[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-424-g418556ccd
git at osgeo.org
git at osgeo.org
Mon Jan 31 06:52:21 PST 2022
the project "PostGIS".
via 418556ccdd06d02b222f05c1a3a798415f3ce6a4 (commit)
via c1b870248d8ab317a2d5e3b2a7a205198ad3c6e7 (commit)
from 43c28820ac147e39e76b22cecad93766be7a86c5 (commit)
revisions in full, below.
commit 418556ccdd06d02b222f05c1a3a798415f3ce6a4
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 15:51:41 2022 +0100
Fix validity errors in ko_KR translation
diff --git a/doc/po/ko_KR/reference_accessor.xml.po b/doc/po/ko_KR/reference_accessor.xml.po
index 8bc85ceb1..7b2fd7e59 100644
--- a/doc/po/ko_KR/reference_accessor.xml.po
+++ b/doc/po/ko_KR/reference_accessor.xml.po
@@ -80,8 +80,8 @@ msgid ""
"Returns the type of the geometry as a string. Eg: 'LINESTRING', 'POLYGON', "
"'MULTIPOINT', etc."
msgstr ""
-"<para>도형의 유형을 스트링으로 반환합니다. 예: 'LINESTRING', 'POLYGON', "
-"'MULTIPOINT' 등등.</para>"
+"도형의 유형을 스트링으로 반환합니다. 예: 'LINESTRING', 'POLYGON', "
+"'MULTIPOINT' 등등."
#. Tag: para
#: reference_accessor.xml:28
@@ -659,7 +659,7 @@ msgstr "ST_CoordDim"
#: reference_accessor.xml:220
#, fuzzy, no-c-format
msgid "Return the coordinate dimension of a geometry."
-msgstr "<para>ST_Geometry 값의 좌표 차원을 반환합니다.</para>"
+msgstr "ST_Geometry 값의 좌표 차원을 반환합니다."
#. Tag: funcprototype
#: reference_accessor.xml:225
@@ -675,7 +675,7 @@ msgstr ""
#: reference_accessor.xml:235
msgid "Return the coordinate dimension of the ST_Geometry value."
#. Tag: para
#: reference_accessor.xml:237
@@ -722,7 +722,7 @@ msgstr "ST_Dimension"
#: reference_accessor.xml:266
msgid "Returns the topological dimension of a geometry."
#: reference_accessor.xml:271
@@ -1006,7 +1006,7 @@ msgstr "ST_NumPoints"
msgid ""
"Returns a set of <varname>geometry_dump</varname> rows for the coordinates "
"in a geometry."
-msgstr "<para>도형의 내용을 요약한 텍스트를 반환합니다.</para>"
+msgstr "도형의 내용을 요약한 텍스트를 반환합니다."
#: reference_accessor.xml:378
@@ -1339,7 +1339,7 @@ msgstr "ST_NumPoints"
msgid ""
"Returns a set of <varname>geometry_dump</varname> rows for the segments in a "
"geometry."
#: reference_accessor.xml:464
@@ -3312,8 +3312,8 @@ msgid ""
"Return the M coordinate of a Point, or NULL if not available. Input must be "
"a Point."
msgstr ""
-"<para>포인트의 M 좌표를 반환합니다. M 좌표가 없는 경우 NULL을 반환합니다. 포"
-"인트만 입력받을 수 있습니다.</para>"
+"포인트의 M 좌표를 반환합니다. M 좌표가 없는 경우 NULL을 반환합니다. 포"
+"인트만 입력받을 수 있습니다."
#. Tag: para
#: reference_accessor.xml:1372
@@ -3470,7 +3470,7 @@ msgstr "ST_NDims"
#: reference_accessor.xml:1442
msgid "Returns the coordinate dimension of a geometry."
#: reference_accessor.xml:1447
@@ -4446,7 +4446,7 @@ msgstr "ST_Summary"
#: reference_accessor.xml:1980
msgid "Returns a text summary of the contents of a geometry."
#. Tag: funcsynopsis
#: reference_accessor.xml:1985
@@ -4468,7 +4468,7 @@ msgstr ""
#: reference_accessor.xml:2000
msgid "Returns a text summary of the contents of the geometry."
#. Tag: para
#: reference_accessor.xml:2002
@@ -4637,8 +4637,8 @@ msgid ""
"Return the X coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>포인트의 X 좌표를 반환합니다. X 좌표가 없는 경우 NULL을 반환합니다. 포"
+"포인트의 X 좌표를 반환합니다. X 좌표가 없는 경우 NULL을 반환합니다. 포"
+"인트만 입력받을 수 있습니다."
#. Tag: para
#: reference_accessor.xml:2076
@@ -4723,8 +4723,8 @@ msgid ""
"Return the Y coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>포인트의 Y 좌표를 반환합니다. Y 좌표가 없는 경우 NULL을 반환합니다. 포"
+"포인트의 Y 좌표를 반환합니다. Y 좌표가 없는 경우 NULL을 반환합니다. 포"
+"인트만 입력받을 수 있습니다."
#. Tag: para
#: reference_accessor.xml:2120
@@ -4809,8 +4809,8 @@ msgid ""
"Return the Z coordinate of the point, or NULL if not available. Input must "
"be a point."
msgstr ""
-"<para>포인트의 Z 좌표를 반환합니다. Z 좌표가 없는 경우 NULL을 반환합니다. 포"
+"포인트의 Z 좌표를 반환합니다. Z 좌표가 없는 경우 NULL을 반환합니다. 포"
+"인트만 입력받을 수 있습니다."
#. Tag: para
#: reference_accessor.xml:2165
diff --git a/doc/po/ko_KR/reference_constructor.xml.po b/doc/po/ko_KR/reference_constructor.xml.po
index 124b0a873..bd1cd94e4 100644
--- a/doc/po/ko_KR/reference_constructor.xml.po
+++ b/doc/po/ko_KR/reference_constructor.xml.po
@@ -348,7 +348,7 @@ msgstr "예시"
#: reference_constructor.xml:121
msgid "Create a 3D line string from a 3D MultiPoint"
-msgstr "<para>멀티포인트 도형으로부터 라인스트링을 생성합니다.</para>"
+msgstr "멀티포인트 도형으로부터 라인스트링을 생성합니다."
#. Tag: programlisting
#: reference_constructor.xml:122
diff --git a/doc/po/ko_KR/reference_lrs.xml.po b/doc/po/ko_KR/reference_lrs.xml.po
index e28fca1ae..3f1356ab8 100644
--- a/doc/po/ko_KR/reference_lrs.xml.po
+++ b/doc/po/ko_KR/reference_lrs.xml.po
@@ -751,8 +751,8 @@ msgid ""
"Returns the locations along a measured geometry (as a Point or MultiPoint) "
"that match a measure value. Polygonal elements are not supported."
msgstr ""
-"<para>설정한 척도와 일치하는 요소들을 가진 파생 도형 집합의 값을 반환합니다. "
-"폴리곤 구성 요소는 지원되지 않습니다.</para>"
+"설정한 척도와 일치하는 요소들을 가진 파생 도형 집합의 값을 반환합니다. "
+"폴리곤 구성 요소는 지원되지 않습니다."
#. Tag: para
#: reference_lrs.xml:365 reference_lrs.xml:419
@@ -855,8 +855,8 @@ msgid ""
"Return a geometry (collection) with the portions of the input measured "
"geometry that match the specified measure range (inclusively)."
msgstr ""
#. Tag: para
#: reference_lrs.xml:423 reference_lrs.xml:474
@@ -983,11 +983,11 @@ msgstr "ST_InterpolatePoint"
#. Tag: refpurpose
#: reference_lrs.xml:501
-#, fuzzy, no-c-format
+#, no-c-format
msgid "Returns the interpolated measure of a geometry closest to a point."
msgstr ""
-"<para>입력 포인트에 가까운 포인트에서 도형의 척도 차원(M 차원)의 값을 반환합"
-"니다.</para>"
+"입력 포인트에 가까운 포인트에서 도형의 척도 차원(M 차원)의 값을 반환합"
+"니다."
#: reference_lrs.xml:506
@@ -1008,8 +1008,8 @@ msgid ""
"Returns the value of the measure dimension of a geometry at the point closed "
"to the provided point."
msgstr ""
-"니다.</para>"
+"니다."
#. Tag: para
#: reference_lrs.xml:520
diff --git a/doc/po/ko_KR/reference_management.xml.po b/doc/po/ko_KR/reference_management.xml.po
index 89081112b..6c4c4a115 100644
--- a/doc/po/ko_KR/reference_management.xml.po
+++ b/doc/po/ko_KR/reference_management.xml.po
@@ -584,7 +584,7 @@ msgstr ""
#: reference_management.xml:292
+#, no-c-format
msgid ""
"<funcdef>integer <function>Find_SRID</function></funcdef> "
"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
@@ -592,13 +592,11 @@ msgid ""
"parameter></paramdef> <paramdef><type>varchar </type> "
"<parameter>a_geomfield_name</parameter></paramdef>"
msgstr ""
-"<funcprototype> <funcdef>text <function>Populate_Geometry_Columns</"
-"function></funcdef> <paramdef><type>boolean </type> "
-"<parameter>use_typmod=true</parameter></paramdef> </funcprototype> "
-"<funcprototype> <funcdef>int <function>Populate_Geometry_Columns</function></"
-"funcdef> <paramdef><type>oid</type> <parameter>relation_oid</parameter></"
-"paramdef> <paramdef><type>boolean </type> <parameter>use_typmod=true</"
-"parameter></paramdef> </funcprototype>"
+"<funcdef>integer <function>Find_SRID</function></funcdef> "
+"<paramdef><type>varchar </type> <parameter>a_schema_name</parameter></"
+"paramdef> <paramdef><type>varchar </type> <parameter>a_table_name</"
+"parameter></paramdef> <paramdef><type>varchar </type> "
+"<parameter>a_geomfield_name</parameter></paramdef>"
#. Tag: para
#: reference_management.xml:304
diff --git a/doc/po/ko_KR/reference_measure.xml.po b/doc/po/ko_KR/reference_measure.xml.po
index 4fca21868..e6ab1c41d 100644
--- a/doc/po/ko_KR/reference_measure.xml.po
+++ b/doc/po/ko_KR/reference_measure.xml.po
@@ -2121,8 +2121,8 @@ msgid ""
"Returns the 2D length of a linear geometry. Alias for <varname>ST_Length</"
"varname>"
msgstr ""
-"<para>도형이 라인스트링 또는 멀티라인스트링일 경우 도형의 2차원 길이를 반환합"
-"니다. 이 함수는 <varname>ST_Length</varname> 와 동일합니다.</para>"
+"도형이 라인스트링 또는 멀티라인스트링일 경우 도형의 2차원 길이를 반환합"
+"니다. 이 함수는 <varname>ST_Length</varname> 와 동일합니다."
#: reference_measure.xml:806
@@ -2143,8 +2143,8 @@ msgid ""
"Returns the 2D length of the geometry if it is a linestring or multi-"
"linestring. This is an alias for <varname>ST_Length</varname>"
msgstr ""
#. Tag: para
#: reference_measure.xml:825
diff --git a/doc/po/ko_KR/reference_operator.xml.po b/doc/po/ko_KR/reference_operator.xml.po
index 499ff9663..757f05f70 100644
--- a/doc/po/ko_KR/reference_operator.xml.po
+++ b/doc/po/ko_KR/reference_operator.xml.po
@@ -229,14 +229,15 @@ msgstr "참고"
#. Tag: para
#: reference_operator.xml:77
+#, no-c-format
msgid ""
", <xref linkend=\"ST_Extent\"/>, <xref linkend=\"ST_Geometry_Overabove\"/>, "
"<xref linkend=\"ST_Geometry_Overright\"/>, <xref linkend="
"\"ST_Geometry_Overbelow\"/>, <xref linkend=\"ST_Geometry_Overleft\"/>, <xref "
"linkend=\"ST_Geometry_Contain\"/>, <xref linkend=\"ST_Geometry_Contained\"/>"
msgstr ""
-", <xref linkend=\"ST_Geometry_Overright\"/>, <xref linkend="
+", <xref linkend=\"ST_Extent\"/>, <xref linkend=\"ST_Geometry_Overabove\"/>, "
+"<xref linkend=\"ST_Geometry_Overright\"/>, <xref linkend="
@@ -1172,7 +1173,7 @@ msgstr ""
#: reference_operator.xml:791
#, no-c-format
msgid "="
-msgstr "<refname>=</refname>"
+msgstr "="
#. Tag: refpurpose
#: reference_operator.xml:793
diff --git a/doc/po/ko_KR/reference_transaction.xml.po b/doc/po/ko_KR/reference_transaction.xml.po
index 14decc3b1..49734570e 100644
--- a/doc/po/ko_KR/reference_transaction.xml.po
+++ b/doc/po/ko_KR/reference_transaction.xml.po
@@ -265,9 +265,9 @@ msgid ""
"transaction support metadata tables, and drops all triggers attached to lock-"
"checked tables."
msgstr ""
-"<para>장기 실행 트랜잭션 지원을 비활성화시킵니다. 이 함수는 장기 실행 트랜잭"
+"장기 실행 트랜잭션 지원을 비활성화시킵니다. 이 함수는 장기 실행 트랜잭"
"션 지원 메타데이터 테이블을 제거하고, 잠금을 확인한(lock-checked) 테이블에 부"
-"여된 모든 트리거를 삭제합니다.</para>"
+"여된 모든 트리거를 삭제합니다."
#. Tag: para
#: reference_transaction.xml:139
@@ -323,9 +323,9 @@ msgid ""
"metadata tables. It must be called once before using the other functions in "
"this section. Calling it twice is harmless."
msgstr ""
-"<para>장기 실행 트랜잭션 지원을 활성화시킵니다. 이 함수는 필수적인 메타데이"
+"장기 실행 트랜잭션 지원을 활성화시킵니다. 이 함수는 필수적인 메타데이"
"터 테이블들을 생성하는데, 이 단원에 있는 다른 함수들을 이용하기 전에 한번 호"
-"출해줘야 합니다. 두 번 호출해도 상관없습니다.</para>"
+"출해줘야 합니다. 두 번 호출해도 상관없습니다."
#. Tag: para
#: reference_transaction.xml:185
@@ -469,8 +469,8 @@ msgid ""
"Removes all locks held by specified authorization token. Returns the number "
"of locks released."
msgstr ""
-"<para>특정 승인 ID가 실행한 모든 잠금을 제거합니다. 해제된 잠금 개수를 반환합"
-"니다.</para>"
+"특정 승인 ID가 실행한 모든 잠금을 제거합니다. 해제된 잠금 개수를 반환합"
+"니다."
#: reference_transaction.xml:300
commit c1b870248d8ab317a2d5e3b2a7a205198ad3c6e7
Date: Mon Jan 31 15:41:05 2022 +0100
Fix invalid refs in ko_KR translation
diff --git a/doc/po/ko_KR/reference.xml.po b/doc/po/ko_KR/reference.xml.po
index feb20d6e7..fe7e996fd 100644
--- a/doc/po/ko_KR/reference.xml.po
+++ b/doc/po/ko_KR/reference.xml.po
@@ -56,7 +56,7 @@ msgstr ""
#. Tag: chapter
#: reference.xml:16
+#, no-c-format
msgid ""
"&reference_type; &reference_management; &reference_constructor; "
"&reference_accessor; &reference_editor; &reference_validation; "
@@ -67,8 +67,11 @@ msgid ""
"&reference_transaction; &reference_version; &reference_guc; "
"&reference_troubleshooting;"
msgstr ""
-"&reference_type; &reference_guc; &reference_management; "
-"&reference_constructor; &reference_accessor; &reference_editor; "
-"&reference_output; &reference_operator; &reference_measure; "
-"&reference_sfcgal; &reference_processing; &reference_lrs; "
-"&reference_transaction; "
+"&reference_type; &reference_management; &reference_constructor; "
+"&reference_accessor; &reference_editor; &reference_validation; "
+"&reference_srs; &reference_input; &reference_output; &reference_operator; "
+"&reference_relationship; &reference_measure; &reference_overlay; "
+"&reference_processing; &reference_transformation; &reference_cluster; "
+"&reference_bbox; &reference_lrs; &reference_trajectory; &reference_sfcgal; "
+"&reference_transaction; &reference_version; &reference_guc; "
+"&reference_troubleshooting;"
index a27c9092a..124b0a873 100644
@@ -1371,15 +1371,15 @@ msgstr ""
#. Tag: para
#: reference_constructor.xml:542
+#, no-c-format
msgid ""
", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
"linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref linkend="
"\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
msgstr ""
-", <xref linkend=\"ST_Accum\"/>, <xref linkend=\"ST_AddPoint\"/>, <xref "
-"linkend=\"ST_GeometryType\"/>, <xref linkend=\"ST_IsClosed\"/>, <xref "
-"linkend=\"ST_LineMerge\"/>, <xref linkend=\"ST_BuildArea\"/>"
+", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
+"linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref linkend="
+"\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
#. Tag: refname
#: reference_constructor.xml:549
Summary of changes:
doc/po/ko_KR/reference.xml.po | 15 +++++++------
doc/po/ko_KR/reference_accessor.xml.po | 36 +++++++++++++++----------------
doc/po/ko_KR/reference_constructor.xml.po | 10 ++++-----
doc/po/ko_KR/reference_lrs.xml.po | 18 ++++++++--------
doc/po/ko_KR/reference_management.xml.po | 14 ++++++------
doc/po/ko_KR/reference_measure.xml.po | 8 +++----
doc/po/ko_KR/reference_operator.xml.po | 7 +++---
doc/po/ko_KR/reference_transaction.xml.po | 12 +++++------
8 files changed, 61 insertions(+), 59 deletions(-)
hooks/post-receive
