[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-421-g58820aa98
git at osgeo.org
git at osgeo.org
Mon Jan 31 06:35:30 PST 2022
the project "PostGIS".
via 58820aa9839343933e3528819ea1c26c98a2203e (commit)
from dba8989936816731bfbcbbe25be36d89e5c18eaf (commit)
revisions in full, below.
commit 58820aa9839343933e3528819ea1c26c98a2203e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 15:35:21 2022 +0100
Fix validity errors in french translation
diff --git a/doc/po/fr/reference_accessor.xml.po b/doc/po/fr/reference_accessor.xml.po
index a0dff6b19..da1857638 100644
--- a/doc/po/fr/reference_accessor.xml.po
+++ b/doc/po/fr/reference_accessor.xml.po
@@ -84,8 +84,8 @@ msgid ""
"Returns the type of the geometry as a string. Eg: 'LINESTRING', 'POLYGON', "
"'MULTIPOINT', etc."
msgstr ""
-"<para>Retourne le type de la géométrie, par exemple: 'LINESTRING', "
-"'POLYGON', 'MULTIPOINT', etc.</para>"
+"Retourne le type de la géométrie, par exemple: 'LINESTRING', "
+"'POLYGON', 'MULTIPOINT', etc."
#. Tag: para
#: reference_accessor.xml:28
diff --git a/doc/po/fr/reference_constructor.xml.po b/doc/po/fr/reference_constructor.xml.po
index 00369e75e..839fd9bb3 100644
--- a/doc/po/fr/reference_constructor.xml.po
+++ b/doc/po/fr/reference_constructor.xml.po
@@ -349,7 +349,7 @@ msgstr "Exemples"
#: reference_constructor.xml:121
#, fuzzy, no-c-format
msgid "Create a 3D line string from a 3D MultiPoint"
-msgstr "<para>Crée une LineString à partir d'une géométrie MultiPoint.</para>"
+msgstr "Crée une LineString à partir d'une géométrie MultiPoint."
#. Tag: programlisting
#: reference_constructor.xml:122
@@ -476,7 +476,7 @@ msgstr "ST_MakeLine"
#: reference_constructor.xml:179
msgid "Creates a LineString from Point, MultiPoint, or LineString geometries."
#. Tag: funcsynopsis
#: reference_constructor.xml:183
diff --git a/doc/po/fr/reference_management.xml.po b/doc/po/fr/reference_management.xml.po
index f0f7fff50..fe707059a 100644
--- a/doc/po/fr/reference_management.xml.po
+++ b/doc/po/fr/reference_management.xml.po
@@ -518,13 +518,11 @@ msgid ""
"parameter></paramdef> <paramdef><type>varchar </type> "
"<parameter>a_geomfield_name</parameter></paramdef>"
msgstr ""
-"<funcprototype> <funcdef>text <function>Populate_Geometry_Columns</"
-"function></funcdef> <paramdef><type>boolean </type> "
-"<parameter>use_typmod=true</parameter></paramdef> </funcprototype> "
-"<funcprototype> <funcdef>int <function>Populate_Geometry_Columns</function></"
-"funcdef> <paramdef><type>oid</type> <parameter>relation_oid</parameter></"
-"paramdef> <paramdef><type>boolean </type> <parameter>use_typmod=true</"
-"parameter></paramdef> </funcprototype>"
+"<funcdef>integer <function>Find_SRID</function></funcdef> "
+"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> <parameter>a_table_name</"
+"parameter></paramdef> <paramdef><type>varchar </type> "
+"<parameter>a_geomfield_name</parameter></paramdef>"
#. Tag: para
#: reference_management.xml:304
diff --git a/doc/po/fr/reference_raster.xml.po b/doc/po/fr/reference_raster.xml.po
index 9f11be170..403680ba8 100644
--- a/doc/po/fr/reference_raster.xml.po
+++ b/doc/po/fr/reference_raster.xml.po
@@ -3285,7 +3285,7 @@ msgstr ""
#. Tag: funcprototype
#: reference_raster.xml:1748
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"<funcdef>raster <function>ST_MakeEmptyCoverage</function></funcdef> "
"<paramdef><type>integer </type> <parameter>tilewidth</parameter></paramdef> "
@@ -3302,20 +3302,20 @@ msgid ""
"paramdef> <paramdef choice=\"opt\"><type>integer </type> "
"<parameter>srid=unknown</parameter></paramdef>"
msgstr ""
-"<funcprototype> <funcdef>raster <function>ST_Rescale</function></funcdef> "
-"<paramdef><type>raster </type> <parameter>rast</parameter></paramdef> "
-"<paramdef><type>double precision </type> <parameter>scalexy</parameter></"
-"paramdef> <paramdef choice=\"opt\"><type>text </type> "
-"<parameter>algorithm=NearestNeighbour</parameter></paramdef> <paramdef "
-"choice=\"opt\"><type>double precision </type> <parameter>maxerr=0.125</"
-"parameter></paramdef> </funcprototype> <funcprototype> <funcdef>raster "
-"<function>ST_Rescale</function></funcdef> <paramdef><type>raster </type> "
-"<parameter>rast</parameter></paramdef> <paramdef><type>double precision </"
-"type> <parameter>scalex</parameter></paramdef> <paramdef><type>double "
-"precision </type> <parameter>scaley</parameter></paramdef> <paramdef choice="
-"\"opt\"><type>text </type> <parameter>algorithm=NearestNeighbour</"
-"parameter></paramdef> <paramdef choice=\"opt\"><type>double precision </"
-"type> <parameter>maxerr=0.125</parameter></paramdef> </funcprototype>"
+"<funcdef>raster <function>ST_MakeEmptyCoverage</function></funcdef> "
+"<paramdef><type>integer </type> <parameter>tilewidth</parameter></paramdef> "
+"<paramdef><type>integer </type> <parameter>tileheight</parameter></paramdef> "
+"<paramdef><type>integer </type> <parameter>width</parameter></paramdef> "
+"<paramdef><type>integer </type> <parameter>height</parameter></paramdef> "
+"<paramdef><type>double precision </type> <parameter>upperleftx</parameter></"
+"paramdef> <paramdef><type>double precision </type> <parameter>upperlefty</"
+"parameter></paramdef> <paramdef><type>double precision </type> "
+"<parameter>scalex</parameter></paramdef> <paramdef><type>double precision </"
+"type> <parameter>scaley</parameter></paramdef> <paramdef><type>double "
+"precision </type> <parameter>skewx</parameter></paramdef> "
+"<paramdef><type>double precision </type> <parameter>skewy</parameter></"
+"paramdef> <paramdef choice=\"opt\"><type>integer </type> "
+"<parameter>srid=unknown</parameter></paramdef>"
#. Tag: para
#: reference_raster.xml:1768
@@ -8969,36 +8969,49 @@ msgid ""
"\"opt\"><type>double precision </type> <parameter>maxerr=0.125</parameter></"
"paramdef> </funcprototype>"
msgstr ""
-"<funcprototype> <funcdef>raster <function>ST_SnapToGrid</function></funcdef> "
+"<funcprototype> <funcdef>raster <function>ST_Resample</function></funcdef> "
-"<paramdef><type>double precision </type> <parameter>gridx</parameter></"
-"paramdef> <paramdef><type>double precision </type> <parameter>gridy</"
-"parameter></paramdef> <paramdef choice=\"opt\"><type>text </type> "
+"<paramdef choice=\"opt\"><type>double precision </type> "
+"<parameter>gridx=NULL</parameter></paramdef> <paramdef choice=\"opt"
+"\"><type>double precision </type> <parameter>gridy=NULL</parameter></"
+"paramdef> <paramdef choice=\"opt\"><type>double precision </type> "
+"<parameter>skewx=0</parameter></paramdef> <paramdef choice=\"opt"
+"\"><type>double precision </type> <parameter>skewy=0</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>text </type> "
+"<parameter>algorithm=NearestNeighbor</parameter></paramdef> <paramdef choice="
+"\"opt\"><type>double precision </type> <parameter>maxerr=0.125</parameter></"
+"paramdef> </funcprototype> <funcprototype> <funcdef>raster "
+"<function>ST_Resample</function></funcdef> <paramdef><type>raster </type> "
+"<parameter>rast</parameter></paramdef> <paramdef choice=\"opt\"><type>double "
+"precision </type> <parameter>scalex=0</parameter></paramdef> <paramdef "
+"choice=\"opt\"><type>double precision </type> <parameter>scaley=0</"
-"type> <parameter>scalex=DEFAULT 0</parameter></paramdef> <paramdef choice="
-"\"opt\"><type>double precision </type> <parameter>scaley=DEFAULT 0</"
-"<function>ST_SnapToGrid</function></funcdef> <paramdef><type>raster </type> "
-"type> <parameter>gridx</parameter></paramdef> <paramdef><type>double "
-"precision </type> <parameter>gridy</parameter></paramdef> "
-"<paramdef><type>double precision </type> <parameter>scalex</parameter></"
-"paramdef> <paramdef><type>double precision </type> <parameter>scaley</"
+"type> <parameter>gridx=NULL</parameter></paramdef> <paramdef choice=\"opt"
+"<parameter>rast</parameter></paramdef> <paramdef><type>raster </type> "
+"<parameter>ref</parameter></paramdef> <paramdef choice=\"opt\"><type>text </"
+"type> <parameter>algorithm=NearestNeighbor</parameter></paramdef> <paramdef "
+"parameter></paramdef> <paramdef choice=\"opt\"><type>boolean </type> "
+"<parameter>usescale=true</parameter></paramdef> </funcprototype> "
+"<paramdef><type>raster </type> <parameter>rast</parameter></paramdef> "
+"<paramdef><type>raster </type> <parameter>ref</parameter></paramdef> "
+"<paramdef><type>boolean </type> <parameter>usescale</parameter></paramdef> "
+"paramdef> </funcprototype>"
#. Tag: para
#: reference_raster.xml:4807
@@ -9104,7 +9117,7 @@ msgstr ""
#: reference_raster.xml:4852
+#, no-c-format
msgid ""
@@ -9125,16 +9138,16 @@ msgstr ""
+"\"opt\"><type>text </type> <parameter>algorithm=NearestNeighbor</parameter></"
+"<parameter>maxerr=0.125</parameter></paramdef> </funcprototype>"
#. Tag: para
#: reference_raster.xml:4876
@@ -9251,7 +9264,7 @@ msgstr ""
#: reference_raster.xml:4920
+#, no-c-format
msgid ""
"<funcprototype> <funcdef>raster <function>ST_Reskew</function></funcdef> "
@@ -9272,16 +9285,16 @@ msgstr ""
"<paramdef><type>double precision </type> <parameter>skewxy</parameter></"
"<function>ST_Reskew</function></funcdef> <paramdef><type>raster </type> "
"type> <parameter>skewx</parameter></paramdef> <paramdef><type>double "
"precision </type> <parameter>skewy</parameter></paramdef> <paramdef choice="
#. Tag: para
#: reference_raster.xml:4944
@@ -9381,7 +9394,7 @@ msgstr ""
#: reference_raster.xml:4982
+#, no-c-format
msgid ""
@@ -9419,12 +9432,12 @@ msgstr ""
+"<parameter>scalex=DEFAULT 0</parameter></paramdef> <paramdef choice=\"opt"
+"\"><type>double precision </type> <parameter>scaley=DEFAULT 0</parameter></"
@@ -9432,18 +9445,18 @@ msgstr ""
#. Tag: para
#: reference_raster.xml:5021
diff --git a/doc/po/fr/reference_transaction.xml.po b/doc/po/fr/reference_transaction.xml.po
index c643427d8..95c0a6511 100644
--- a/doc/po/fr/reference_transaction.xml.po
+++ b/doc/po/fr/reference_transaction.xml.po
@@ -277,10 +277,10 @@ msgid ""
"transaction support metadata tables, and drops all triggers attached to lock-"
"checked tables."
msgstr ""
-"<para>Désactive le support des transactions longues. Cette fonction supprime "
+"Désactive le support des transactions longues. Cette fonction supprime "
"les tables de métadonnées du support de transactions longues, et supprime "
"également tous les déclencheurs attachés aux tables pour lesquelles il y a "
-"une vérification de verrou.</para>"
+"une vérification de verrou."
#. Tag: para
#: reference_transaction.xml:139
@@ -336,10 +336,10 @@ msgid ""
"metadata tables. It must be called once before using the other functions in "
"this section. Calling it twice is harmless."
msgstr ""
-"<para>Active le support des transactions longues. Cette fonction crée les "
+"Active le support des transactions longues. Cette fonction crée les "
"tables de métadonnées nécessaires. Elle doit être appelée une fois avant "
"d'utiliser les autres fonctions de cette section. L'appeler deux fois ou "
-"plus n'a aucun effet.</para>"
+"plus n'a aucun effet."
#. Tag: para
#: reference_transaction.xml:185
@@ -484,8 +484,8 @@ msgid ""
"Removes all locks held by specified authorization token. Returns the number "
"of locks released."
msgstr ""
-"<para>Supprime tous les verrous que possède l'autorisation spécifiée. "
-"Retourne le nombre de verrous supprimés.</para>"
+"Supprime tous les verrous que possède l'autorisation spécifiée. "
+"Retourne le nombre de verrous supprimés."
#: reference_transaction.xml:300
Summary of changes:
doc/po/fr/reference_accessor.xml.po | 4 +-
doc/po/fr/reference_constructor.xml.po | 4 +-
doc/po/fr/reference_management.xml.po | 12 ++-
doc/po/fr/reference_raster.xml.po | 151 ++++++++++++++++++---------------
doc/po/fr/reference_transaction.xml.po | 12 +--
5 files changed, 97 insertions(+), 86 deletions(-)
hooks/post-receive
