-#~ "foo;\n"
-#~ " st_astext\n"
-#~ "----------------\n"
-#~ " POINT(3 4)"
-#~ msgstr ""
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "\n"
-#~ "\n"
-#~ "foo;\n"
-#~ " st_astext\n"
-#~ " POINT(3 4)"
-#, fuzzy, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"ST_AsEWKT\"/>, <xref linkend=\"ST_Length\"/>, <xref "
-#~ "linkend=\"ST_LineInterpolatePoints\"/> <xref linkend="
-#~ "\"ST_3DLineInterpolatePoint\"/> <xref linkend=\"ST_LineLocatePoint\"/> O"
-#~ msgstr ""
-#~ ", <xref linkend=\"ST_Length2D\"/>, <xref linkend=\"ST_LineInterpolatePoint"
-#~ "\"/>, <xref linkend=\"ST_LineSubstring\"/>"
-#~ msgid ""
-#~ "Returns a point interpolated along a line in 3D. Second argument is a "
-#~ "float8 between 0 and 1 representing fraction of total length of "
-#~ "linestring the point has to be located."
-#~ msgstr ""
-#~ msgid ""
-#~ "linkend=\"ST_LineInterpolatePoint\"/> <xref linkend="
-#~ "\"ST_LineInterpolatePoints\"/> <xref linkend=\"ST_LineLocatePoint\"/>"
-#~ msgstr ""
-#, no-c-format
-#~ msgid ""
-#~ "Returns a float between 0 and 1 representing the location of the closest "
-#~ "point on LineString to the given Point, as a fraction of total 2d line "
-#~ "length."
-#~ msgstr ""
-#~ "Retorna um flutuador entre 0 e 1 representando a localização do ponto mai "
-#~ "próximo na linestring do ponto dado, como uma fração de uma linha de "
-#~ "comprimento 2d total."
-#, no-c-format
-#~ msgid ""
-#~ "Return a linestring being a substring of the input one starting and "
-#~ "ending at the given fractions of total 2d length. Second and third "
-#~ "arguments are float8 values between 0 and 1."
-#~ msgstr ""
-#~ "Retorna uma linestring sendo uma substring da de entrada começando e "
-#~ "finalizando nas frações dadas do total 2d de comprimento. Segundo e "
-#~ "terceiro argumentos são valores float8 entre 0 e 1."
-#, no-c-format
-#~ msgid ""
-#~ "arguments are float8 values between 0 and 1. This only works with "
-#~ "LINESTRINGs. To use with contiguous MULTILINESTRINGs use in conjunction "
-#~ "with <xref linkend=\"ST_LineMerge\"/>."
-#~ msgstr ""
-#~ "terceiro argumentos são valores float8 entre 0 e 1. Isso só funciona com "
-#~ "LINESTRINGs. Para usar com MULTILINSTRINGs contíguas, use em conjunção "
-#~ "com <xref linkend=\"ST_LineMerge\"/>."
-#, no-c-format
-#~ msgid ""
-#~ "--Return the approximate 1/3 mid-range part of a linestring\n"
-#~ "SELECT ST_AsText(ST_Line_SubString(ST_GeomFromText('LINESTRING(25 50, 100 "
-#~ "125, 150 190)'), 0.333, 0.666));\n"
-#~ "\n"
-#~ " st_astext\n"
-#~ "------------------------------------------------------------------------------------------------\n"
-#~ "LINESTRING(69.2846934853974 94.2846934853974,100 125,111.700356260683 "
-#~ "140.210463138888)\n"
-#~ "\n"
-#~ "--The below example simulates a while loop in\n"
-#~ "--SQL using PostgreSQL generate_series() to cut all\n"
-#~ "--linestrings in a table to 100 unit segments\n"
-#~ "-- of which no segment is longer than 100 units\n"
-#~ "-- units are measured in the SRID units of measurement\n"
-#~ "-- It also assumes all geometries are LINESTRING or contiguous "
-#~ "MULTILINESTRING\n"
-#~ "--and no geometry is longer than 100 units*10000\n"
-#~ "--for better performance you can reduce the 10000\n"
-#~ "--to match max number of segments you expect\n"
-#~ "\n"
-#~ "SELECT field1, field2, ST_LineSubstring(the_geom, 100.00*n/length,\n"
-#~ " CASE\n"
-#~ " WHEN 100.00*(n+1) < length THEN 100.00*(n+1)/length\n"
-#~ " ELSE 1\n"
-#~ " END) As the_geom\n"
-#~ "FROM\n"
-#~ " (SELECT sometable.field1, sometable.field2,\n"
-#~ " ST_LineMerge(sometable.the_geom) AS the_geom,\n"
-#~ " ST_Length(sometable.the_geom) As length\n"
-#~ " FROM sometable\n"
-#~ " ) AS t\n"
-#~ "CROSS JOIN generate_series(0,10000) AS n\n"
-#~ "WHERE n*100.00/length < 1;"
-#~ msgstr ""
-#~ "\n"
-#~ " st_astext\n"
-#~ "\n"
-#~ "\n"
-#~ " CASE\n"
-#~ " ELSE 1\n"
-#~ "FROM\n"
-#~ " ) AS t\n"
-#, no-c-format
-#~ msgid ""
-#~ "<refpurpose>Return a derived geometry collection value with elements that "
-#~ "match the specified measure. Polygonal elements are not supported.</"
-#~ "refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna um valor de coleção de geometria derivado com "
-#~ "elementos que combinam com a medida específica. Elementos polígonos não "
-#~ "são suportados.</refpurpose>"
-#, no-c-format
-#~ msgid ""
-#~ "Semantic is specified by: ISO/IEC CD 13249-3:200x(E) - Text for "
-#~ "Continuation CD Editing Meeting"
-#~ msgstr ""
-#~ "Semântico é especificado por: ISO/IEC CD 13249-3:200x(E) - Text for "
-#, no-c-format
-#~ msgid ""
-#~ "SELECT ST_AsText(the_geom)\n"
-#~ " FROM\n"
-#~ " (SELECT ST_LocateAlong(\n"
-#~ " ST_GeomFromText('MULTILINESTRINGM((1 2 3, 3 4 2, "
-#~ "9 4 3),\n"
-#~ " (1 2 3, 5 4 5))'),3) As the_geom) As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "-----------------------------------------------------------\n"
-#~ " MULTIPOINT M (1 2 3)\n"
-#~ "\n"
-#~ "--Geometry collections are difficult animals so dump them\n"
-#~ "--to make them more digestable\n"
-#~ "SELECT ST_AsText((ST_Dump(the_geom)).geom)\n"
-#~ " FROM\n"
-#~ "9 4 3),\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "---------------\n"
-#~ " POINTM(1 2 3)\n"
-#~ " POINTM(9 4 3)\n"
-#~ " POINTM(1 2 3)"
-#~ msgstr ""
-#~ " FROM\n"
-#~ "9 4 3),\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "\n"
-#~ " FROM\n"
-#~ "9 4 3),\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ msgid ""
-#~ "Return a derived geometry collection value with elements that match the "
-#~ "specified range of measures inclusively."
-#~ msgstr ""
-#~ "<para>Retorna um valor de coleção de geometria derivado com elementos que "
-#~ "combinam com a medida específica. Elementos polígonos não são suportados."
-#~ "</para>"
-#~ msgid ""
-#~ "FROM (\n"
-#~ " SELECT ST_LocateBetween(\n"
-#~ " 'MULTILINESTRING M ((1 2 3, 3 4 2, 9 4 3),(1 2 3, 5 4 5))'),\n"
-#~ " 1.5,\n"
-#~ " 3\n"
-#~ " ) as the_geom\n"
-#~ ") As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "------------------------------------------------------------------------\n"
-#~ " GEOMETRYCOLLECTION M (LINESTRING M (1 2 3,3 4 2,9 4 3),POINT M (1 2 3))\n"
-#~ "\n"
-#~ "FROM (\n"
-#~ " 1.5,\n"
-#~ " 3\n"
-#~ " ) As the_geom\n"
-#~ ") As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "--------------------------------\n"
-#~ " LINESTRING M (1 2 3,3 4 2,9 4 3)\n"
-#~ " POINT M (1 2 3)"
-#~ msgstr ""
-#~ " FROM\n"
-#~ " (SELECT ST_LocateBetween(\n"
-#~ " ST_GeomFromText('MULTILINESTRING M ((1 2 3, 3 4 "
-#~ "2, 9 4 3),\n"
-#~ " (1 2 3, 5 4 5))'),1.5, 3) As the_geom) As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "\n"
-#~ " FROM\n"
-#~ "2, 9 4 3),\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ msgid ""
-#~ "<refpurpose>Return a derived geometry (collection) value with elements "
-#~ "that intersect the specified range of elevations inclusively.</refpurpose>"
-#~ msgstr ""
-#~ msgid ""
-#~ "<para>Return a derived geometry (collection) value with elements that "
-#~ "intersect the specified range of elevations inclusively.</para>"
-#~ msgstr ""
-#~ "</para>"
-#~ msgid ""
-#~ "SELECT ST_AsEWKT(ST_LocateBetweenElevations(\n"
-#~ " ST_GeomFromEWKT('LINESTRING(1 2 3, 4 5 6)'), 2, "
-#~ "4)) As ewelev;\n"
-#~ " ewelev\n"
-#~ "----------------------------------------------------------------\n"
-#~ " MULTILINESTRING((1 2 3,2 3 4))\n"
-#~ "\n"
-#~ "SELECT ST_AsEWKT(ST_LocateBetweenElevations('LINESTRING(1 2 6, 4 5 -1, 7 "
-#~ "8 9)', 6, 9)) As ewelev;\n"
-#~ "\n"
-#~ " ewelev\n"
-#~ "GEOMETRYCOLLECTION(POINT(1 2 6),LINESTRING(6.1 7.1 6,7 8 9))\n"
-#~ "\n"
-#~ "-- Geometry collections are difficult animals so dump them\n"
-#~ "-- to make them more digestable\n"
-#~ "SELECT ST_AsEWKT((ST_Dump(the_geom)).geom)\n"
-#~ " FROM\n"
-#~ " (SELECT ST_LocateBetweenElevations('LINESTRING(1 2 6, 4 5 -1, 7 8 "
-#~ "9)', 6, 9) as the_geom) As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#~ "POINT(1 2 6)\n"
-#~ "LINESTRING(6.1 7.1 6,7 8 9)"
-#~ msgstr ""
-#~ " ST_GeomFromEWKT('LINESTRING(1 2 3, 4 5 6)'),2,4)) "
-#~ "As ewelev;\n"
-#~ " ewelev\n"
-#~ "\n"
-#~ " ST_GeomFromEWKT('LINESTRING(1 2 6, 4 5 -1, 7 8 "
-#~ "9)'),6,9)) As ewelev;\n"
-#~ "\n"
-#~ " ewelev\n"
-#~ "\n"
-#~ " FROM\n"
-#~ " (SELECT ST_LocateBetweenElevations(\n"
-#~ "9)'),6,9) As the_geom) As foo;\n"
-#~ "\n"
-#~ " st_asewkt\n"
-#, no-c-format
-#~ msgid ""
-#~ "<refpurpose>Return the value of the measure dimension of a geometry at "
-#~ "the point closed to the provided point.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Retorna o valor da dimensão de medida da geometria no ponto "
-#~ "fechado para o ponto fornecido.</refpurpose>"
-#, no-c-format
-#~ msgid ""
-#~ "Return a derived geometry with measure elements linearly interpolated "
-#~ "between the start and end points."
-#~ msgstr ""
-#~ "Retorna uma geometria derivada com elementos de medida interpolados "
-#~ "linearmente entre os pontos de início e de fim."
-#~ msgid ""
-#~ "Changed: 2.0.0 - in prior versions this used to be called "
-#~ "ST_Locate_Between_Measures. The old name has been deprecated and will be "
-#~ "removed in the future but is still available for backward compatibility."
-#~ msgstr ""
-#~ "Alterações: 2.0.0 - nas versões anteriores era chamado de "
-#~ "ST_Locate_Along_Measure. O nome antigo foi menosprezado e será removido "
-#~ "no futuro, mas ainda está disponível para compatibilidades anteriores."
-#~ msgid ""
-#~ "Return a derived geometry (collection) value with elements that intersect "
-#~ "the specified range of elevations inclusively. Only 3D, 4D LINESTRINGS "
-#~ "and MULTILINESTRINGS are supported."
-#~ msgstr ""
-#~ "Retorna um valor de geometria derivada (coleção) com elementos que "
-#~ "inserem a variação específica de elevações. Apenas 3D, 4D LINESTRINGS e "
-#~ "MULTILINESTRINGS são suportadas."
-#~ msgid ""
-#~ "the specified range of elevations inclusively. Only 3D, 3DM LINESTRINGS "
-#~ msgstr ""
-#~ "inserem a variação específica de elevações. Apenas 3D, 3DM LINESTRINGS e "
diff --git a/doc/po/pt_BR/reference_management.xml.po b/doc/po/pt_BR/reference_management.xml.po
index 0a23d6a46..76c78ba28 100644
--- a/doc/po/pt_BR/reference_management.xml.po
+++ b/doc/po/pt_BR/reference_management.xml.po
@@ -586,7 +586,7 @@ msgstr ""
#: reference_management.xml:292
+#, no-c-format
msgid ""
"<funcdef>integer <function>Find_SRID</function></funcdef> "
"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
@@ -594,13 +594,11 @@ msgid ""
"parameter></paramdef> <paramdef><type>varchar </type> "
"<parameter>a_geomfield_name</parameter></paramdef>"
msgstr ""
-"<funcprototype> <funcdef>text <function>Populate_Geometry_Columns</"
-"function></funcdef> <paramdef><type>boolean </type> "
-"<parameter>use_typmod=true</parameter></paramdef> </funcprototype> "
-"<funcprototype> <funcdef>int <function>Populate_Geometry_Columns</function></"
-"funcdef> <paramdef><type>oid</type> <parameter>relation_oid</parameter></"
-"paramdef> <paramdef><type>boolean </type> <parameter>use_typmod=true</"
-"parameter></paramdef> </funcprototype>"
+"<funcdef>integer <function>Find_SRID</function></funcdef> "
+"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> <parameter>a_table_name</"
+"parameter></paramdef> <paramdef><type>varchar </type> "
+"<parameter>a_geomfield_name</parameter></paramdef>"
#. Tag: para
#: reference_management.xml:304
diff --git a/doc/po/pt_BR/reference_measure.xml.po b/doc/po/pt_BR/reference_measure.xml.po
index 419949fb2..4197e3c47 100644
--- a/doc/po/pt_BR/reference_measure.xml.po
+++ b/doc/po/pt_BR/reference_measure.xml.po
@@ -2136,9 +2136,9 @@ msgid ""
"Returns the 2D length of a linear geometry. Alias for <varname>ST_Length</"
"varname>"
msgstr ""
-"<para>Retorna o comprimento 2-dimensional da geometria se for uma linestring "
+"Retorna o comprimento 2-dimensional da geometria se for uma linestring "
"ou multi-linestring. Isto é um heterônimo para <varname>ST_Length</"
-"varname></para>"
+"varname>"
#: reference_measure.xml:806
@@ -2159,9 +2159,9 @@ msgid ""
"Returns the 2D length of the geometry if it is a linestring or multi-"
"linestring. This is an alias for <varname>ST_Length</varname>"
msgstr ""
-"varname></para>"
+"varname>"
#. Tag: para
#: reference_measure.xml:825
diff --git a/doc/po/pt_BR/reference_transaction.xml.po b/doc/po/pt_BR/reference_transaction.xml.po
index 01448a23c..0207ff34c 100644
--- a/doc/po/pt_BR/reference_transaction.xml.po
+++ b/doc/po/pt_BR/reference_transaction.xml.po
@@ -269,9 +269,9 @@ msgid ""
"transaction support metadata tables, and drops all triggers attached to lock-"
"checked tables."
msgstr ""
-"<para>Desativa suporte de transações longas. Essa função remove as tables de "
+"Desativa suporte de transações longas. Essa função remove as tables de "
"metadados ad transação longa e derruba todos os triggers anexados às tables "
-"lock-checked.</para>"
+"lock-checked."
#. Tag: para
#: reference_transaction.xml:139
@@ -327,9 +327,9 @@ msgid ""
"metadata tables. It must be called once before using the other functions in "
"this section. Calling it twice is harmless."
msgstr ""
-"<para>Ativa o suporte de longas transações. Essa função cria as tables de "
+"Ativa o suporte de longas transações. Essa função cria as tables de "
"metadados que são requeridas, precisa ser chamada uma vez antes de usar "
-"outras funções nessa seção. Chamá-la duas vezes não tem problema.</para>"
+"outras funções nessa seção. Chamá-la duas vezes não tem problema."
#. Tag: para
#: reference_transaction.xml:185
@@ -474,8 +474,8 @@ msgid ""
"Removes all locks held by specified authorization token. Returns the number "
"of locks released."
msgstr ""
-"<para>Remove todos os fechamentos armazenados por id de autorização "
-"específica Retorna o número de fechamentos liberados.</para>"
+"Remove todos os fechamentos armazenados por id de autorização "
+"específica Retorna o número de fechamentos liberados."
#: reference_transaction.xml:300
@@ -494,36 +494,3 @@ msgstr ""
" UnLockRows\n"
" ------------\n"
" 2"
-#~ msgid ""
-#~ "Creates/adds to a temp table called temp_lock_have_table the current "
-#~ "transaction identifier and authorization token key."
-#~ msgstr ""
-#~ "Cria/adiciona a uma temp table chamada temp_lock_have_table, o "
-#~ "identificador da transação atual e chave de autorização token. "
-#~ msgid ""
-#~ "<refpurpose>Disable long transaction support. This function removes the "
-#~ "long transaction support metadata tables, and drops all triggers attached "
-#~ "to lock-checked tables.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Desativa suporte de transações longas. Essa função remove as "
-#~ "tables de metadados ad transação longa e derruba todos os triggers "
-#~ "anexados às tables lock-checked.</refpurpose>"
-#~ msgid ""
-#~ "<refpurpose>Enable long transaction support. This function creates the "
-#~ "required metadata tables, needs to be called once before using the other "
-#~ "functions in this section. Calling it twice is harmless.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Ativa o suporte de longas transações. Essa função cria as "
-#~ "tables de metadados que são requeridas, precisa ser chamada uma vez antes "
-#~ "de usar outras funções nessa seção. Chamá-la duas vezes não tem problema."
-#~ "</refpurpose>"
-#~ msgid ""
-#~ "<refpurpose>Remove all locks held by specified authorization id. Returns "
-#~ "the number of locks released.</refpurpose>"
-#~ msgstr ""
-#~ "<refpurpose>Remove todos os fechamentos armazenados por id de autorização "
-#~ "específica Retorna o número de fechamentos liberados.</refpurpose>"
Summary of changes:
doc/po/pt_BR/reference_accessor.xml.po | 1250 +----------------------------
doc/po/pt_BR/reference_constructor.xml.po | 2 +-
doc/po/pt_BR/reference_lrs.xml.po | 453 +----------
doc/po/pt_BR/reference_management.xml.po | 14 +-
doc/po/pt_BR/reference_measure.xml.po | 8 +-
doc/po/pt_BR/reference_transaction.xml.po | 45 +-
6 files changed, 43 insertions(+), 1729 deletions(-)
hooks/post-receive
