[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-413-g8e829f9f0
git at osgeo.org
git at osgeo.org
Sun Jan 30 17:17:46 PST 2022
the project "PostGIS".
via 8e829f9f0a9f7fe31f12d4c2d57ca1df26f4d8cd (commit)
from 5abafca623ef036b229182322b9bbeb4155b9827 (commit)
revisions in full, below.
commit 8e829f9f0a9f7fe31f12d4c2d57ca1df26f4d8cd
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 02:15:43 2022 +0100
Fix structural issues in es translations
References #5073
diff --git a/doc/po/es/reference_accessor.xml.po b/doc/po/es/reference_accessor.xml.po
index 0dbc49385..b19cafa5a 100644
--- a/doc/po/es/reference_accessor.xml.po
+++ b/doc/po/es/reference_accessor.xml.po
@@ -80,8 +80,8 @@ msgid ""
"Returns the type of the geometry as a string. Eg: 'LINESTRING', 'POLYGON', "
"'MULTIPOINT', etc."
msgstr ""
-"<para>Devuelve el tipo de geometría como una cadena de texto. Ej: "
-"'LINESTRING', 'POLYGON', 'MULTIPOINT', etc.</para>"
+"Devuelve el tipo de geometría como una cadena de texto. Ej: "
+"'LINESTRING', 'POLYGON', 'MULTIPOINT', etc."
#. Tag: para
#: reference_accessor.xml:28
@@ -667,9 +667,7 @@ msgstr "ST_CoordDim"
#: reference_accessor.xml:220
#, fuzzy, no-c-format
msgid "Return the coordinate dimension of a geometry."
-msgstr ""
-"<para>Devuelve la dimensión de las coordenadas del valor de ST_Geometry.</"
-"para>"
+msgstr "Devuelve la dimensión de las coordenadas del valor de ST_Geometry."
#. Tag: funcprototype
#: reference_accessor.xml:225
@@ -685,9 +683,7 @@ msgstr ""
#: reference_accessor.xml:235
msgid "Return the coordinate dimension of the ST_Geometry value."
-msgstr ""
-"para>"
#. Tag: para
#: reference_accessor.xml:237
@@ -733,9 +729,7 @@ msgstr "ST_Dimension"
#: reference_accessor.xml:266
msgid "Returns the topological dimension of a geometry."
-msgstr ""
-"para>"
#: reference_accessor.xml:271
@@ -1023,7 +1017,7 @@ msgid ""
"Returns a set of <varname>geometry_dump</varname> rows for the coordinates "
"in a geometry."
msgstr ""
-"<para>Devuelve un resumen de texto del contenido de la geometría.</para>"
+"Devuelve un resumen de texto del contenido de la geometría."
#: reference_accessor.xml:378
@@ -1357,7 +1351,7 @@ msgid ""
"Returns a set of <varname>geometry_dump</varname> rows for the segments in a "
"geometry."
msgstr ""
#: reference_accessor.xml:464
@@ -3360,8 +3354,8 @@ msgid ""
"Return the M coordinate of a Point, or NULL if not available. Input must be "
"a Point."
msgstr ""
-"<para>Devuelve la coordenada M del punto, o NULL si no seta disponible. La "
-"entrada debe ser un punto.</para>"
+"Devuelve la coordenada M del punto, o NULL si no seta disponible. La "
+"entrada debe ser un punto."
#. Tag: para
#: reference_accessor.xml:1372
@@ -3518,9 +3512,7 @@ msgstr "ST_NDims"
#: reference_accessor.xml:1442
msgid "Returns the coordinate dimension of a geometry."
-msgstr ""
-"para>"
#: reference_accessor.xml:1447
@@ -4505,8 +4497,7 @@ msgstr "ST_Summary"
#: reference_accessor.xml:1980
msgid "Returns a text summary of the contents of a geometry."
-msgstr ""
+msgstr "Devuelve un resumen de texto del contenido de la geometría."
#. Tag: funcsynopsis
#: reference_accessor.xml:1985
@@ -4528,8 +4519,7 @@ msgstr ""
#: reference_accessor.xml:2000
msgid "Returns a text summary of the contents of the geometry."
-msgstr ""
#. Tag: para
#: reference_accessor.xml:2002
@@ -4699,8 +4689,8 @@ msgid ""
"Return the X coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>Devuelve la coordenada X del punto, o NULL si no está disponible. La "
+"Devuelve la coordenada X del punto, o NULL si no está disponible. La "
#. Tag: para
#: reference_accessor.xml:2076
@@ -4785,8 +4775,8 @@ msgid ""
"Return the Y coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>Devuelve la coordenada Y del punto, o NULL si no está disponible. La "
+"Devuelve la coordenada Y del punto, o NULL si no está disponible. La "
#. Tag: para
#: reference_accessor.xml:2120
@@ -4871,8 +4861,8 @@ msgid ""
"Return the Z coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>Devuelve la coordenada Z del punto, o NULL si no está disponible. La "
+"Devuelve la coordenada Z del punto, o NULL si no está disponible. La "
#. Tag: para
#: reference_accessor.xml:2165
diff --git a/doc/po/es/reference_constructor.xml.po b/doc/po/es/reference_constructor.xml.po
index c7869f4ee..a870e0cec 100644
--- a/doc/po/es/reference_constructor.xml.po
+++ b/doc/po/es/reference_constructor.xml.po
@@ -350,7 +350,7 @@ msgstr "Ejemplos"
#: reference_constructor.xml:121
msgid "Create a 3D line string from a 3D MultiPoint"
-msgstr "<para>Crea una LineString desde una geometría MultiPoint.</para>"
+msgstr "Crea una LineString desde una geometría MultiPoint."
#. Tag: programlisting
#: reference_constructor.xml:122
diff --git a/doc/po/es/reference_lrs.xml.po b/doc/po/es/reference_lrs.xml.po
index 3b1d99f9c..936dcbaec 100644
--- a/doc/po/es/reference_lrs.xml.po
+++ b/doc/po/es/reference_lrs.xml.po
@@ -756,9 +756,8 @@ msgid ""
"Returns the locations along a measured geometry (as a Point or MultiPoint) "
"that match a measure value. Polygonal elements are not supported."
msgstr ""
-"<para>Devuelve un valor de la colección Geometry derivado con elementos que "
-"coinciden con la medida especificada. No se admiten elementos poligonales.</"
-"para>"
+"Devuelve un valor de la colección Geometry derivado con elementos que "
+"coinciden con la medida especificada. No se admiten elementos poligonales."
#. Tag: para
#: reference_lrs.xml:365 reference_lrs.xml:419
@@ -862,9 +861,8 @@ msgid ""
"Return a geometry (collection) with the portions of the input measured "
"geometry that match the specified measure range (inclusively)."
msgstr ""
-"para>"
#. Tag: para
#: reference_lrs.xml:423 reference_lrs.xml:474
@@ -994,8 +992,8 @@ msgstr "ST_InterpolatePoint"
msgid "Returns the interpolated measure of a geometry closest to a point."
msgstr ""
-"<para>Devuelve el valor de la dimensión medida de una geometría en el punto "
-"cerrado al punto proporcionado.</para>"
+"Devuelve el valor de la dimensión medida de una geometría en el punto "
+"cerrado al punto proporcionado."
#: reference_lrs.xml:506
@@ -1016,8 +1014,8 @@ msgid ""
"Returns the value of the measure dimension of a geometry at the point closed "
"to the provided point."
msgstr ""
#. Tag: para
#: reference_lrs.xml:520
diff --git a/doc/po/es/reference_management.xml.po b/doc/po/es/reference_management.xml.po
index 8d442ff0d..176aa49bb 100644
--- a/doc/po/es/reference_management.xml.po
+++ b/doc/po/es/reference_management.xml.po
@@ -602,13 +602,11 @@ msgid ""
"parameter></paramdef> <paramdef><type>varchar </type> "
"<parameter>a_geomfield_name</parameter></paramdef>"
msgstr ""
-"<funcprototype> <funcdef>text <function>Populate_Geometry_Columns</"
-"function></funcdef> <paramdef><type>boolean </type> "
-"<parameter>use_typmod=true</parameter></paramdef> </funcprototype> "
-"<funcprototype> <funcdef>int <function>Populate_Geometry_Columns</function></"
-"funcdef> <paramdef><type>oid</type> <parameter>relation_oid</parameter></"
-"paramdef> <paramdef><type>boolean </type> <parameter>use_typmod=true</"
-"parameter></paramdef> </funcprototype>"
+"<funcdef>integer <function>Find_SRID</function></funcdef> "
+"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> <parameter>a_table_name</"
+"parameter></paramdef> <paramdef><type>varchar </type> "
+"<parameter>a_geomfield_name</parameter></paramdef>"
#. Tag: para
#: reference_management.xml:304
diff --git a/doc/po/es/reference_transaction.xml.po b/doc/po/es/reference_transaction.xml.po
index 0755c5863..481f6a5da 100644
--- a/doc/po/es/reference_transaction.xml.po
+++ b/doc/po/es/reference_transaction.xml.po
@@ -274,9 +274,9 @@ msgid ""
"transaction support metadata tables, and drops all triggers attached to lock-"
"checked tables."
msgstr ""
-"<para>Deshabilita el soporte de transacciones grandes. Esta función elimina "
+"Deshabilita el soporte de transacciones grandes. Esta función elimina "
"las tablas de metadatos para soporte de transacciones grandes, y borra todos "
-"los disparadores vinculados a las tablas de comprobación de bloqueos.</para>"
+"los disparadores vinculados a las tablas de comprobación de bloqueos."
#. Tag: para
#: reference_transaction.xml:139
@@ -332,10 +332,10 @@ msgid ""
"metadata tables. It must be called once before using the other functions in "
"this section. Calling it twice is harmless."
msgstr ""
-"<para>Habilita el soporte de transacciones grandes. Esta función crea las "
+"Habilita el soporte de transacciones grandes. Esta función crea las "
"tablas de metadatos requeridas, necesita ser llamada una vez antes de usar "
"las otras funciones en esta sección. Llamarla más de una vez no produce "
-"problemas.</para>"
+"problemas."
#. Tag: para
#: reference_transaction.xml:185
@@ -479,8 +479,8 @@ msgid ""
"Removes all locks held by specified authorization token. Returns the number "
"of locks released."
msgstr ""
-"<para>Retira todos los bloqueos mantenidos por el id de la autorización "
-"especificada. Devuelve el número de bloqueos liberados.</para>"
+"Retira todos los bloqueos mantenidos por el id de la autorización "
+"especificada. Devuelve el número de bloqueos liberados."
#: reference_transaction.xml:300
Summary of changes:
doc/po/es/reference_accessor.xml.po | 46 +++++++++++++---------------------
doc/po/es/reference_constructor.xml.po | 2 +-
doc/po/es/reference_lrs.xml.po | 18 ++++++-------
doc/po/es/reference_management.xml.po | 12 ++++-----
doc/po/es/reference_transaction.xml.po | 12 ++++-----
5 files changed, 38 insertions(+), 52 deletions(-)
hooks/post-receive
