[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-427-g12bc33bd7
git at osgeo.org
git at osgeo.org
Mon Jan 31 08:03:18 PST 2022
the project "PostGIS".
via 12bc33bd7a90d2f7cf6e140515fdf6c9ad467a45 (commit)
from 5d88858a2ca86e1eb8963515fc5dae86fd7ba382 (commit)
revisions in full, below.
commit 12bc33bd7a90d2f7cf6e140515fdf6c9ad467a45
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 17:03:03 2022 +0100
Fix -Werror=sign-compare warnings
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 65203f5ce..20d51088e 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -72,7 +72,7 @@ pointarrayToString(char *output, POINTARRAY *pa)
char x[OUT_DOUBLE_BUFFER_SIZE];
char y[OUT_DOUBLE_BUFFER_SIZE];
- int i;
+ unsigned int i;
char *ptr = output;
for ( i=0; i < pa->npoints; i++ )
@@ -162,7 +162,7 @@ static size_t
drawPolygon(char *output, LWPOLY *lwp, LAYERSTYLE *style)
char *ptr = output;
- int i;
+ unsigned int i;
LWDEBUGF(4, "%s", "drawPolygon called");
LWDEBUGF( 4, "poly = %s", lwgeom_to_ewkt((LWGEOM*)lwp) );
@@ -193,7 +193,7 @@ static size_t
drawGeometry(char *output, LWGEOM *lwgeom, LAYERSTYLE *styles )
char *ptr = output;
- int i;
+ unsigned int i;
int type = lwgeom->type;
switch (type)
Summary of changes:
doc/html/image_src/generator.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
