[postgis-tickets] [PostGIS] #5070: TWKB: last point of the linearing hole of a polygon is lost when xyprecision < 0
trac at osgeo.org
Sun Jan 30 22:34:24 PST 2022
xyprecision < 0
Reporter: Aurélien Mino | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by nicklas):
That the point disapears comes from the optimization of removing identical
points.
From the discussion in the github thread, do you agree this is correct?
But I do not remember why we don't remove the hole when all the points are
the same.
I might recall we had some discussion about it, but I am not sure. The
alternative would be to:
"If we don't have at least 3 different points in a hola after reducing
precision we remove the hole".
What talks against that solution is that it would put an overhead for all
holes.
I see ST_Makevalid can do that job as a postprocessing. I guess that is
what we thought.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5070#comment:2>
