[postgis-tickets] [PostGIS] #5074: Consider using itstool for localization
trac at osgeo.org
Sun Jan 30 16:43:02 PST 2022
Reporter: strk | Owner: robe
Type: task | Status: new
Priority: medium | Milestone:
Component: l18n | Version:
Resolution: | Keywords:
Comment (by strk):
As a first test I tried generating the pot file for the introduction.xml
with no switches and no configuration (itstool introduction.xml >
po/templates/introduction.xml.pot).
Few interesting things I saw:
(1) Tags are more informative:
-#. Tag: para
+#. (itstool) path: chapter/para
(2) The ", no-c-format" line isn't added:
#: introduction.xml:21
-#, no-c-format
msgid "Project Steering Committee"
msgstr ""
(3) Line wrapping doesn't seem to be supported:
-msgid ""
-"MVT support, Bug fixing, Performance and stability improvements, GitHub
-"curation, alignment of PostGIS with PostgreSQL releases"
+msgid "MVT support, Bug fixing, Performance and stability improvements,
GitHub curation, alignment of PostGIS with PostgreSQL releases"
(4) itstool seems to be including useless portions of the string in the
msgid (I checked and xml2po/po2xml are keeping the link intact):
-msgid "Boundless"
+msgid "<ulink url=\"https://www.boundlessgeo.com\">Boundless</ulink>"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5074#comment:1>
