[postgis-tickets] [PostGIS] #5061: update-po keep old strings
trac at osgeo.org
Mon Jan 31 07:28:50 PST 2022
Reporter: robe | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.3.0
Component: l18n | Version: master
Resolution: | Keywords:
Comment (by strk):
I've just disabled fuzzy mathcing in our `update-po` as of
[dba8989936816731bfbcbbe25be36d89e5c18eaf/git] as it was found to often
result in broken XML.
The previous msgids could be added by adding --previous switch to MSGMERGE
but we'd need some experiementation with it. Could you make sure to drop
the fuzzy matching first from Weblate though ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5061#comment:3>
