[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-430-g6ab30ba04
git at osgeo.org
git at osgeo.org
Mon Jan 31 09:09:20 PST 2022
the project "PostGIS".
via 6ab30ba04ff1b24446543b9c16407dde78d8d606 (commit)
from 753408bc2078f63e0469c337d5998dfb8c93c144 (commit)
revisions in full, below.
commit 6ab30ba04ff1b24446543b9c16407dde78d8d606
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jan 31 18:08:39 2022 +0100
Enable check-tests-enabled test on "make check"
Closes #5062
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 8b83943d4..70391fada 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -43,7 +43,7 @@ clean-local:
# TODO: drop 'test' target..
test: check
-check: check-no-trailing-blanks check-unit check-regress docs-check check-news
+check: check-no-trailing-blanks check-unit check-regress docs-check check-news check-tests-enabled
staged-install: all
$(MAKE) -C regress staged-install
Summary of changes:
GNUmakefile.in | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
